*** Updated Hyper owners club ***
25 minutes ago, Smoothybb said:
Yeah mine's 360mm so those GT2 shells will fit the length, I'd have to remove the hub extenders though cos it's currently about 350mm wide so wheels would be half in the shell and half out. I thought the dragon chassis was to extend a 7 but I now wonder if it's just an ST chassis alternative?
Thanks for the suggestion, I've bookmarked the deltaplastiks site while I decide between the maclaren and panoz. :good:
Gnome bumpers? I'm confused. :o
Gnome...... :lol:
damn auto correct! I mean T-Bone
4 minutes ago, Wrighty8766 said:
Gnome...... :lol:
LMFAO, I wondered if it was a typo but still scrolled two pages of google searching for them!! :insane:
Yeah I do like the tbones, had them on off roaders before.
On 18/03/2017 at 23:38, HellaFlush said:
To people that have converted their Hyper ST's to brushless power. How have you gone about having a Rx box? Ideally want it to be as low down as possible and neat.
Matt
I have exactly the same question.
Any suggestions appreciated.
I just ended up mounting my RX to the plate above the servo. One cable tie does the trick
That looks like a good idea. :thumbsup:  I have bought a new servo mount plate so I should be able to do the same as you there. I will pop a hole in the corner for the antenna.
My receiver isn't waterproof so I might have to pop it in a balloon or something.
Haven't had a chance to test it yet so no idea if it actually works yet haha.
Mines not waterproof either but I don't plan on taking it out in the wet
  • 1 year later...
15 hours ago, TheP0acher said:
SS conversion
hobbywing 120a
“castle” 2650kv
19/46
nothing special
takes some good ‘ammer
How are temps running that gearing? I normally run 17/46 in the summer.
The weather that day was about 16 degrees and i got through 2 4s 5000mah packs before i blew the tire off, esc was really cool and the motor was slightly hot but not too excessive
  • 3 months later...
Here's my hyper 7
it's almost ready to run i need to get a new flywheel & then the engine can can be fitted & hopefully get it running in the next couple of weeks. I can then start on my ST winter project.
parts fitted
alloy spoiler platform
Alloy chassis braces F/R
alloy servo brace
carbon centre brace
carbon servo holder
Hong Nor shocks
Cnc towers F/R
22* hub carriers
spider diff in rear
Losi smart centre diff with  lightened 50 tooth spur
.21 novarossi 4b plus fitted with a 41021 header & 9901 pipe with a 36000 cooler.
14 tooth lightened clutch bell (worn)
Parts needed
New wheels & tyres
Flywheel 3/4 pin
Clutch shoes
14 & 15 tooth clutch bells
Newer style shell
Better servos
