wolfie1 Posted April 23, 2023 Share Posted April 23, 2023 24 minutes ago, Stormbringer said: not really the higher the kv the faster the motor but less torque the lower the kv the lower speed but more torque Ok thanks that makes sense, so is a 2800kv ok for a rock crawler? Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted April 23, 2023 Share Posted April 23, 2023 going by other folks posts etc it would seem around the 2800kv is ok , no experiance of it myself in crawlers yet Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 23, 2023 Share Posted April 23, 2023 Just now, Stormbringer said: going by other folks posts etc it would seem around the 2800kv is ok , no experiance of it myself in crawlers yet Thanks i too have just no idea either when it comes to brushless stuff, i have always up till now been a fuel powered car modeller 1 Quote Link to comment Share on other sites More sharing options...
Redback Posted April 23, 2023 Share Posted April 23, 2023 3 hours ago, wolfie1 said: Ok thanks that makes sense, so is a 2800kv ok for a rock crawler? Yes its about spot on, as i have the full fat 2 speed, the high kv is fine as you can go low range for the technical stuff and highrange for long distances, went the high kv as can always gear down if more torque is needed (never is) 2 Quote Link to comment Share on other sites More sharing options...
Shergar Posted April 23, 2023 Share Posted April 23, 2023 The 45 tooth spur/9 tooth pinon is a cheap mod, Id add a metal motor plate maybe for a brushless, but many on here have had no bother withe standard one. Ive had no bother with the standard plastic prop-shafts either! 1 Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 23, 2023 Share Posted April 23, 2023 (edited) So after a lot of research and deliberation i decided on this esc and motor, so should be with me soon 🙂https://www.modelsport.co.uk/product/hobbywing-xerun-axe540l-r2-2800kv-1334727 do you think i will need to drop a pinion gear size from stock, i do have a 10 tooth as im waiting on 140mm 2.2 wheels and tyres arriving at some point? Edited April 23, 2023 by wolfie1 1 Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 23, 2023 Share Posted April 23, 2023 1 hour ago, Shergar said: The 45 tooth spur/9 tooth pinon is a cheap mod, Id add a metal motor plate maybe for a brushless, but many on here have had no bother withe standard one. Ive had no bother with the standard plastic prop-shafts either! Thanks for the advice, I have the alloy motor plate and the cover bit on and am waiting for the bottom alloy bit arriving which hopefully will be soon Quote Link to comment Share on other sites More sharing options...
Redback Posted April 24, 2023 Share Posted April 24, 2023 never needed a metal motor plate, i know the metal parts if they are not traxass will not line up correctly and usally need some manual work / grinding to get them to seat together you also shouldnt need to gear down, unless you find it to fast, you will not have issues with torque 2 Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 24, 2023 Share Posted April 24, 2023 9 minutes ago, Redback said: never needed a metal motor plate, i know the metal parts if they are not traxass will not line up correctly and usally need some manual work / grinding to get them to seat together you also shouldnt need to gear down, unless you find it to fast, you will not have issues with torque Awesome thanks, i was well impressed with the fit of the alloy bits, they were perfectly fitting, i was expecting to maybe have to do a little fiddling with them but didnt need any whatsoever 1 Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted April 24, 2023 Share Posted April 24, 2023 The new motor is on it’s way 😁 but the main reason why I’m posting is because tone rear end imo there’s way to much on the back of the body is there a nice alternative ? Not bothered if the extra wheel fuel can and jack isn’t there anymore but what something there the only problem I see is the tyre holder also acts as a body post/brace going into the rear bumper with 2 prongs any mods or parts out there Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 24, 2023 Share Posted April 24, 2023 4 hours ago, RC4WD fan said: The new motor is on it’s way 😁 but the main reason why I’m posting is because tone rear end imo there’s way to much on the back of the body is there a nice alternative ? Not bothered if the extra wheel fuel can and jack isn’t there anymore but what something there the only problem I see is the tyre holder also acts as a body post/brace going into the rear bumper with 2 prongs any mods or parts out there So what motor have you got coming? I am not understanding the other bit though Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted April 24, 2023 Share Posted April 24, 2023 9 minutes ago, wolfie1 said: So what motor have you got coming? I am not understanding the other bit though this one https://www.modelsport.co.uk/product/hobbywing-quicrun-fusion-pro-2300kv-sensored-brushless-2in1-1344884 and I’m on about this way to much going on at the back for me what something a little less the wheel is way to big but would look stupid with a smaller one Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted April 24, 2023 Share Posted April 24, 2023 what about a wheel cover something like this ? https://www.amazon.co.uk/Cover-115-120mm-Crawler-Accessory-Skeleton/dp/B0B2ZS99LK/ref=sr_1_32?crid=15K95T23D5DY7&keywords=1%2F10%2Brc%2Bwheel%2Bcovers&qid=1682356524&sprefix=1%2F10%2Brc%2Bwheel%2Bcovers%2Caps%2C89&sr=8-32&th=1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted April 24, 2023 Share Posted April 24, 2023 (edited) This my 1 with that cover Edited April 24, 2023 by Stormbringer 1 Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 24, 2023 Share Posted April 24, 2023 So did you just put a bit of polystyrene in the cover to save weight? Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted April 24, 2023 Share Posted April 24, 2023 no the stock spare is under it but you could use polystyrene under it Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted April 24, 2023 Share Posted April 24, 2023 37 minutes ago, Stormbringer said: This my 1 with that cover I could do that I found a Land Rover one just looks to big might look a bit better if I paint the cans and high lift jack 🤔 1 Quote Link to comment Share on other sites More sharing options...
wolfie1 Posted April 24, 2023 Share Posted April 24, 2023 I removed my jack as it blocked the reverse light Quote Link to comment Share on other sites More sharing options...
Popular Post locky Posted April 24, 2023 Popular Post Share Posted April 24, 2023 Finished removing paint from windscreen, just the rear left, F-150 High Trail came with window stickers. Think I'll not bother with trying to detail black window rubber trim as cant see any method. 4 Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted April 24, 2023 Share Posted April 24, 2023 10 minutes ago, locky said: Finished removing paint from windscreen, just the rear left, F-150 High Trail came with window stickers. Think I'll not bother with trying to detail black window rubber trim as cant see any method. Can you use a fin tip marker pen ? Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted April 24, 2023 Share Posted April 24, 2023 I’m also sure you can get very thin black tape for RC body’s Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted April 24, 2023 Share Posted April 24, 2023 Trim tape it comes in various colours and sizes https://wheelspinmodels.co.uk/i/91697/ 1 Quote Link to comment Share on other sites More sharing options...
RC4WD fan Posted April 24, 2023 Share Posted April 24, 2023 3 minutes ago, Stormbringer said: Trim tape it comes in various colours and sizes https://wheelspinmodels.co.uk/i/91697/ That’s the stuff 👍 might get some to do the shut lines on the D110 1 Quote Link to comment Share on other sites More sharing options...
locky Posted April 24, 2023 Share Posted April 24, 2023 1 hour ago, Stormbringer said: Trim tape it comes in various colours and sizes https://wheelspinmodels.co.uk/i/91697/ Being picky now as think matt black would look better. Not sure how to make the curved corners with it though. Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted April 24, 2023 Share Posted April 24, 2023 dunno never used it on curved corners mate Quote Link to comment Share on other sites More sharing options...
