53HRA Posted August 31, 2022 Share Posted August 31, 2022 All-new chassis with narrowed front suspension pivots increases stability & traction Hard composite suspension arms combined with the improved central chassis flex keeps the suspension geometry stable while the flex is transferred through chassis and radio plate to maintain traction Narrower front and rear suspension holders for improved traction and stability Lower down-stop mounting holders without the eccentric geometry make the car easier to set suspension down-stops All-new front aluminium bulkheads accommodate new upper arm holder with adjustable flex Redesigned front upper arm holder features new roll centre positions in all 9 positions Ultra-compact and super lightweight receiver box moves the weight lower and closer to the centre of the chassis Radio plate with new servo holders moves the throttle servo more rearwards, the steering servo more frontwards and receiver box with a more central location Servo saver stand with key lock design Fuel tube holders allows to be mounted directly on the radio plate for a clean look Simplified aluminium 2-speed shaft holders eliminate unnecessary braces to make the chassis more flexible, while the wider positioning provide improved support for the 2 speed shaft Pulley collar is optimized for the fixed position of the pulley on the 2-speed shaft New rear aluminium bulkheads have a 2mm front/rear wheelbase adjustment for easy traction tuning depending on the track conditions. Front position more traction, rear position more stability Longer rear suspension pins for wide range of wheelbase adjustment View full news article Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted August 31, 2022 Share Posted August 31, 2022 Love the body shell it looks fast just sitting still Quote Link to comment Share on other sites More sharing options...
