Nick Posted March 14, 2023 Share Posted March 14, 2023 A PERFORMANCE RIG BUILT TO ENDURE. When hitting the trail, you want to do it with confidence -- and the answer is the Enduro Sendero HD Titanium Trail Truck!At the heart of the Enduro is our revolutionary StealthR X gearbox. Although the exterior appears to have a conventional 3-gear transmission look, the inside is far from conventional. The StealthR X features the ability to adjust the rear drive ratio independently of the front drive across three levels: stock overdrives the front end 5.7% (installed in RTR), option 1 provides a one-to-one drive ratio front-to-rear (available separately), and option 2 overdrives the front end 11.83% (included with RTR).Feeding the power to the tires are 3-piece telescopic driveshafts with an extruded aluminum center section, universal front drive axles, and hardened steel ring and pinion gears. With the Enduro drivetrain, delivering useful power will not be an issue.We relocated the steering link assembly from the conventional location to behind the axle (BTA). This feature greatly improves approach angle and front-end clearance, making rough terrain much easier to handle.The Enduro Trail Truck with Sendero body comes ready for adventure right out of the box, with performance-driven Reedy Power electronics. The ultra-smooth and powerful 16-turn, 5-slot brushed crawler motor and Reedy Power SC480X electronic speed controller with T-plug connector supply ample power to this tough rig. Controlling the beast on the trail is our 3-channel XP130 2.4GHz radio and Reedy Power high-torque 1320MG metal-gear servo.With all this packed in one box, we know the Enduro Trail Truck is ready for the trail -- are you?The #40120 Combo includes a Reedy Compact Balance Charger and Reedy 7.4V LiPo Battery with T-plug.Sendero HD Titanium Features Reedy Power SC480X electronic speed controller NEW Reedy Power high-torque 1523MG metal gear servo Steel servo horn Adjustable width rock sliders New box diorama Sendero HD high-strength polycarbonate body with NEW color, a cab-only design with molded utility bed Ocho beadlock wheels Adjustable front injection-molded bumper Updated plastics Chassis FeaturesBTA STEERING and ALUMINUM STEERING PLATES: Behind-the-axle steering provides better approach angles, more clearance, and a cleaner look. Bolt-on aluminum steering plates allow for more adjustment, strength, and future modification for the user.INTEGRATED SERVO WINCH MOUNT: Mounting a winch directly to the chassis is the strongest and most reliable spot on any trail rig. Positioned alongside the steering servo for overall chassis balance and weight distribution.THREADED ALUMINUM SHOCK BODIES: Threaded aluminum and fluid-filled, these shocks keep the vehicle stable on the trail and retain oil even in the roughest terrain.REEDY POWER CRAWLER MOTOR: The Reedy Power 5-slot 16-turn brushed crawler motor provides ample torque with a smooth power delivery. This allows for slow precise acceleration while maintaining consistent power over rough terrain and obstacles.REEDY POWER ELECTRONIC SPEED CONTROLLER (ESC): The water resistant SC480X brushed ESC is specifically programmed for crawling with proportional forward/reverse, dual auxiliary power output leads, LiPo low-voltage cutoff protections, and T-plug connector.RADIO and SERVO: The XP130, 2.4GHz, 3-channel radio, and receiver, together with a 1320MG (metal gear) water-resistant servo pushing out 173 oz-in (12.5kg-cm) of torque at 6V is the perfect setup for keeping the Enduro under control on the trail.STEALTHR X GEARBOX WITH ADJUSTABLE OVERDRIVE GEARS: At the heart of the Enduro is our revolutionary StealthR X gearbox. Although the exterior appears to have a conventional 3-gear transmission look, the inside is far from conventional. The StealthR X features the ability to adjust the rear drive ratio independently of the front drive across three levels: stock overdrives the front end 5.7% (installed in RTR), option 1 provides a one-to-one drive ratio front-to-rear (available separately), and option 2 overdrives the front end 11.83% (included with RTR).Body FeaturesALL IN THE DETAILS. No trail truck would be complete without a detailed and realistic looking body. The Sendero HD Titanium Trail Truck is just that with inspired styling from the 1980s and 1990s American pick-up trucks.The Sendero HD Titanium comes equipped with a high-strength polycarbonate body in NEW color that has been pre-painted to look fresh off the showroom floor. The Sendero HD was designed for both looks and function, featuring a cab-only design with molded utility bed for cargo, injection-molded compact bumper, windshield wipers, folding mirrors, updated sliders, and front grill with working LEDs.The Sendero HD's pivoting side mirror design reduces the risk of losing mirrors while on the trail. The updated sliders cradle the body to protect it when crawling over rocks. Drive your rig with confidence knowing it can handle navigating through tight technical rock features.Out of the box, the Sendero HD Titanium Trail Truck is ready to tackle the elements -- your journey begins here!OFFICIALLY LICENSED WHEELS AND TIRES: Gripping the trail is a set of officially licensed General GrabberTM X3 tires molded in a high-performance, soft compound rubber. The General GrabberTM X3 tires are mounted on Ocho beadlock wheels. No more worrying if your RTR tires will come unglued.Sendero HD Body Features Cab-only design featuring injection-molded utility bed Sendero body thermoformed in high-strength polycarbonate in NEW color Clear windows Molded grill Replaceable headlight lenses Pivoting side mirrors LED headlights Adjustable front injection-molded bumper Removable injection-molded fairlead Realistic styling Injection-molded utility bed Licensed 1.9"x4.65" General Grabber> X3 tires View full news article 3 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted March 14, 2023 Share Posted March 14, 2023 looks nice in this colour, i guess its same as the older red one , same spec 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted March 14, 2023 Share Posted March 14, 2023 it does look pretty smart Quote Link to comment Share on other sites More sharing options...
Rustic Ade Posted March 14, 2023 Share Posted March 14, 2023 Didn't need to see that, I'm becoming an RC magpie and was thinking about a larger crawler, although mine is only teeny, it is great, and I don't need a bigger one! Also need to learn what I'm doing with the tech side of things. But it does look good...🤔 2 Quote Link to comment Share on other sites More sharing options...
BashingBrian Posted March 14, 2023 Share Posted March 14, 2023 Visible body pins and no interior, seriously it's 2023..!! Come on Element sort it out..🤨 2 Quote Link to comment Share on other sites More sharing options...
PraetoR Posted March 14, 2023 Share Posted March 14, 2023 I like it 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 15, 2023 Share Posted March 15, 2023 10 hours ago, BashingBrian said: Visible body pins and no interior, seriously it's 2023..!! Come on Element sort it out..🤨 My first thought as well Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted March 15, 2023 Share Posted March 15, 2023 Tooo be fair, while i agree that it's a bit 2000ish, it's also comparatively cheap for the amount of crawler you get. The closest would probably be the TRX4 Sport at almost £100 more. This rig is built to a price, and i can see why they do it. I kind of even agree with it, makes it easy to recommend to people who want to dab their toe into crawlers - great rig, great price, at the cost of an interior and a well designed mounting system. I don't even mind the body posts, i'll be honest. At the end of the day this is supposed to be a capable trail/crawler rig, not a scaler. Better to save money with posts/interior than at the gearbox for example. Pointing out missing features without acknowledging the price isn't quite fair to the rig. 1 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted March 15, 2023 Share Posted March 15, 2023 1 hour ago, m4inbrain said: Tooo be fair, while i agree that it's a bit 2000ish, it's also comparatively cheap for the amount of crawler you get. The closest would probably be the TRX4 Sport at almost £100 more. This rig is built to a price, and i can see why they do it. I kind of even agree with it, makes it easy to recommend to people who want to dab their toe into crawlers - great rig, great price, at the cost of an interior and a well designed mounting system. I don't even mind the body posts, i'll be honest. At the end of the day this is supposed to be a capable trail/crawler rig, not a scaler. Better to save money with posts/interior than at the gearbox for example. Pointing out missing features without acknowledging the price isn't quite fair to the rig. I agree these are a pretty good rig, can add an interior for more scale, think it takes a cheap Led light set as well but so we know the price 1 Quote Link to comment Share on other sites More sharing options...
BashingBrian Posted March 15, 2023 Share Posted March 15, 2023 10 hours ago, m4inbrain said: Pointing out missing features without acknowledging the price isn't quite fair to the rig. What is the price?? I don't see a price in this post... Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted March 15, 2023 Share Posted March 15, 2023 (edited) 2 hours ago, BashingBrian said: What is the price?? I don't see a price in this post... The only thing that changed is the colour. £339 for the red one, make it £345 for the new colour. TRX Sport (closest comparable rig in quality) is £419, also doesn't have an interior as well as uses body posts, same for the AT-4 Emo at £459. edit: i wouldn't know any sub-£400 rigs that sport an interior and hidden bodyposts/magnets or clips. Closest one would probably be my Sherpa, and while i like it, it's nowhere near as capable or quality as a Sendero. Also £419. Edited March 15, 2023 by m4inbrain Quote Link to comment Share on other sites More sharing options...
BashingBrian Posted March 16, 2023 Share Posted March 16, 2023 Well I just looked and it's currently $389.99 at Amain, so I think we'll be lucky if this is sub £400 when it hits the UK..!!! Here's hoping 😉😂 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted March 16, 2023 Share Posted March 16, 2023 3 hours ago, BashingBrian said: Well I just looked and it's currently $389.99 at Amain, so I think we'll be lucky if this is sub £400 when it hits the UK..!!! Here's hoping 😉😂 Means it's $14 more than the red ($375) one which is £339 here. Truth to be told, i can't really see why it's even $14 more since it's just a new colour, but it'll probably be £349 here. Which is still a good price for a decent rig. Assuming they use the same conversion/pricing as they did for the red one. I'd be surprised if it's close to £400, though wouldn't be the first time we see conversion shennanigans. 1 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted March 16, 2023 Share Posted March 16, 2023 5 hours ago, m4inbrain said: Means it's $14 more than the red ($375) one which is £339 here. Truth to be told, i can't really see why it's even $14 more since it's just a new colour, but it'll probably be £349 here. Which is still a good price for a decent rig. Assuming they use the same conversion/pricing as they did for the red one. I'd be surprised if it's close to £400, though wouldn't be the first time we see conversion shennanigans. Based on the Ecto, when they launched the green one it was £40 dearer than the yellow, so i would not be surprised if it retails at £389 Quote Link to comment Share on other sites More sharing options...
m4inbrain Posted March 16, 2023 Share Posted March 16, 2023 2 minutes ago, Lone-wolf said: Based on the Ecto, when they launched the green one it was £40 dearer than the yellow, so i would not be surprised if it retails at £389 Meh, it's still a reasonable deal at £389, but at that price i'd probably go for a TRX4 Sport. £40 for a paintjob, pff. 1 Quote Link to comment Share on other sites More sharing options...
BashingBrian Posted March 17, 2023 Share Posted March 17, 2023 So, it turns out that it's price in the UK is £369..!!👍 1 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted March 17, 2023 Share Posted March 17, 2023 52 minutes ago, BashingBrian said: So, it turns out that it's price in the UK is £369..!!👍 Are you gonna get one? 1 Quote Link to comment Share on other sites More sharing options...
BashingBrian Posted March 18, 2023 Share Posted March 18, 2023 3 hours ago, Lone-wolf said: Are you gonna get one? Nah, got too many projects on the go atm 😂 1 Quote Link to comment Share on other sites More sharing options...
BashingBrian Posted March 19, 2023 Share Posted March 19, 2023 Been reading more about this rig, can someone please explain to me the differences between the red one and this new one.?? I can't figure out what's different 😂 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted March 26, 2023 Share Posted March 26, 2023 On 19/03/2023 at 20:20, BashingBrian said: Been reading more about this rig, can someone please explain to me the differences between the red one and this new one.?? I can't figure out what's different 😂 I think its just colour and price 1 Quote Link to comment Share on other sites More sharing options...
