Fid dragon hammer vs kraken vekta
sean-vrs
35 minutes ago, RCbutcher said:
The dragon hammer specs are very good. It's bigger than the vekta.  Length 931.6mm vs 884mm. Other dimensions are closer to each other. Dh 40mm taller.
Both have the same 6061T6 chassis.
Vekta has 8mm shock shafts.  Dh 7mm.
Dh has 750ml fuel tank.
Vekta is much lighter. Rollers weigh dh 22kg / v5 17.7kg
Dragon hammer is more than 50% alloy mayb why it's so heavy.
Now I thought the vekta 5 was rear wheel drive but that page says its 4wd with centre diff. I must have thought wrong.
Dh will do 75kph 46mph with its zenhoa 29cc. Is that potential or fact tho lol.
Dh shocks are pretty big too. 185mm fronts. 225mm rears.  Vekta has 300mm shocks.
Just a quick comparison for lazies like me. The dragon hammer has impressed me apart from its weight. That's shocking.
Dragon hammer is 24kg rtr. 5ive is 16.7kg. Baja 13kg. Rtr
You may want to check the weight again as I get different from the DH page: http://www.fidracing.com/pro/showproduct.php?lang=en&id=87
Roller is 16.5Kg and RTR is 18.5Kg
3 minutes ago, RCbutcher said:
I went on gross weight thinking that's the full weight. I'll change it to net.
Gross weight includes the weight of the package that you'll receive ( So box, the truck, TX and other parts that's included in the box )
6 hours ago, Pistonhead said:
Saw this on Facebook earlier
Not a bad fit lol
Never seen a 5ive upclose, though that looks mighty nice sat on there.  Perfection might be the shell sides being level with the chassis plate but it's not too far off.
1 hour ago, .AJ. said:
I agree, Kraken have already hinted at different body styles to come along later, so all this "the wheels look small" talk doesn't bother me in the slightest
Not in touch with your inner tart, I reckon :P
