Hobao DC1 Owners
17 minutes ago, everclear1984 said:
Can somebody with a user manual tell me size of the bearings on the diff locker please? Mine were seized solid and had to be but off. I measured them at 8x12x4 but that size doesn't seem to exist.
Never mind, found it! It's 8x12x3.5
1 hour ago, Stormbringer said:
Have you gone back to the stock bumper ?
Looks really at home in the mud :good:
I have, I think it looks more scale than the rc4wd one. Still need to fit the winch.
I stripped the front axle apart today, EVERY bearing needs replacing! I just can't seem to keep it out of the water 😂 To be fair, this is the first maintenance I've done since building it.
  • Haha 3
29 minutes ago, Jack Reacher said:
I learnt the hard way with water and crawlers on my FS scx, ruined all bearings  so my dc1 has not been in water will be a good buy for some one
I've never bought an RC with the intention of keeping it clean, other than the Strada I guess. Bash em, break em, fix em and repeat 👍
Same!  No way I’m spending good money on a toy to baby it 👍
8x12x3.5
Assuming this is what you are looking for ☺️
Edit.....
Balls, sorry didn't see that you'd found it!
Edited by MrPeaski
1 hour ago, Redback said:
Or rather than baby it, you could fill the axles with marine grease and never worry. 🙂
That's what I'll be doing this time. I only had bike grease available at the time of building it.
How bad are the bearing like all seized? Do you wash your trucks after a mud bath? Do you put a drop of oil or corrosion x on the bearings after a wash? Even if you dont run them in the water, just on wet grass water gets in the hub bearings easily.
I also use Abby gun grease and it seems to do just as good as marine grease. My crawlers has never had a bearing fail / seize, either im doing things right or not running them hard enough 😛
None were seized solid, though some had failed and were only being held together while they had pressure on them lol. I rinse it with clean water and dry it after every muddy session, and I occasionally apply oil to any accessible bearings. It's been through thick mud and disgusting water more times than I can count, I think a year between bearing changes is perfectly acceptable 🙂
Oh for sure, for some reason i thought this truck was basically new 🙃
I like to dunk them too 😬 GT85 is a few quid a can and a cheap investment post rinse off, I've been putting RC bearings rubber shielded in as replacements. I do add a little machine oil now and then too. My favourite combo seems to be red n tacky grease and Schumacher/Xtralube during build and GT85 after a run.
Edited by Shergar
How long did the resisting last then :rofl:
It stayed (mostly) dry today. I still need to strip and service the rear axle and it'd be nice if it wasn't full of gunk when I eventually get around to it 🤣
I bet that water was so very tempting, cant believe my DC1 not sold, i dont really want to sell it but i want a multiplex Funray more and that is an expensive sport glider!
I think i need to strip and grease the axles on the carisma ford, that does go in water as no bearings to rust
