Drapes86 Posted November 25, 2020 Author Share Posted November 25, 2020 Just now, Drapes86 said: Let me guess... is it this thing? Is it a capacitor? It was installed between the + and - terminals of the motor and I forgot to install it in my excitement 🙈 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 25, 2020 Author Share Posted November 25, 2020 Just now, Drapes86 said: Let me guess... is it this thing? Is it a capacitor? It was installed between the + and - terminals of the motor and I forgot to install it in my excitement 🙈 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 25, 2020 Share Posted November 25, 2020 4 minutes ago, Drapes86 said: To be fair, the new generation of ESC’s are far superior in every way to the old mechanical ones. was this with the new battery, could just have been too much for the speed controller? 1 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 25, 2020 Share Posted November 25, 2020 5 minutes ago, Drapes86 said: Ah, that may well be the culprit😀 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted November 25, 2020 Share Posted November 25, 2020 you could try fitting the capacitor and try powering it up again being mechanical it may work 1 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 25, 2020 Author Share Posted November 25, 2020 3 minutes ago, Ag100 said: To be fair, the new generation of ESC’s are far superior in every way to the old mechanical ones. was this with the new battery, could just have been too much for the speed controller? Yes it was the new battery connected.. I tried to not be ridiculous with it and bought a 1800mah battery compared to the original 1200mah, but something clearly wasn't right in the circuit! Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 25, 2020 Author Share Posted November 25, 2020 44 minutes ago, Stormbringer said: you could try fitting the capacitor and try powering it up again being mechanical it may work No, it's completely b0lloxed. It's melted the plastic and possibly welded the metal parts inside it... either way it is completely seized in position. It's a shame because it is 30+ years old, but I guess that's a learning experience. I'll keep it to go with the story of the car, but she's not going anywhere until I buy a new controller 👎 Quote Link to comment Share on other sites More sharing options...
Redback Posted November 26, 2020 Share Posted November 26, 2020 Assuming the 1200mha and the 1800mha are both 7.4v i dont see the battery being a cause unless you upped the voltage, did you open the speed controller up to check it was mechanically sound? Its a shame to loose the original but an electronic ecu will give you much better runtime and performance in the long term, maybe a silver lining of the cloud. 1 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 26, 2020 Author Share Posted November 26, 2020 6 hours ago, Redback said: Assuming the 1200mha and the 1800mha are both 7.4v i dont see the battery being a cause unless you upped the voltage, did you open the speed controller up to check it was mechanically sound? Its a shame to loose the original but an electronic ecu will give you much better runtime and performance in the long term, maybe a silver lining of the cloud. I didn't install the capacitor which bridges the poles of the motor, so I think that will be the cause. My only concern is that the speed controller is the original for the car, and it is 30+ years old - I intended to up upgrade to ESC anyway and I have one in the post already 👍 I didn't inspect it before installing no, that would have been far too sensible! 😅 I did bench test it beforehand though, and I didn't install the capacitor then either, so I thought everything was going well. Sadly not for the mech controller who was being burned alive in all the excitement! Quote Link to comment Share on other sites More sharing options...
turok007 Posted November 27, 2020 Share Posted November 27, 2020 I raced a custom special for a while back in the day. all i can remember really is it used brown spur gears they looked like wood. Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 27, 2020 Author Share Posted November 27, 2020 On 26/11/2020 at 06:52, Drapes86 said: I didn't install the capacitor which bridges the poles of the motor, so I think that will be the cause. My only concern is that the speed controller is the original for the car, and it is 30+ years old - I intended to up upgrade to ESC anyway and I have one in the post already 👍 I didn't inspect it before installing no, that would have been far too sensible! 😅 I did bench test it beforehand though, and I didn't install the capacitor then either, so I thought everything was going well. Sadly not for the mech controller who was being burned alive in all the excitement! After doing some research, the capacitor is installed across the motor terminals to prevent interference between the motor and the transmitter signal to the car... ...so it doesn't explain why the mech servo burnout. It does mean that it wasn't my own incompetence that caused it though, so that's something at least! 😂 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Drapes86 Posted November 27, 2020 Author Popular Post Share Posted November 27, 2020 It might not look like much progress, but I've got the drive and belt covers on. I pretty much had to dossassemble the entire car to get the lower cover on, so there's significantly more work than it first appears. Still waiting for the new ESC to arrive. Excited is a bit of an understatement! Can't wait to see it go 😍 4 Quote Link to comment Share on other sites More sharing options...
Ag100 Posted November 27, 2020 Share Posted November 27, 2020 7 minutes ago, Drapes86 said: It might not look like much progress, but I've got the drive and belt covers on. I pretty much had to dossassemble the entire car to get the lower cover on, so there's significantly more work than it first appears. Still waiting for the new ESC to arrive. Excited is a bit of an understatement! Can't wait to see it go 😍 Don’t know what it is about those wheels, but they just look really good👍 1 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 27, 2020 Author Share Posted November 27, 2020 5 minutes ago, Ag100 said: Don’t know what it is about those wheels, but they just look really good👍 Thanks mate! Considering they are so plain, they do look the business don't they. I do like the pepperpot style wheels of the Turbo though 👌 Quote Link to comment Share on other sites More sharing options...
Popular Post Drapes86 Posted November 28, 2020 Author Popular Post Share Posted November 28, 2020 On 25/11/2020 at 09:37, bertberr said: Yes, just use some black plastic tube/spacer/stand-off, the originals are square section, but nobody would ever notice unless they were a massive bore or judging an originality contest. They are 18mm in length, and originally 4 x M2.6x12 self tappers were used all the way through wing stay, angle adjuster and into stay joint. Personally, I'd just grab a couple of hex section spacers / stand offs from ebay, they do them in 18mm so you wouldn't even need to trim them up, only a couple of quid for two, and then just use the more readily available M3 tappers (in black!). Or you could go round section in either black plastic or some non-anodized alloy, your choice really. New wing stay supports installed and looking bang tidy! Thanks for the tip on the 18mm hex spacers, they were plug and play and the whole assembly looks much better with the black screws 👍 4 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted November 28, 2020 Share Posted November 28, 2020 Your doing a grand job on restoring this 1 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 28, 2020 Author Share Posted November 28, 2020 Here's all of the pictures I've taken during the rebuild so far in an album 👍 2 Quote Link to comment Share on other sites More sharing options...
turok007 Posted November 28, 2020 Share Posted November 28, 2020 Sorry if i missed it but do you have the 2nd motor plate it is a alloy strange shape one that fits behind the main one. i think it was to help with pinion placement. 1 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted November 28, 2020 Author Share Posted November 28, 2020 37 minutes ago, turok007 said: Sorry if i missed it but do you have the 2nd motor plate it is a alloy strange shape one that fits behind the main one. i think it was to help with pinion placement. Yeah, its they're alright... it is an absolute pig to install because the screws have to be fitted blind into the motor housing! The screws tightened into something and the motor feels pretty solid, so I assume they located into the right holes 😂 It's fitted onto slotted holes, so I guess you yould put a bigger or smaller pinion on...? 2 Quote Link to comment Share on other sites More sharing options...
turok007 Posted November 28, 2020 Share Posted November 28, 2020 23 minutes ago, Drapes86 said: Yes i remember it being a right pain changing motors while at the track as the screws had to be short. i was trying to get mine to go a bit quicker as the smallest spur i had was not small enough so i had to use a pinion of 30+ teeth. 1 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted December 2, 2020 Author Share Posted December 2, 2020 Finally an update worth reporting on - New ESC and motor brushes have arrived and installed... she's a runner! 🤩 By no means perfect. There is some interference, possibly with the sheer number of high frequency brain microwaving things going on in my house. Maybe outside will work better? 🤔 The steering servo arm comes loose at the slightest knock, so I'm a little nervous about stretching it's legs fully at the risk of obliterating her into the nearest curb! I have to push the throttle stick forward twice to get it to go forward... any ideas? Oh, and it's a lot faster in reverse than it is going forwards?? Is this a setting on the ESC? 2 Quote Link to comment Share on other sites More sharing options...
James.S Posted December 2, 2020 Share Posted December 2, 2020 Glad that you got it all working mate On your transmitter you should have a couple of sliding buttons, left for normal & right for reverse. One is for the throttle and one for the steering, try switching them the opposite way and see if that fixes the problem for you 1 Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted December 2, 2020 Share Posted December 2, 2020 nice one try reversing the control on the throttle stick- usually whilst travelling forward, pulling back acts as a brake until stopped, then you go down again to activate reverse. I say you conrol is ar5e about face, easiest silution flipping it on the handset 1 Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted December 2, 2020 Share Posted December 2, 2020 Just now, James RC said: Glad that you got it all working mate On your transmitter you should have a couple of sliding buttons, left for normal & right for reverse. One is for the throttle and one for the steering, try switching them the opposite way and see if that fixes the problem for you beat me to it, nice one 1 Quote Link to comment Share on other sites More sharing options...
Drapes86 Posted December 2, 2020 Author Share Posted December 2, 2020 3 hours ago, Dan_Q said: beat me to it, nice one Thanks chaps! Is this the same even with this dinosaur? I've got the trim levers beneath the sticks, but not sure what you're suggesting can be done with it... or am I missing something? Do I need to get into the transmitter to do it? Quote Link to comment Share on other sites More sharing options...
