Tug Posted May 1, 2019 Share Posted May 1, 2019 Quick word to AJs diffs; good luck with that!^ ? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 1, 2019 Author Share Posted May 1, 2019 Lol, I was recommend 300/600/300 on a FB group, but that seemed like a odd combination?? I’ve got 500, 200, 100, 50, 30 all in my pit box so I can have a play around ? I was also told to get alloy centre diff mounts or I will cook the diff sooner rather than later Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 1, 2019 Author Share Posted May 1, 2019 Found this, I’ve had GDS stuff in the past and it’s been pretty good for the money, I would like a Modified RC diff mount, but the wallet is pretty empty at the moment ? https://www.ebay.co.uk/itm/GDS-RACING-4pcs-diff-mount-for-team-losi-5ive-T-quick-change-BLACK-BLUE-RED-GOLD/163281145726? Quote Link to comment Share on other sites More sharing options...
mond Posted May 1, 2019 Share Posted May 1, 2019 (edited) 56 minutes ago, .AJ. said: Lol, I was recommend 300/600/300 on a FB group, but that seemed like a odd combination?? I’ve got 500, 200, 100, 50, 30 all in my pit box so I can have a play around ? I was also told to get alloy centre diff mounts or I will cook the diff sooner rather than later Honestly, those values are ridiculous. I get that the idea is to stop things diffing out but it also makes it utterly uncontrollable and you lose the agility of the buggy. No thickness off oil will stop that motor on 12S from diffing out anf blowing a tyre if you're genuinly bogged down on a few wheels. I tried a million in the DBXLE on 8S and it would diff out in an instant if I was stupid. I'd stick 100k in the middle and then 50k in the front and probably 20 in the rear. Too thick in the middle and rear and it will kick out on every turn. On my 5ive, I run 12k/10k/7k for running on a track. Granted my engine is a fraction of that motors torque and probably half the horse power. Edited May 1, 2019 by mond Quote Link to comment Share on other sites More sharing options...
Tug Posted May 1, 2019 Share Posted May 1, 2019 I have an Integy CD mount, laugh all you want, it does the job, it doesn't flex. Yeah, you'll have to try different oils, but if you're not racing it, it's hardly important. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 1, 2019 Author Share Posted May 1, 2019 As long as it’s alloy it will help keep everything straight and the diff cool, it’s hardly a high stress area so no need for anything too fancy, plus the split design is a bonus... Oil wise, I used to run 50/100/30 in my 5ive-T, that was with a Bartolone 34cc, think I’ll go with original plan and work from there ? Quote Link to comment Share on other sites More sharing options...
Tug Posted May 1, 2019 Share Posted May 1, 2019 It might not be stressed itself, but the flex I've witnessed on mine is quite severe, this means your mesh is way off with every squeeze of the trigger. Now hurry up with the build! Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 1, 2019 Author Share Posted May 1, 2019 I’ve started on the roller, but as it been done a few times on here before I won’t bore anyone with pics until it gets interesting ? Quote Link to comment Share on other sites More sharing options...
supersavage Posted May 1, 2019 Share Posted May 1, 2019 I ran 30,000 front, 60,000 centre and anything in between 5,000-15,000 in the rear of my truck and buggy but that was my track set up and engines that don't have any near the amount of torque that monster of a motor is going to have. 1 Quote Link to comment Share on other sites More sharing options...
tamiyafanboy Posted May 2, 2019 Share Posted May 2, 2019 Following 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 2, 2019 Author Share Posted May 2, 2019 Been trying to find the TLR carbon dual servo tray kit without much luck tbh and when I do it’s stupidly priced.... It uses the same tray as the brushless conversion kit though, so looks like I’ll be buying the TLR brushless conversion kit and then selling the motor mount, trays (may use one tray as a and esc mount) and the other parts I don’t need, so I’ll save a good bit of money because all the dual servo tray kits are $40 more than the brushless kit even though they have half the parts..... ? Dual servo Tray kit https://www.horizonhobby.com/dual-steering-servo-tray-conversion%3A-5ive-t--5ive-b-p-tlr358001 Brushless conversion kit https://www.horizonhobby.com/product/cars-and-trucks/car-and-truck-accessory/all-surface-parts/electric-conversion-kit:-5ive-t--5ive-b-p-tlr358000 Quote Link to comment Share on other sites More sharing options...
supersavage Posted May 2, 2019 Share Posted May 2, 2019 Might be worth trying to contact these guys as they might be able to point you in the right direction of what you want. https://www.facebook.com/groups/320237558499847/ 1 Quote Link to comment Share on other sites More sharing options...
mond Posted May 2, 2019 Share Posted May 2, 2019 How does that even fit in a B? Why not go for the aluminium dual mount for the B? IMHO its much nearer and a step up from the T servo setup. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 2, 2019 Author Share Posted May 2, 2019 The tray is the same as what’s in the brushless kit Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 2, 2019 Author Share Posted May 2, 2019 I guess you mean this alloy dual mount https://www.amainhobbies.com/team-losi-racing-5iveb-aluminum-dual-steering-servo-tray-tlr351002/p582937 Im not a fan of that style set up and the other reason is where I’m mounting the ESC I need to hack up the stock throttle servo and battery box to make room for it to fit and looking at pictures of how others have done it, I would never be happy with it Quote Link to comment Share on other sites More sharing options...
mond Posted May 2, 2019 Share Posted May 2, 2019 Fair play. Not tempted with that ridiculous Hitec again? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 2, 2019 Author Share Posted May 2, 2019 It did cross my mind ? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 2, 2019 Author Share Posted May 2, 2019 Been cracking on with the build, one thing I’ve seen with the conversion kit that i find very poor is the use of these screws to hold the motor mount to the chassis, why couldn’t they use engine inserts? My mate has a few sets and is going to pop round so we can work out which size is needed for the 16t pinion Quote Link to comment Share on other sites More sharing options...
Tug Posted May 2, 2019 Share Posted May 2, 2019 I've struggled with that. You may end up using big inserts, but reversing them to get a perfect mesh. Keep us posted on how you get on. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 2, 2019 Author Share Posted May 2, 2019 Yea looks like it’s the 18/24 or 19/23 ones ? Quote Link to comment Share on other sites More sharing options...
Popular Post .AJ. Posted May 2, 2019 Author Popular Post Share Posted May 2, 2019 Just finished up the basic roller, only took about 5hrs not having the petrol parts or radio gear fitted 7 Quote Link to comment Share on other sites More sharing options...
tamiyafanboy Posted May 2, 2019 Share Posted May 2, 2019 Looking good! 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 3, 2019 Author Share Posted May 3, 2019 I’ve put the stock wheels up for sale and just ordered these ? https://www.rcmodelz.co.uk/30-degree-north-signature-mini-pin-wheels-yellow.html Quote Link to comment Share on other sites More sharing options...
Scoobyslayer Posted May 3, 2019 Share Posted May 3, 2019 (edited) nice work aj. man I wish I hadn't seen this post. I have been toying with converting my 5ive b to brushless as I already have the lipos I can use from my hpi Baja flux. the only thing stopping me is if I still want to race with it, I can't see a set of lipos lasting 22-25mins lol if you do buy the tlr conversion kit I might be interested in the parts you do not use. keep me posted if that's the way you end up going. cant wait to see your running videos. do you have a youtube channel? Edited May 7, 2019 by Scoobyslayer 1 Quote Link to comment Share on other sites More sharing options...
Scoobyslayer Posted May 3, 2019 Share Posted May 3, 2019 (edited) if you are not 100% set on using dual steering servos you could try what I am doing and use the single servo mount from the 30degree north buggy. im not sure how this will hold up as I have not done a field test yet. I will post a pic later Edited May 3, 2019 by Scoobyslayer Quote Link to comment Share on other sites More sharing options...
