AJ's KV1 Heavy Metal Russian Armour
.AJ.
How did you fix the gear wheel on the servo? Just drill an undersize hole and jam it on?
I was planning a similar setup...though I can't use a proper servo...I would have to remove the control board and just use the motor as a motor hooked up to the stock power supply ( no facility for servo traverse...just servo recoil and elevation on the Clark board )
The more I listen to the whine of the stock motor the worse it sounds to me. I got several old servos...any one of which would be fine for this
Just had a thought mate, how about run a Y Lead from the RX channel for the rotation, one side for the Clark and then the other to a 360 servo and if it runs too fast get a Turnigy Servo speed controller?
hmmm....that could work. The left/right operation on the left stick is traverse.....so using a y-lead should be fine. It won't interfere with the other options which use that channel along with other inputs.
Not really a lot to show off, the main difference is that the extra controls ie cannon fire, MG, smoke on/off, light on/off etc have now been assigned to the switches instead of having to hold the sticks in odd positions lol
