vinniejones Posted February 24, 2023 Share Posted February 24, 2023 JUST STARTED FLYING RC PLANES GOT DX6E TRANSMITTER BUT STRUGGLEING TO FIND A SD CARD THAT WIL WORK IN IT I HAVE READ CLASS 6 AND 16GB MAX FORMAT FAT32 I THINK BUT CANT FIND A CLASS 6 CARD WHAT IS EVERYBODY USEING MANYTHANKS IN ADVANCE VINNIEJONES Quote Link to comment Share on other sites More sharing options...
monkeyboy_uk Posted February 24, 2023 Share Posted February 24, 2023 JUST GET A CLASS 10, THEY ARE FASTER SO WILL BE FINE. Quote Link to comment Share on other sites More sharing options...
Alex97 Posted February 24, 2023 Share Posted February 24, 2023 PLEASE SPEAK UP 1 Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 PARDON Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 2 hours ago, vinniejones said: JUST STARTED FLYING RC PLANES GOT DX6E TRANSMITTER BUT STRUGGLEING TO FIND A SD CARD THAT WIL WORK IN IT I HAVE READ CLASS 6 AND 16GB MAX FORMAT FAT32 I THINK BUT CANT FIND A CLASS 6 CARD WHAT IS EVERYBODY USEING MANYTHANKS IN ADVANCE VINNIEJONES I PUT A CLASS 10 IN AND IT WILL IMPORT BNF FROM WEBSITE BUT WONT IMPORT ONTO DX6E Quote Link to comment Share on other sites More sharing options...
Bajadre Posted February 24, 2023 Share Posted February 24, 2023 did you format card to FAT32 first vinnie? does the BF file show on the card? Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 if i remember correctly theres a format card function in the transmitter but it has been a while since i needed to format a card for tx,s Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 1 hour ago, Bajadre said: did you format card to FAT32 first vinnie? does the BF file show on the card? YES I FORMATED IT TO FAT32 AND THE BNF FILE DOES SHOW ON CARD ON MY LAPTOP BUT IN THE DX6E IT DOESNT SHOW Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 Just had a look at my card and its a Sandisc 2GB micro sd card which i use with sd adapter for DX8 , DX8G2 and without adapter for NX8 1 Quote Link to comment Share on other sites More sharing options...
Alex97 Posted February 24, 2023 Share Posted February 24, 2023 Try using a smaller capacity card, 4GB. Some devices can't read the card if it's above a certain capacity. Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 10 minutes ago, Stormbringer said: if i remember correctly theres a format card function in the transmitter but it has been a while since i needed to format a card for tx,s THANKS STORMBRIDGER WILL LOOK AT THAT Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 also on the NX8 when you go to card utillities you need to select external to see whats on card Dont know if same with DX6e Quote Link to comment Share on other sites More sharing options...
Bajadre Posted February 24, 2023 Share Posted February 24, 2023 i used to use the dx6 years ago and sure i used a 2gb sandisk card and that was overkill tbf the custom voice files were tiny all i can remember was doing the model modes were easy enough 👍 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 yeh the model files are tiny as well just a few kbs Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 2 hours ago, Stormbringer said: Just had a look at my card and its a Sandisc 2GB micro sd card which i use with sd adapter for DX8 , DX8G2 and without adapter for NX8 THANKS FOR THAT AND GOING TO THE TROUBLE OF CHECKING YOURS 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 no probs when you format card are you using fast format ? Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 4 minutes ago, Stormbringer said: no probs when you format card are you using fast format ? YES I AM Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 try the other option ie the slow format as i found quick format wasnt formatting it to fat 32 1 Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 43 minutes ago, Bajadre said: i used to use the dx6 years ago and sure i used a 2gb sandisk card and that was overkill tbf the custom voice files were tiny all i can remember was doing the model modes were easy enough 👍 THANKS FOR THAT 1 Quote Link to comment Share on other sites More sharing options...
vinniejones Posted February 24, 2023 Author Share Posted February 24, 2023 Just now, Stormbringer said: try the other option ie the slow format as i found quick format wasnt formatting it to fat 32 WILL DO THAT THANKS 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 1 other thing have you registered your transmitter on the spektrum site ? https://spektrumrc.com/MyAccount/Login.aspx?ReturnUrl=%2fMyAccount%2f if you havnt registered it i know you cant do any updates to the TX but not sure if that extends to model files 1 Quote Link to comment Share on other sites More sharing options...
Bajadre Posted February 24, 2023 Share Posted February 24, 2023 i remember why i went Team black sheep gear now lol 😂 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 Whats team black sheep then ? but at least Spektrum keep stuff updated if registered Got my DX8 in 2010 and last update 2014 got dx8 g2 2017 and still being updated 1 Quote Link to comment Share on other sites More sharing options...
Bajadre Posted February 24, 2023 Share Posted February 24, 2023 (edited) TBS agent is updated all the time storm Crossfire is far superior on both range (40kms) and latency tbh not knocking speccy gear at all but i had endless range problems with mine obv TBS is more expensive though Edited February 24, 2023 by Bajadre 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 24, 2023 Share Posted February 24, 2023 cheers mate 1 Quote Link to comment Share on other sites More sharing options...
