norney hurtmore Posted May 28, 2008 Share Posted May 28, 2008 how hot should my engine get? do different engine sizes differ in temp? Quote Link to comment Share on other sites More sharing options...
Mr Terminator Posted May 28, 2008 Share Posted May 28, 2008 An ideal range is between 220-250 F.What engine have you got..? The smaller engines do tend to run at hotter temps than the big blocks from .21 upwards,I have a .15 engine that runs happily at the upper end of the scale at 265 F and thats quite happy there with no bubbling or boiling fuel in the carb.I'd say 270 F is the absolute max for safety and no two engines are the same so it's always a good idea to have a temp gun.... Quote Link to comment Share on other sites More sharing options...
martin Posted May 28, 2008 Share Posted May 28, 2008 Yep carls right mate small blocks are higher on temps than big blocks my t15 engine hits about 270f and is happy where as the pro.28 in the havoc loves it at 240f to 250f they do all differ from one another and glow plug grade and fuel combination all are key elements to a perfect running engine at lower temps. marty Quote Link to comment Share on other sites More sharing options...
norney hurtmore Posted May 28, 2008 Author Share Posted May 28, 2008 its a .21, but don't know what make its fitted on my RTR Ansmann virus and if i can here my fuel boiling is it running too hot? Quote Link to comment Share on other sites More sharing options...
martin Posted May 28, 2008 Share Posted May 28, 2008 Yep its to hot mate, if you haven't got a temp guage the spit method is ok and gets you around the point of a good tune, get it up to running temp and put some spit on the head if it boils instantly/dances around straight away its way to hot, you want it to sizzle about 2/3 seconds after its been applied, if it doesn't sizzle at all its running to rich. marty Quote Link to comment Share on other sites More sharing options...
Mr Terminator Posted May 28, 2008 Share Posted May 28, 2008 The engine you have in the Virus is a Force.21 with Ansmanns own anodised head and markings.Martins spot on,you need to richen your HSN until you get the desired running temp.Invest in a temp gun mate,they're invaluable when your pretty new to the hobby... Quote Link to comment Share on other sites More sharing options...
Logie Posted May 28, 2008 Share Posted May 28, 2008 Temps vary as said above, anything 240 and below is fine. Some engines can run hotter, but you really shouldnt exceed 270f. Its quoted in alot of manuals that this is the danger zone. I have the SH .28 and it doesnt like to run hot, yet my Thunder Tiger .21 is happiest 260f Quote Link to comment Share on other sites More sharing options...
austinberry2005 Posted May 29, 2008 Share Posted May 29, 2008 ki dont have a heat gun thing but i use the spit method and it starts to sizzle after about 4-5 seconds!!! Quote Link to comment Share on other sites More sharing options...
Mr Terminator Posted May 29, 2008 Share Posted May 29, 2008 Temps vary as said above, anything 240 and below is fine Just to point out incase of any confusion,below 200 F is not good for the engine either,the only time these temps should be seen in normal running is when an engine is being broke in as its not at full throttle and running really rich.It wouldn't be wise to run around at 170 F all day as the piston and liner will wear prematurely through the liner not expanding enough.So a good range is 220-250 F,allowing for different engines no higher than 270 F and thats after full WOT runs... Quote Link to comment Share on other sites More sharing options...
Logie Posted May 29, 2008 Share Posted May 29, 2008 ops yes, as Mr T said dont want it too low I have a friend who has run a Savage for years and his temp after high speed runs is normally 305f and his truck is still going fine and its used atleast twice a week. If the car sounds healthy, your getting smoke and the fuel is not boiling theres really nothing much to worry about. If its smoking that means the engine is getting lubed. If it sounds healthy and its going well then, that says it all really. Some people will advise not to go over 240f. Myself and others run up around the 260~270f trouble free. It depends on how you feel about tunning the car. I belive most engine are made and limits are placed to bring a certain safety margin in to cover warrenty etc and these limits are always on the cautious side to protect the manufacture Quote Link to comment Share on other sites More sharing options...
norney hurtmore Posted May 29, 2008 Author Share Posted May 29, 2008 cheers peeps, this is exactly what i was after have got a temp guage for it , running at 211f and now i've busted me pullstart anywhere open at 9:30 pm in Hants ? lol Quote Link to comment Share on other sites More sharing options...
norney hurtmore Posted June 4, 2008 Author Share Posted June 4, 2008 i'm taking my temp readings from the top of the heatsink is this right ? or should i be taking it from the glowplug ? Quote Link to comment Share on other sites More sharing options...
incognito Posted June 4, 2008 Share Posted June 4, 2008 You want to take it from glow plug. Select on your temp gun show hottest reading if it has that feature and get it as close to the glow plug (pointing down where you insert the glow starter) as you can. Quote Link to comment Share on other sites More sharing options...
damodear Posted June 4, 2008 Share Posted June 4, 2008 can you just repeat those running temps again please in celcus (I can't use Fahrenheit) Thanks Damo Quote Link to comment Share on other sites More sharing options...
Danny-B- Posted June 4, 2008 Share Posted June 4, 2008 (edited) Max temp - 270f - 132.2c normal 210f to 250f - 98.8c to 121.1c Minimum 200f - 93.3c Just to add ... i was out with my Hyper tonight, was getting temps on 240 - 255 after speed runs, which is great, loads of smoke. I used to run it 265+, which was a bit nippier but i'd rather loose a little speed and have the engine last longer Anyway, my servo horn has worn now so i have to wait on a new one coming Edited June 4, 2008 by Danny-B- Quote Link to comment Share on other sites More sharing options...
