tomr Posted December 28, 2021 Share Posted December 28, 2021 1 hour ago, Ant.p said: Painted the body shell for the Losi 8eight T2.0 using a ‘marbling’ technique I thought I’d try out. I also had a go at framing the windows white. This was a delicate job, and it went okay. There is some paint bleed in a few spots, but if you squint it look the nuts 😅 Ive also put some belted road tyres on it as I’m planning to do some speed runs once done with the hyper 7 (so could be a while). Top job 👍 That looks awesome 1 Quote Link to comment Share on other sites More sharing options...
Ant.p Posted December 28, 2021 Share Posted December 28, 2021 (edited) 28 minutes ago, BigGinge said: That shell looks brilliant; any more detail to share on how you did the paint job? Thank you! I must admit, I was pleased with the effect having not done it before. Was also an experiment with the ‘fade’ but both are relatively easy to achieve… the marble effect requires 2 colours. First is applied heavy, then quickly lay a thin/soft plastic sheet over painted area. Use a paint brush to push into all the nooks and crannies, then peel off. This process lifts a large amount of paint from the shell. Leave to dry and then apply the 2nd colour as you normally would in a few thinner coats. I also did a fade at the same time. I sprayed from the front of the shell towards the rear, moving from left to right. Put the paint on thinner as you move towards the area you want to change colour. Then apply your other colour over the entire shell in thin coats. YouTube is full of examples of each process. I watched a load then made my own choices as there’s several ways of achieving the results. Edited December 28, 2021 by Ant.p 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Redback Posted December 28, 2021 Popular Post Share Posted December 28, 2021 Started a combined battery & esc tray for the tf2, only did 1/3 of the print as stuck my finger too close again. Still works good enough, glad it didnt waste 2 more hours on walls that wouldnt have been any use. Also locked the 2 speed to low range, had been locked running in high 🤦♂️ though the truck was rapid on 2s. 5 Quote Link to comment Share on other sites More sharing options...
BigGinge Posted December 28, 2021 Share Posted December 28, 2021 1 hour ago, Ant.p said: the marble effect requires 2 colours. First is applied heavy, then quickly lay a thin/soft plastic sheet over painted area. Use a paint brush to push into all the nooks and crannies, then peel off. This process lifts a large amount of paint from the shell. Leave to dry and then apply the 2nd colour as you normally would in a few thinner coats. I can totally see this in the patterns now that you have said how you’ve created them; a very cool bit of painting process (though one I can easily see myself overthinking if I were to ever give it a try. Do you need anything special for the plastic sheet or is something like the side of a thin carrier bag ok for doing this? Quote Link to comment Share on other sites More sharing options...
Ant.p Posted December 29, 2021 Share Posted December 29, 2021 9 hours ago, BigGinge said: I can totally see this in the patterns now that you have said how you’ve created them; a very cool bit of painting process (though one I can easily see myself overthinking if I were to ever give it a try. Do you need anything special for the plastic sheet or is something like the side of a thin carrier bag ok for doing this? I thought the same. You do need to work quickly so that the paint doesn’t get a chance to skin up. You don’t need to panic though. Just have everything to hand. Inconsistency adds to the effect, so just gently press the plastic so it’s in contact everywhere. Use a paintbrush to press where fingers can’t get. as for the type of plastic. The more flexible the better. A lightweight bin liner is what I used. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post everclear1984 Posted December 29, 2021 Popular Post Share Posted December 29, 2021 Braved the weather and got them diiiirrty 😁 15 Quote Link to comment Share on other sites More sharing options...
Popular Post tomr Posted December 29, 2021 Popular Post Share Posted December 29, 2021 Finished the R1 build 13 Quote Link to comment Share on other sites More sharing options...
Ant.p Posted December 29, 2021 Share Posted December 29, 2021 27 minutes ago, tomr said: Finished the R1 build Looks great! I’m still not sold on crawlers in general, but if (a big if!) I was to get one, these look to be most up my street. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted December 29, 2021 Popular Post Share Posted December 29, 2021 Finished the basic TRX4 Build 👍 10 Quote Link to comment Share on other sites More sharing options...
Popular Post UKRobster Posted December 29, 2021 Popular Post Share Posted December 29, 2021 Starting rebuilding my Granite after getting a load of new parts. Also serviced the diffs - was shocked to see how little oil was in there. Cleaned them out and replaced with 20k diff oil. I could tell the difference after doing the first one just from turning it by hand. Hopefully it will improve the handling. First image is the diff before - can you make out how little oil was in there? f This is re-filled - again difficult to see: Got the back end put back together on the new chasis: 6 Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted December 29, 2021 Share Posted December 29, 2021 Minor one but something Im hoping will make a difference. Had some slop in my Maxx steering link, so went with some Alloy Rod ends 3 Quote Link to comment Share on other sites More sharing options...
Popular Post BigGinge Posted December 29, 2021 Popular Post Share Posted December 29, 2021 Got the TRX4 trail van wired up and running (in the house). Still plenty to do to get it finished mind. 13 Quote Link to comment Share on other sites More sharing options...
supersavage Posted December 30, 2021 Share Posted December 30, 2021 Started thinking about keeping the TRX4 instead of selling it 🤔 1 Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted December 30, 2021 Popular Post Share Posted December 30, 2021 TRX4 ftw! 14 Quote Link to comment Share on other sites More sharing options...
turok007 Posted December 30, 2021 Share Posted December 30, 2021 On 29/12/2021 at 15:41, tomr said: Finished the R1 build Makes me what to get one of mine out of storage 2 Quote Link to comment Share on other sites More sharing options...
Redback Posted December 30, 2021 Share Posted December 30, 2021 (edited) Crashed the yeti into a tree, wasnt going fast, just a light bump on the front left tire and killed the servo 😠 first powerhd servo to pop, will be putting a servo saver on next time, hopefully gears from extronix servos will fit. My fault for showing off infront of parents going wow look at that to their 3 year olds 😛 Edited December 30, 2021 by Redback 1 1 3 Quote Link to comment Share on other sites More sharing options...
tomr Posted December 30, 2021 Share Posted December 30, 2021 39 minutes ago, turok007 said: Makes me what to get one of mine out of storage I wasn’t too sure about it when I bought it but now it’s built i love the way it looks 1 Quote Link to comment Share on other sites More sharing options...
Buggy Malone Posted December 30, 2021 Share Posted December 30, 2021 Repaired the Vantage today (slipper coupler replacement) so it should be good for its second run. The first run destroyed the spoiler so today I also made a protective wing to save the suspension housings. I used the following, lol: 1. A seat belt trim from an old car. 2. Sound deadening hard sponge from a campervan. 3. Two small car suspension bushes (one black, one yellow). 4. .......and bolted it all together. Looks OK TBH and should do a good job ......and it cost be nothing to make 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Shergar Posted December 31, 2021 Popular Post Share Posted December 31, 2021 Have been rejuvenating a SCX 10 for my daughter, Holmes motor, 1060, Power HD servo and some Traxxas wheels bought off the sales forum replacing the miss mash of rubbish fitted! Need to tidy the body next, but greased and tightened what was there first. Need taller shocks ( originals all gummed up within) but these will do for the moment. It’s a bit tight for height in here…. This is not a really useful box lid upside down 🤣 6 Quote Link to comment Share on other sites More sharing options...
Popular Post oodboo Posted December 31, 2021 Popular Post Share Posted December 31, 2021 Finally got round to building this one: 6 Quote Link to comment Share on other sites More sharing options...
Buggy Malone Posted December 31, 2021 Share Posted December 31, 2021 2 hours ago, oodboo said: Finally got round to building this one: There looks to be a nice collection going-on under that shelf - very smart 1 Quote Link to comment Share on other sites More sharing options...
supersavage Posted December 31, 2021 Share Posted December 31, 2021 Took the TRX4 out for a run and ran another tank through the Savage, it's starting to loosen up and get faster. One more tank and a bit more tunning and I'll be able to try and sort the gear change out providing I can find somewhere to take it. 3 Quote Link to comment Share on other sites More sharing options...
Popular Post 53HRA Posted December 31, 2021 Popular Post Share Posted December 31, 2021 Spent 6hrs on NYE stripping the man cave after opening the shed, only to discover layers of mould on the shelves. Now I understand why MDF is utter rubbish as it soaked up all the moisture. Off to the tip on Tuesday! 3 1 1 2 Quote Link to comment Share on other sites More sharing options...
Ant.p Posted December 31, 2021 Share Posted December 31, 2021 11 minutes ago, 53HRA said: Spent 6hrs on NYE stripping the man cave after opening the shed, only to discover layers of mould on the shelves. Now I understand why MDF is utter rubbish as it soaked up all the moisture. Off to the tip on Tuesday! It serves a purpose, but has its limitations! You can get moisture resistant MDF but WBP ply would be a better option if you plan to replace and is an unheated room. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Andy20xe Posted January 1, 2022 Popular Post Share Posted January 1, 2022 Got all the rpm parts fitted to the slash this morning, ( don't get a lie in with a 7 month old puppy !!) Also test fitted the drag body, should work well I think, just needs a little light trimming!! 7 Quote Link to comment Share on other sites More sharing options...
