Wltoys 12402-a Posted May 16, 2021 Share Posted May 16, 2021 3 hours ago, Yrkoon said: i put some netting over the fan for the hyper 7 to stop stones and stuff getting in. went over the vse threadlocking screws and checking they were tight etc and stickered it up a bit. then i got the wing mount and wing from dads old trophy truggy as a stop gap, which should offer some protection to the back shock tower and i put nandas on it as the other tyres didnt hold up to well with yesterdays bashing 🙂 Try a dusty motor cover stops everything getting m8b 3 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted May 16, 2021 Share Posted May 16, 2021 Well fixed the H7 today Upon checking it earlier today i found that the screw had pulled out the bottom of steering knuckle and it seems it was a field repair many years ago lol where i had used a shorter screw it was only into the knuckle about 3 mm Sourced a better longer screw and its screwed in threadlocked and is solid for now 3 Quote Link to comment Share on other sites More sharing options...
Fuzzock Posted May 16, 2021 Share Posted May 16, 2021 3 hours ago, turok007 said: So was it stuck to the shaft or mount Stuck to the shaft. Not entirely sure how or why as of yet (Threadlock/rust?), but at least it is off. 🙂 Ian... 2 Quote Link to comment Share on other sites More sharing options...
Seminole81 Posted May 17, 2021 Share Posted May 17, 2021 Snapped the hex on the 1.5 driver on the pinion grub screw. That was fun to get out...changed to a metal spur gear and pinion on the XT, went for a 64T and 19T compared to the original of I think 48 and 13? It was stripped so it needed done. Went to replace front diff on the MT as I lost FWD on it. Pulled it apart, put 50k diff oil in it, replaced it, tested it. Still no FWD. Further investigation lead to rear diff being pulled off, noticed the centre drive shaft had a pin missing from the rear diff cup side and the rear diff cup was damaged (bent where the pin should have been). so replaced them both. Noticed the pinion gear was mega loose on the MT. Grub screw somehow managed it's way loose, so figured I'd pull it and replace the spur and pinion with the metal ones, same as the XT. No idea how the spur gear survived with the pinion literally moving up and down the motor freely. Whilst I was at that I pulled the rear diff and filled that with 30k oil. Stuck it all back together and boom! All working as intended. Noticed the MT had a bent shock, so pulled them all and decided to rebuild the shocks with thinner oil; 500 cSt. Currently sitting half assembled. Also going to order another set of Quantum Flux + springs, along with some additional pivot balls as I don't have any of those. Shocks might be a bit soft, so will adjust the spring rates on them until the new springs come. Then finally replaced the snapped body post mount on the MT as well. Just waiting till after work to finish rebuild the shocks and stick it all back together. Think the rear axles were ever-so-slightly bent, and had a few HD ones so stuck them on. Also I think one of the front axles is slightly bent as well so will replace them as I've got another set of HD ones. Going to throw another shim on the axles as well if I can. Also re-calibrated the ESC for the MT as it had lost reverse and only worked intermittently. That works fine now as well. Think that's everything. All-in-all, I was on it for about 4/5 hours...wife was not overly impressed as I didn't get into bed until 1:30 😄 2 1 Quote Link to comment Share on other sites More sharing options...
Popular Post James.S Posted May 17, 2021 Popular Post Share Posted May 17, 2021 Stickered up my new shell for the ZD truggy. Couple on the wing aswell Representin' 11 Quote Link to comment Share on other sites More sharing options...
Popular Post Seminole81 Posted May 17, 2021 Popular Post Share Posted May 17, 2021 11 minutes ago, James.S said: Stickered up my new shell for the ZD truggy. Couple on the wing aswell Representin' All them little dot stickers must of took you ages mate! 4 Quote Link to comment Share on other sites More sharing options...
Popular Post Yrkoon Posted May 17, 2021 Popular Post Share Posted May 17, 2021 done some work on the tt-01 🙂 changed a stripped spur gear noticed the diffs were nearly dry so greased them both up. just charging a battery now to test it out 🙂 7 Quote Link to comment Share on other sites More sharing options...
Popular Post Fly In My Soup Posted May 17, 2021 Popular Post Share Posted May 17, 2021 Not finished, but I couldn't resist a quick shakedown in a stream... 🌧️ 10 Quote Link to comment Share on other sites More sharing options...
Popular Post QRC Posted May 17, 2021 Popular Post Share Posted May 17, 2021 (edited) Final prep for the start of saloonstox at my local club tomorrow night, hopefully my numbers and racing name decals should show up tomorrow in time...only two more bodyshells to paint, long night ahead....🤣 Edited May 17, 2021 by QRC 10 2 Quote Link to comment Share on other sites More sharing options...
Yrkoon Posted May 17, 2021 Share Posted May 17, 2021 well i got a few minutes out of the new spur gear lol on further inspection the stupid tamiya pinion gear is pretty worn down, oops, time for another modelsport order 🙂 3 Quote Link to comment Share on other sites More sharing options...
Popular Post walkbythesea Posted May 17, 2021 Popular Post Share Posted May 17, 2021 I had previously swapped out the stock Reedy 15kg servo from my Sendero for a 25kg replacement, today I was putting the Reedy into my Tomahawk to get a 25kg servo back into stock for my Carisma Rangey project. To be honest this handled just the same with an Etronix 3kg servo, there’s no need for a big servo in such a diddy car but it’s what I have - since I built this in February I’ve swapped servos in it 4 times already for the sake of different projects 😂😂😂 6 1 Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted May 17, 2021 Popular Post Share Posted May 17, 2021 Fitted a set of Treal axles to the Ryft 9 Quote Link to comment Share on other sites More sharing options...
Popular Post walkbythesea Posted May 17, 2021 Popular Post Share Posted May 17, 2021 (edited) Replaced the broken hub knuckle on the Outlaw, got four wheels on my wagon again ✌️😎 Edited May 17, 2021 by walkbythesea 6 Quote Link to comment Share on other sites More sharing options...
Popular Post walkbythesea Posted May 17, 2021 Popular Post Share Posted May 17, 2021 (edited) Removed Krystals interior, found the original steering wheel jammed underneath the interior, drilled out the rivets that support the axles and off with the wheels 😃 Edited May 17, 2021 by walkbythesea 6 Quote Link to comment Share on other sites More sharing options...
Popular Post Hell horn. Posted May 17, 2021 Popular Post Share Posted May 17, 2021 Messed with the sporty again. Going to test it tomorrow and see what it can do. If anything. Lol 6 Quote Link to comment Share on other sites More sharing options...
Fuzzock Posted May 17, 2021 Share Posted May 17, 2021 Started to get the ST conversion to the end point by making the ESC mount (The holes are for the ESC)... Ian... 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Stephen shr Posted May 17, 2021 Popular Post Share Posted May 17, 2021 Put some hudryos on my contrast 8 Quote Link to comment Share on other sites More sharing options...
Popular Post Redback Posted May 18, 2021 Popular Post Share Posted May 18, 2021 (edited) Made a custom transmission from spare parts i had lying about for use in experiments & stuff, used a hyper 7 motor mount, with limitless spool and a hyper 7 center bearing holder left over from my nitro to brushless conversion. Then as always first victim the outlaw 😁 Edited May 18, 2021 by Redback 6 Quote Link to comment Share on other sites More sharing options...
Popular Post walkbythesea Posted May 18, 2021 Popular Post Share Posted May 18, 2021 (edited) First trial fit of the body… More detail in Krystals thread… Krystals latest updates Edited May 18, 2021 by walkbythesea 7 1 Quote Link to comment Share on other sites More sharing options...
chewbacca Posted May 18, 2021 Share Posted May 18, 2021 16 hours ago, .AJ. said: Fitted a set of Treal axles to the Ryft Wot no Vitavon ?? 🤔 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 18, 2021 Share Posted May 18, 2021 Na, I much prefer Treal stuff 😉 1 Quote Link to comment Share on other sites More sharing options...
Popular Post walkbythesea Posted May 18, 2021 Popular Post Share Posted May 18, 2021 Correct driveshafts now fitted, temporary body mounts, totally inappropriate absence of suspension that will actually hold up almost 6kg of model - but it’s sunny and time for a maiden drive! 3 4 Quote Link to comment Share on other sites More sharing options...
Popular Post Yrkoon Posted May 18, 2021 Popular Post Share Posted May 18, 2021 (edited) done some work on the hyper 7, after how bad i bent the rear shock tower and the replacement been on back order i thought id better reinforce it. bodge job time 🙂 took the plate that used to sit between the nitro engine and the chassis and dremmeled the center bit off so i was left with 2 nice strong bits. surprisingly they lined up perfect with the screw holes i was already using on the shock tower all finished and it is much stronger now with over long screws 🙂 might do something similar to the front one just thinking of what parts i can scrounge around the house lol Edited May 18, 2021 by Yrkoon 7 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Redback Posted May 18, 2021 Popular Post Share Posted May 18, 2021 1st transmission test was a failure very high motor and esc heat on 2s gearing was to high for this size of wheels i run, scavanged a diffrent spur off an old nitro monster truck, modifed the old mount to fit. Wouldnt take 11t pinion due to the massive spur so had to flip the motor mount and use the mounting screw at the bottom to lock the mount into position. This setup now doesn't overheat and drag break performs as it should holds the truck well enough, can go up to 4s if my dodgy mount can take it. 6 Quote Link to comment Share on other sites More sharing options...
Popular Post QRC Posted May 18, 2021 Popular Post Share Posted May 18, 2021 raced them....😆 6 Quote Link to comment Share on other sites More sharing options...
