FTX Mauler Rock Crawler Owners Thread
johninderby
Hi All,
Newb from Oxfordshire here. Got one of these wee beasties for chrimbo, not had much play time yet but have already made a few tweaks. It coincidentally happened to come with a TGY1501 servo and a couple of 4000mah 2s lipos ;). I've also removed the body hinge and pushed the bumper in further to improve the approach angle.
You can just see in this shot the original holes in the bumper mounting bar have pretty much been pushed through the bumper mount this has moved the bumper back about 6mm
The body had to be trimmed a touch to clear the bumper
New bumper postion from above
Hi All,
Am a newb from suffolk and its been about 20yrs since I have had rc cars. My wife bought me a mauler for Christmas and my question is can you run lipo batteries using the stock esc as there are pins marked NIMH or LIPO on it.  I see Ollie you are running lipos and they came as stock , mine came with a 2000 MAH NI-MH battery.If so is much advantage running lipos or just go for a 4000 / 5000 MAH battery . Have found the mauler quite capable. Thanks in advance for your advice.
11 hours ago, Stumpy65 said:
Hi All,
Yes you just swap the jumper to run lipos.
Mine also came with the NiMH stock, I just ordered the lipos at the same time. The advantages of the lipos are power density and current delivery, I have some 2700mah lipos for another car that are much smaller and lighter than the 2000mah NiMH.
With the 4000mah lipos I have I reckon you'd probably get around an hours runtime, I was out for 40mins and the battery was still 7.2v (6.6v low voltage cutoff)
In this particular car I'm not sure how much of an advantage lipo will give in terms of outright performance as it's geared so low the motor doesn't really have to struggle at all even on quite steep inclines so burst current draw is going to be quite low. You could use a similar capacity lipo to the stock battery and gain some weight reduction. Lipos do have their advantages over NiMH and I'm already set up for lipos so buying more lipos over NiMH was a no brainer for me.
1 hour ago, just rolling said:
great vid, thought it was gone for a moment into the ice, i run 2s lipos in mine, snowing here at the moment so might just have to head out there with some rcs
Thanks, the puddle was only ankle deep but I did hold my breath when it went in the drink. Just shows how capable this thing is, if that was one of my bashers it wouldn't have climbed back out.
1 hour ago, Stumpy65 said:
Thanks that's a big help . What current draw lipos do I go for thanks and do I need a fail safe.
To work out the max available current from a lipo you need to multiply the mah by the C rating and then divide by 1000 to go from milliamps to amps
Mine for example are
4000mah X 30c /1000 = 120amps
2700mah X 30c /1000 = 81 amps.
A typical brushed 540 will draw around 10a or less, the higher the turn count the lower the current draw. Low gearing will also give lower current draw.
Based on my estimated runtime of an hour from a 4000mah battery (most of that at wide open throttle) the average current draw will be 4 amps with the max maybe 6-7 amps.
Finally getting round to fitting the 1/8th scale Ford F-150 Supercab body to the Mauler. Made up new carbon fibre links to lengthen the wheelbase to 360mm so that the tyres will fit the body properly. Body is just roughly trimmed out at the moment and will have to sort out the body mount posts.
Think the body suits the Mauler rather nicely.  :thumbsup:  BTW Axial Ax10 axles have been fitted.
            John
4_A098207-_C17_A-4_A9_A-_ADF0-3_CCF907_F
90_EF95_B6-790_E-459_D-8235-771_E11_AA01
            John
good work John, what colour you going for? i got a few trucks running that shell all done metalic blue kinda like a old bigfoot colour
Hi All,
I intend to get one of these ordered this week and finding this thread very helpful , so thank you to those posting the info , especially any mod photos
and product links.
So I`ve got a few questions to those who already have the FTX Mauler.
Straight off I`ll get the suggested servo fitted, but similar models seem to need metal lockers ( such as hsp 180009 ) and talk of a need to grease the gears so any update on this would be appreciated.
Finally I like almost everything about the Mauler but I can`t live with that body shell paint job...whilst I wait to buy a pickup shell sometime in the future ( and not get a clear Mauler shell ) I intend to overspray with a gloss/Metallic black and re sticker...any thoughts or suggestions would be appreciated.
regards
Kev T
21 hours ago, Kev T said:
Hi All,
and product links.
regards
Kev T
I got the orange one, the shell actually is not as bad in the flesh, still running mine all stock except xt60 connectors and 2s lipo
Just received the Orange version this morning....wouldn`t mind seeing a few photos of your body mount upgrade and new shell...also any one who has changed their servo , how would you advise I should go about the electrics..?
1 hour ago, johninderby said:
Servo change is a must. Stock servo is incredibly slow and limited range of travel . This inexpensive servo is so much better.
https://www.ebay.co.uk/itm/Turnigy-PowerHD-1501MG-High-Torque-Servo-17kg-cm-0-14s-Waterproof-Metal-Gear/321583502346?epid=14012123154&hash=item4adfded40a:g:2u4AAOSwOTVZptCB
      John
Hi John,
Thanks, and I intend to get the servo you recommend...however for now I'm keeping the stock esc but looking at the wiring its not totally straight forward for a novice like myself.
There is no unplug one and plug in another...I'm looking for ideas on best way to connect up .?
Actually it is a simple as just plugging in a new ESC and a new receiver. You will however need to get a new radio system or you can get the separate FTX receiver and use it with a separate ESC.
ESC
https://www.modelsport.co.uk/hobbywing-quicrun-1060-brushed-waterproof-esc-sbec/rc-car-products/404964
Receiver
http://ftx-rc.com/ftx-mauler-optional-receiver-for-separate-esc-use-not-2in?search=Mauler&page=4
or
https://www.modelsport.co.uk/ftx-mauler-optional-receiver-for-seperate-esc-use-not-2-in1-/rc-car-products/422676
        John
ESC
Receiver
or
        John
Thanks again John,
But you misunderstood me...I'm keeping my existing esc etc for now...which leaves me wondering the best way to connect a new servo as existing servo wiring seems to lack an easy unplug option
8 minutes ago, johninderby said:
Replacement servo just plugs straight into the servo plug lead on esc/RX unit same as the stock servo.
45_CF68_FA-9656-40_FB-864_F-89_E6_DE0_FF
4_F577_BA2-7705-4889-_B853-1_CC4864_C830
Right...thats excellent...at a glance I didn't think that would be possible.
Really appreciate your help...will get that servo ordered tonight.
As John says it's plug 'n' play. Once you cut the cable ties off you'll see where the stock servo is plugged in. I'm still running the stock ESC/Rx combo and the servo swap is definitely a worthwhile upgrade.
Thanks Ollie,
I'll be doing your front bumper mod as well.
