Ross9999992 Posted March 20, 2023 Share Posted March 20, 2023 7 hours ago, totlxtc said: Cannot un-see HAHA I also see moustache but more along the lines of Chinese dragon 2 Quote Link to comment Share on other sites More sharing options...
Alex97 Posted March 20, 2023 Share Posted March 20, 2023 1 hour ago, Grogg said: I've now got the transmitter to bind with the receiver it came with fine, even got 4 wheel steering all setup, I was just hoping to use the Asbima receiver as it has an internal antenna, so I won't have to put a hole in the body for one, nor have one of those plastic tube sticking out of my RC car. I have tried putting the jump cable into channel 4 to see if that would put the receiver into binding mode, but that doesn't do anything, and it turns out the link they sent me doesn't doesn't work, ot requires a password to view, witch they didn't give That RX is the wrong protocol and will not work with a GT5! You don't need to put a hole through the body, hide the ariel with the servo and ESC receiver wires (don't wrap it too tight as it is a coax cable) Quote Link to comment Share on other sites More sharing options...
totlxtc Posted March 20, 2023 Share Posted March 20, 2023 1 hour ago, Ross9999992 said: HAHA I also see moustache but more along the lines of Chinese dragon Yes!! Thats perfect! 🤣🤣🤣 Quote Link to comment Share on other sites More sharing options...
Rustic Ade Posted March 20, 2023 Share Posted March 20, 2023 9 hours ago, MrCake said: A day off so finally got to test the Big Rock with the Typhon shocks, and new CNHL 8000mah battery. Very impressed with both items and unsurprisingly the run time was ages! How much difference do the bigger shocks make? Quote Link to comment Share on other sites More sharing options...
MrCake Posted March 21, 2023 Share Posted March 21, 2023 I dont go mad with jumps but it all just seems more plush. when it comes to landing and that is without me adjusting them yet Yes, I could have probably tweaked the stock ones but fancied an upgrade even if the price is a bitter pill. Quote Link to comment Share on other sites More sharing options...
Rustic Ade Posted March 21, 2023 Share Posted March 21, 2023 5 hours ago, MrCake said: I dont go mad with jumps but it all just seems more plush. when it comes to landing and that is without me adjusting them yet Yes, I could have probably tweaked the stock ones but fancied an upgrade even if the price is a bitter pill. Nowt wrong with treating yourself! Did you consider any other shocks for it? I don't go mad for jumps but do find mine bottoms out at the front end. Think better shocks are the answer over thicker oil or more spacers but I do have to consider budget. Either that or I need to vastly improve my return to earth skills! Quote Link to comment Share on other sites More sharing options...
totlxtc Posted March 21, 2023 Share Posted March 21, 2023 12 minutes ago, Rustic Ade said: Nowt wrong with treating yourself! Did you consider any other shocks for it? I don't go mad for jumps but do find mine bottoms out at the front end. Think better shocks are the answer over thicker oil or more spacers but I do have to consider budget. Either that or I need to vastly improve my return to earth skills! Stiffer springs along with shims? 1 Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted March 21, 2023 Share Posted March 21, 2023 Found out that the motor on my baja was junk more money to spend 🙄 2 Quote Link to comment Share on other sites More sharing options...
MrCake Posted March 21, 2023 Share Posted March 21, 2023 (edited) 5 hours ago, Rustic Ade said: Nowt wrong with treating yourself! Did you consider any other shocks for it? I don't go mad for jumps but do find mine bottoms out at the front end. Think better shocks are the answer over thicker oil or more spacers but I do have to consider budget. Either that or I need to vastly improve my return to earth skills! My research consisted of reading this thread https://www.arrmaforum.com/threads/arrma-granite-senton-typhon-big-rock-crew-cab-and-vorteks-shock-upgrade.42570/ and I went for what was basically the easiest if not probably most expensive option. These shocks sadly haven't helped my skills 🤣 Edited March 21, 2023 by MrCake duff link 1 Quote Link to comment Share on other sites More sharing options...
Rustic Ade Posted March 22, 2023 Share Posted March 22, 2023 22 hours ago, totlxtc said: Stiffer springs along with shims? I can measure spring dimensions but how do you quantify the stiffness of what I have against what I need? Quote Link to comment Share on other sites More sharing options...
Rustic Ade Posted March 22, 2023 Share Posted March 22, 2023 17 hours ago, MrCake said: My research consisted of reading this thread https://www.arrmaforum.com/threads/arrma-granite-senton-typhon-big-rock-crew-cab-and-vorteks-shock-upgrade.42570/ and I went for what was basically the easiest if not probably most expensive option. These shocks sadly haven't helped my skills 🤣 I'll have a look at that. Quote Link to comment Share on other sites More sharing options...
totlxtc Posted March 22, 2023 Share Posted March 22, 2023 2 hours ago, Rustic Ade said: I can measure spring dimensions but how do you quantify the stiffness of what I have against what I need? Well you say you are bottoming out on the front. By adding stiffer springs you will increase the spring rate. This will mean you need more force to compress the springs meaning less chance of bottoming out. By adding a bump stop then this will limit the travel of the shock meaning it will cushion the hit rather than the body of the shock, also limiting the bottoming out. Quote Link to comment Share on other sites More sharing options...
Popular Post Lone-wolf Posted March 22, 2023 Popular Post Share Posted March 22, 2023 Fitted custom plates to the sca-1e van 4 Quote Link to comment Share on other sites More sharing options...
Popular Post SXFoxstar Posted March 22, 2023 Popular Post Share Posted March 22, 2023 Following everyone’s advice over the past couple of weeks I had this lovely package arrive today! Thanks again for all of your help! I’ve already started to switch the Tamiya connectors out. My soldering needs some practise, it’s been a while! 6 Quote Link to comment Share on other sites More sharing options...
Rustic Ade Posted March 22, 2023 Share Posted March 22, 2023 3 hours ago, totlxtc said: Well you say you are bottoming out on the front. By adding stiffer springs you will increase the spring rate. This will mean you need more force to compress the springs meaning less chance of bottoming out. By adding a bump stop then this will limit the travel of the shock meaning it will cushion the hit rather than the body of the shock, also limiting the bottoming out. Sorry, didn't explain what I meant. If I look to replace the springs for stiffer ones, how do I know what mine are rated at so I can look for stiffer ones. Could I use a short length of small silicone tube on the shock shaft as a bump stop? Quote Link to comment Share on other sites More sharing options...
totlxtc Posted March 22, 2023 Share Posted March 22, 2023 1 hour ago, Rustic Ade said: Sorry, didn't explain what I meant. If I look to replace the springs for stiffer ones, how do I know what mine are rated at so I can look for stiffer ones. Could I use a short length of small silicone tube on the shock shaft as a bump stop? Now I cant tell you about how to get other springs as im not so familiar with the model as others might be. Silicon tube or nitro fuel tube will do the job. Plenty of vids out there explaining how to 👍 1 Quote Link to comment Share on other sites More sharing options...
totlxtc Posted March 22, 2023 Share Posted March 22, 2023 2 hours ago, SXFoxstar said: Following everyone’s advice over the past couple of weeks I had this lovely package arrive today! Thanks again for all of your help! I’ve already started to switch the Tamiya connectors out. My soldering needs some practise, it’s been a while! Ohhhhhh we were joking! You dont want to buy that junk!!! Joking! Nice haul. Have fun 👍👍 2 Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted March 22, 2023 Share Posted March 22, 2023 Got the front end of the baja cleaned and rebuilt now on to the rear to do and wait for the new engine and fuel tank to arrive 👍 2 Quote Link to comment Share on other sites More sharing options...
Popular Post totlxtc Posted March 24, 2023 Popular Post Share Posted March 24, 2023 Houston we have lift off! Flysky RX in and working a treat! All telemetry coming through loud and clear 🙂 4 Quote Link to comment Share on other sites More sharing options...
Rustic Ade Posted March 24, 2023 Share Posted March 24, 2023 1 hour ago, totlxtc said: Houston we have lift off! Flysky RX in and working a treat! All telemetry coming through loud and clear 🙂 Inspired, going to sort mine out this weekend. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Shergar Posted March 24, 2023 Popular Post Share Posted March 24, 2023 Broke a front cvd on my wagon within 2 minutes tonight! E or C clip has escaped/broke and locked the driveline up… I did take this pretty picture though 😁 5 Quote Link to comment Share on other sites More sharing options...
Popular Post Kpowell911 Posted March 25, 2023 Popular Post Share Posted March 25, 2023 Time for a little test. Last week, I took a bone stock TL-01, with 27mhz radio, MSC, a Stock Silver Can 540 and a 7.2v NIMH to 13mph. Today, we have a TL-01 with: Bearings Speed Tuned Gears 2.4ghz Radio Hobbywing 1060 ESC Tamiya BZ Superstock 23t Motor 2S 7.4v Lipo With the exception of the lipo/2.4ghz, this was a sort of achievable set up for 12 year old me in 1999. The new TL-01 also has other mods, but not that will necessarily affect TOP SPEED. Ive also glued Rally Block tyres with inserts. We shall see 4 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted March 25, 2023 Share Posted March 25, 2023 I await with bated breath will it be faster than 13mph 2 Quote Link to comment Share on other sites More sharing options...
totlxtc Posted March 25, 2023 Share Posted March 25, 2023 14mph 😜 3 Quote Link to comment Share on other sites More sharing options...
Popular Post Kpowell911 Posted March 25, 2023 Popular Post Share Posted March 25, 2023 So, decided to take another 2 RCs out with the TL-01. The Traxxas Rally because I intended going to a car park type area, and the XRT just because Ive only used it twice and the Mrs will soon start asking why I spent £1700 on it…… However, what we really went out for was to test the TL-01. Truth be told it was uncontrollable, and drifty, but even so, I managed 22mph. I reckon theres more in it, potentially enough to double the stock MSC powered TL-01, which is pretty incredible for whats effectively £70ish of parts. I do have an idea of how to get a bit more out of it mind. Then I tool the Rally out, seemed rude not to throw on the GPS whilst I had it, so that got a run. Quite happy with that, theres obviously a lot more there but I didnt have much room. I also had a play with the TSM which was very successful. TSM is basically a posh gyro, but it did really help. Im tempted to put the Traxxas TSM Radio in the TL-01 and see if TSM can help me hit 26mph. The XRT was the XRT. Out of its comfort zone really on an industrial estate road, but goos fun none the less. No breakages so just a bit of clean up and lipo care now 5 Quote Link to comment Share on other sites More sharing options...
