Jimplops Posted November 23, 2020 Share Posted November 23, 2020 14 minutes ago, .AJ. said: No problem, I’ll sort some pics in a while 👍 Cheers much appreciated 👍👍 Quote Link to comment Share on other sites More sharing options...
Paulnb57 Posted December 3, 2020 Share Posted December 3, 2020 (edited) @.AJ. Terrible photo from your video! Can I ask what the steering doohickey behind the wheel in the photo is called please? and of poss a link to where I can get one? Thanks! Cracking build! Edited December 3, 2020 by Paulnb57 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 3, 2020 Author Share Posted December 3, 2020 26 minutes ago, Paulnb57 said: @.AJ. Terrible photo from your video! Can I ask what the steering doohickey behind the wheel in the photo is called please? and of poss a link to where I can get one? Thanks! Cracking build! Hi this is the part, it’s used on Tamiya Truck https://www.ebay.com/itm/Xtra-Speed-Aluminum-Steering-Shaft-Set-1-14-Tamiya-Tractor-Trucks-Car-XS-15443/142401964391?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 3, 2020 Author Share Posted December 3, 2020 On 23/11/2020 at 14:52, Jimplops said: Cheers much appreciated 👍👍 Sorry for the late reply And the wheel it mounted as per normal, then I’ve used a washer to get the correct tension when the wheel up is done up tight, so it still spins freely 👍 Quote Link to comment Share on other sites More sharing options...
Jimplops Posted December 3, 2020 Share Posted December 3, 2020 Cheers pal 👍👍 1 Quote Link to comment Share on other sites More sharing options...
Paulnb57 Posted December 3, 2020 Share Posted December 3, 2020 22 minutes ago, .AJ. said: Hi this is the part, it’s used on Tamiya Truck https://www.ebay.com/itm/Xtra-Speed-Aluminum-Steering-Shaft-Set-1-14-Tamiya-Tractor-Trucks-Car-XS-15443/142401964391?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Thanks! Ordered! I need to mount an axle too far forward for a chassis mounted servo to be near it, this should work a treat...back to the scheduled programme!.... 1 Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted January 13, 2021 Author Popular Post Share Posted January 13, 2021 Started on the exhaust 8 Quote Link to comment Share on other sites More sharing options...
Alex97 Posted January 13, 2021 Share Posted January 13, 2021 On 03/12/2020 at 15:06, .AJ. said: Sorry for the late reply And the wheel it mounted as per normal, then I’ve used a washer to get the correct tension when the wheel up is done up tight, so it still spins freely 👍 what DIA is that shaft and do you have a part number for the 12mm hex bearing housing? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted January 13, 2021 Author Share Posted January 13, 2021 3 minutes ago, Alex97 said: what DIA is that shaft and do you have a part number for the 12mm hex bearing housing? 5mm shaft and these are the hubs 👍 1 Quote Link to comment Share on other sites More sharing options...
Alex97 Posted January 13, 2021 Share Posted January 13, 2021 Just now, .AJ. said: 5mm shaft and these are the hubs 👍 i knew you'd only go for Sophisticated parts 🤣 cheers 1 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted January 13, 2021 Author Share Posted January 13, 2021 I think Tamiya make a version, but they are 3 times the price lol 1 Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted January 13, 2021 Author Popular Post Share Posted January 13, 2021 Blimey, 25 years being a plumber has finally become useful 🤣🤣🤣🤣 4 3 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted January 13, 2021 Share Posted January 13, 2021 Coming on nicely mate 1 Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted January 13, 2021 Share Posted January 13, 2021 Very cool man! Are you going to merge the pipes, or just having them brap brap brapping away? 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted January 13, 2021 Author Share Posted January 13, 2021 Think ill leave them as they are 👍 1 Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted January 15, 2021 Author Popular Post Share Posted January 15, 2021 Chopped the rear bed out of the body 4 1 Quote Link to comment Share on other sites More sharing options...
Mack1 Posted January 15, 2021 Share Posted January 15, 2021 Gotta love those pipes. Well cool 😎.👍 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted January 15, 2021 Share Posted January 15, 2021 Whats the capacity of the fuel tank ? really liking how its coming together mate 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted January 15, 2021 Author Share Posted January 15, 2021 Think it’s 125ml, they did make a larger one but I thought this one was a better size scale wise 👍 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted January 15, 2021 Share Posted January 15, 2021 Looks pretty scale 1 Quote Link to comment Share on other sites More sharing options...
igor1960 Posted March 15, 2021 Share Posted March 15, 2021 Impressed by all yours work. Have couple of questions about this engine: 1. Could someone test if this engine will run just on 1 cylinder: meaning what if 1 spark is not powered and gas line disconnected; 2. As it has 2 carburetors, when less power is needed: Is it possible to just close gas line on one of carburetors -- would engine run on 1 cylinder with no or very little load? 3. What is the temperature of an exhaust mixture, did anyone measured it? Thanx, Igor Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 15, 2021 Author Share Posted March 15, 2021 Sorry I’ve not even fired up my engine yet Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted June 14, 2021 Author Popular Post Share Posted June 14, 2021 Time to crack on with build! Next job is make up a the mount for the steering servo, start to fab a rear bed out of poly card and get the fuel tank mounted 👌 4 Quote Link to comment Share on other sites More sharing options...
walkbythesea Posted June 15, 2021 Share Posted June 15, 2021 This is absolutely outstanding 🤘😎 1 Quote Link to comment Share on other sites More sharing options...
