Pistonhead Posted February 4, 2017 Share Posted February 4, 2017 Stared at it, put it in the car... ...started raining, got out the car and put a film on instead Quote Link to comment Share on other sites More sharing options...
Brandon Posted February 4, 2017 Share Posted February 4, 2017 33 minutes ago, cookie666uk said: is that a 3300mah floureon? ive got a couple 40c packs. one always requires a cycle on the charger after a bash to get it to balance properly... It's a floureon 4200mah that I charged up to 3.80 each cell so it must of been a week cell. I've also noticed mine don't hold there charge when I charge them the night before. Quote Link to comment Share on other sites More sharing options...
ProBlitz Posted February 4, 2017 Share Posted February 4, 2017 tried to drill the striped screw on the motor pinion with no success xD i think i will leave it there until the motor burns out xD Quote Link to comment Share on other sites More sharing options...
Brandon Posted February 4, 2017 Share Posted February 4, 2017 15 minutes ago, ProBlitz said: tried to drill the striped screw on the motor pinion with no success xD i think i will leave it there until the motor burns out xD Have you tried pulling the pinion off as hard as you can? Quote Link to comment Share on other sites More sharing options...
Wrighty8766 Posted February 4, 2017 Share Posted February 4, 2017 23 minutes ago, ProBlitz said: tried to drill the striped screw on the motor pinion with no success xD i think i will leave it there until the motor burns out xD Heat it up with a small blowtorch and pry the pinion off the shaft with a flat head screwdriver, that has worked for me in the past Quote Link to comment Share on other sites More sharing options...
ProBlitz Posted February 4, 2017 Share Posted February 4, 2017 12 minutes ago, Brandon said: Have you tried pulling the pinion off as hard as you can? yep but its not easy to work in it and i dont want to bent the motor can... 3 minutes ago, Wrighty8766 said: Heat it up with a small blowtorch and pry the pinion off the shaft with a flat head screwdriver, that has worked for me in the past i was kinda afraid to damage the motor with the heat. the worst part its where the screw is xD such a hard spot to work on, at least i managed to get the motor out of the gearbox now i can regrease the gears that was what i wanted to do... the pinion its still in good shape so i think it will stay in there until i the motor stops working but thanks a lot for the suggestions 1 Quote Link to comment Share on other sites More sharing options...
bieomax Posted February 4, 2017 Share Posted February 4, 2017 Fitted a 20t pinion to the outlawSent from my HTC One M8s using Tapatalk Quote Link to comment Share on other sites More sharing options...
cookie666uk Posted February 4, 2017 Share Posted February 4, 2017 1 hour ago, ProBlitz said: tried to drill the striped screw on the motor pinion with no success xD i think i will leave it there until the motor burns out xD use vaseline while drilling. and resist the urge to use full speed. when drilling hard things slow and steady wins the race... 1 hour ago, Brandon said: It's a floureon 4200mah that I charged up to 3.80 each cell so it must of been a week cell. I've also noticed mine don't hold there charge when I charge them the night before. mine are fine when it comes to holding a charge, they seem to hold for a few days Quote Link to comment Share on other sites More sharing options...
cookie666uk Posted February 5, 2017 Share Posted February 5, 2017 1 hour ago, ProBlitz said: tried to drill the striped screw on the motor pinion with no success xD i think i will leave it there until the motor burns out xD use vaseline while drilling. and resist the urge to use full speed. when drilling hard things slow and steady wins the race... 1 hour ago, Brandon said: It's a floureon 4200mah that I charged up to 3.80 each cell so it must of been a week cell. I've also noticed mine don't hold there charge when I charge them the night before. mine are fine when it comes to holding a charge, they seem to hold for a few days Quote Link to comment Share on other sites More sharing options...
t2boats Posted February 5, 2017 Share Posted February 5, 2017 Seen as my Outback has seen a lot of action in mud and deep water I thought it's best to give it a good clean and change the shock oil. So, fresh 30wt oil added to all shocks, greased inside the axles, bearings out and cleaned in wd40, and a general check of all screws around it - all still tight. Ready for its next testing time! Quote Link to comment Share on other sites More sharing options...
ChrisT Posted February 5, 2017 Share Posted February 5, 2017 Sprayed a wing for the Repsol. Quote Link to comment Share on other sites More sharing options...
stonedef Posted February 5, 2017 Share Posted February 5, 2017 Learnt a valuable lesson today. If bashing at a very wet, very muddy BMX track look whats the other side of big jumps. I went over one and couldn't see the truck land the other side, all I did see was the splash from the very big puddle that my truck landed in The truck ran for about another 5 mins and then stopped working. After that I decided to call it a day much to the disappointment of my son who was enjoying bashing his Bugsta in the mud. I have blown out as much water as I can, with the air gun, out of the electronics and they are now drying out in a bowl of rice. So time will tell if anything has died. But running the trucks in all that water and mud was probably the best 10 mins of rc I've ever had Quote Link to comment Share on other sites More sharing options...
Noj Posted February 5, 2017 Share Posted February 5, 2017 Thinking time about the 'rail, specifically a solution to a very exposed spur and pinion.... Quote Link to comment Share on other sites More sharing options...
froggy8 Posted February 5, 2017 Share Posted February 5, 2017 4 hours ago, t2boats said: Seen as my Outback has seen a lot of action in mud and deep water I thought it's best to give it a good clean and change the shock oil. So, fresh 30wt oil added to all shocks, greased inside the axles, bearings out and cleaned in wd40, and a general check of all screws around it - all still tight. Ready for its next testing time! didnt think you could wd40 the bearings, will you be lubricating them after? Quote Link to comment Share on other sites More sharing options...
stretch Posted February 5, 2017 Author Share Posted February 5, 2017 (edited) Wd40 isn't a lubricant, you need to use light machine oil or similar after if you have to use it. Edited February 5, 2017 by stretch Quote Link to comment Share on other sites More sharing options...
bombercountynick Posted February 5, 2017 Share Posted February 5, 2017 Opened bigfoot, put back in box, i'm afraid it's a shelf queen bigfoot by Nicholas Simpson, on Flickr 3 Quote Link to comment Share on other sites More sharing options...
froggy8 Posted February 5, 2017 Share Posted February 5, 2017 3 hours ago, stretch said: Wd40 isn't a lubricant, you need to use light machine oil or similar after if you have to use it. hi mate, yeah i know.i used wd40 first time and been told not to do that and that i had to lubricate it straight after. Quote Link to comment Share on other sites More sharing options...
stretch Posted February 5, 2017 Author Share Posted February 5, 2017 Ah I was trying to point it out to t2boats. I use motor or brake cleaner to clean then use machine oil to lubricate. 2 Quote Link to comment Share on other sites More sharing options...
Pistonhead Posted February 5, 2017 Share Posted February 5, 2017 (edited) Weather held today so i got the X2 out for a good play. Went from this: To this: A mate flipped it on an unsighted pothole, and i caught it on slowmo Edit: More video and pics to follow in my thread Edited February 5, 2017 by Pistonhead 1 Quote Link to comment Share on other sites More sharing options...
NOFX Posted February 5, 2017 Share Posted February 5, 2017 Made a skid plate for the axxe yesterday. Out of the knackered vaporizer. Just gotta put thick shock in the rear shocks & it's ready to go ? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted February 5, 2017 Share Posted February 5, 2017 2 lots of 8s through the Baja Flux, the AT clone tyres ain't wearing to well on-road tho Quote Link to comment Share on other sites More sharing options...
Wirralnitronoob Posted February 5, 2017 Share Posted February 5, 2017 crashed my wr8 and lost a rear dogbone,,so decided to take the eb4 buggy out,,what by the way kicks ass i love it,full of power and handles on the grass a dream,,but sadly on the drive back to my house the steering completely woundnt work,i walked towards it to inspect then smoke started coming from under the shell,,ive fried the servo lol,suppose it could have been worse like a lipo fire what i originally thought [emoji43]Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Wirralnitronoob Posted February 5, 2017 Share Posted February 5, 2017 oh and i changed the motor on my savage 5t from the toro 1650kv to the hobbywing 2200kv motor and wow what a diffrence so much more speed got a tad bored of playing with cars so took my cheapo drone out and was all good until a freak gust of wind from nowhere made me loose control and i crashed into thankfully my own house but smashing two props so ill need to order some new parts Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
