sunny Posted August 1, 2022 Share Posted August 1, 2022 Hi Guys I'm getting almost no range from Flysky FSGT3B transmitter. I checked everything over onkybthing I can think of is that the aerial wire on the receiver I had it totally covered in a plastic tube to protect it even the clear bit at the end. Would this lessen the range as at the moment its less than 50 metres. Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted August 1, 2022 Share Posted August 1, 2022 Yes it will lesson the range 1 Quote Link to comment Share on other sites More sharing options...
Bajadre Posted August 1, 2022 Share Posted August 1, 2022 yeah brother try not to block the end of the wire Quote Link to comment Share on other sites More sharing options...
sunny Posted August 1, 2022 Author Share Posted August 1, 2022 I'll try again with fully charged batteries and the receiver antenna uncovered and report back 1 Quote Link to comment Share on other sites More sharing options...
BigGinge Posted August 1, 2022 Share Posted August 1, 2022 How have you routed/positioned the antenna in your car? If it is close to some noisy wires (like the ones going between the ESC and motor) or any large metal components (like metal base plates) that can disrupt it's performance too. 2 Quote Link to comment Share on other sites More sharing options...
windz1000r Posted August 1, 2022 Share Posted August 1, 2022 Had the same issue with my flysky gt3B Would be fine out in the middle of knowhere anywhere slightly built up Was absolutely rubbish less than 20m sometimes It seams it was massively affected buy any other signals Gave up with it After trying the receiver in about 60 different locations and trying different cells in the tx ect Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted August 1, 2022 Share Posted August 1, 2022 I had range issue`s on my flysky FSI6x aircraft radio in the Dragon 1200 plane, i have taped over the antenna ends with thick clear tape, kept getting low RSSI at like 50 m out changed the set up and now good for over 1k Quote Link to comment Share on other sites More sharing options...
sunny Posted August 1, 2022 Author Share Posted August 1, 2022 5 hours ago, BigGinge said: How have you routed/positioned the antenna in your car? If it is close to some noisy wires (like the ones going between the ESC and motor) or any large metal components (like metal base plates) that can disrupt it's performance too. yes its running along a metal chassis. I'll get one of those small aerial tubes and stand it up 1 Quote Link to comment Share on other sites More sharing options...
