.AJ. Posted March 24, 2018 Author Share Posted March 24, 2018 Fake disk rotors, easily remove if they ain’t your thing Rear toe inserts in the rear axle, set to zero degrees as stock A set 3 degree inserts are also supplied Dog bones and axles look well up too the job, but a shame the bearings couldnt have been a bit biggger Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 24, 2018 Author Share Posted March 24, 2018 First mod.. Changed the esc wiring to a single connector as I’ll only be running single 4 or 6s packs and yesterday when I first went out I left the jumper behind....... Ive also had a fiddle with the esc settings and turned up the brakes and upped the BEC voltage to 8.4v, I’m not sure if the Servo will thank me in the long run though 1 Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted March 24, 2018 Share Posted March 24, 2018 2 hours ago, .AJ. said: The drifting was me Thats good to hear, I know its not exactly made for a car park but theres nothing worse than powering it out of a corner and the back going. Wondered if it was a characteristic of the rear axle Quote Link to comment Share on other sites More sharing options...
Thom Posted March 24, 2018 Share Posted March 24, 2018 2 hours ago, .AJ. said: First mod.. Changed the esc wiring to a single connector as I’ll only be running single 4 or 6s packs and yesterday when I first went out I left the jumper behind....... Ive also had a fiddle with the esc settings and turned up the brakes and upped the BEC voltage to 8.4v, I’m not sure if the Servo will thank me in the long run though Apparently quite an improvement to handling on 8.4. Lots of guys are going to a 21T pinion. Makes this thing a bullet apparently. I’m happy at 19T to be honest. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 24, 2018 Author Share Posted March 24, 2018 The servo certainly has a bit more go about it now Quote Link to comment Share on other sites More sharing options...
mond Posted March 24, 2018 Share Posted March 24, 2018 Noticed the one difference between this and the smaller version - you get a proper diff in the back, dog bones in the axle. I wonder which other wheels will fit? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 24, 2018 Author Share Posted March 24, 2018 Not a lot at the moment with the stock 20mm hex’s, Hobbythek have a 24mm conversion available and LST2 17mm ones bolt straight on though Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 24, 2018 Author Share Posted March 24, 2018 Found this good size comparison pic Quote Link to comment Share on other sites More sharing options...
Kpowell911 Posted March 25, 2018 Share Posted March 25, 2018 Thanks for that. 5ives are HUGE lol Quote Link to comment Share on other sites More sharing options...
Thom Posted March 25, 2018 Share Posted March 25, 2018 (edited) 5 hours ago, .AJ. said: Found this good size comparison pic AJ what did you use to get to the last two cage bolts (near rear shock) - I presume you are using an leccy screwdriver as there’s literally no room to get leverage on it using hand Allens?stripping mine down for a clean as it absolutely filthy today including some big puddles so want to ACF-50 it all. Edited March 25, 2018 by Thom Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 25, 2018 Author Share Posted March 25, 2018 I use something like thIs, I’ve never been a fan of using electric drills, they can can cause more issues than they solve 1 Quote Link to comment Share on other sites More sharing options...
RobFandango Posted March 25, 2018 Share Posted March 25, 2018 Them tools are good, do you have a link to a set? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 25, 2018 Author Share Posted March 25, 2018 I bought some off eBay ages, they were about £7 each Quote Link to comment Share on other sites More sharing options...
Thom Posted March 25, 2018 Share Posted March 25, 2018 (edited) 5 hours ago, .AJ. said: I use something like thIs, I’ve never been a fan of using electric drills, they can can cause more issues than they solve With such an awkward position on that last hex, I feel that tool should have been included. thanks I’ll look at getting these. Screwfix has the 2mm but not the 2.5mm. Without looking at the truck, isn’t the screw in question 2.5mm? Gah! Edited March 25, 2018 by Thom Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 25, 2018 Author Share Posted March 25, 2018 Yea it’s 2.5mm Quote Link to comment Share on other sites More sharing options...
Thom Posted March 25, 2018 Share Posted March 25, 2018 5 hours ago, .AJ. said: Yea it’s 2.5mm Cheers. Got some but those screws were massively over torqued. Was hell getting them out. Honestly, that screw there is an absolute terrible design decision. Thankfully I love the truck. Not going to put it back on until the FPV mount arrives. Like the fact it has the FPV mount supports out the box, you just need the mount. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 25, 2018 Author Share Posted March 25, 2018 They seem a bit long aswell to me, so I used slightly shorter screws and they went in much easier Quote Link to comment Share on other sites More sharing options...
Thom Posted March 25, 2018 Share Posted March 25, 2018 If they weren’t for the fact that it’s the god damn main cage support screw, I’d of left them out. Honestly, that’s how much I hate them. I don’t get how they couldn’t do better, especially after the SCBE and DXBLE. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 25, 2018 Author Share Posted March 25, 2018 They missed the fact that the average RC’er loves to fiddle and the shell/body should be easily removable, I’m sure someone with come up with a 3D printed quick release solution at some point Quote Link to comment Share on other sites More sharing options...
Thom Posted March 25, 2018 Share Posted March 25, 2018 1 hour ago, .AJ. said: They missed the fact that the average RC’er loves to fiddle and the shell/body should be easily removable, I’m sure someone with come up with a 3D printed quick release solution at some point Not even that. I just want to maintain it. Had a splash and already surface rust on the screws. It all needs a big coating of ACF-50. Quote Link to comment Share on other sites More sharing options...
tanveer Posted March 25, 2018 Share Posted March 25, 2018 Do these super baja reys run 8s lipo? been watching some vids and people seem to mention that its 8s capable. Hobby quater even uploaded a video of it drifting on 8s im just unsure. Quote Link to comment Share on other sites More sharing options...
Thom Posted March 26, 2018 Share Posted March 26, 2018 3 hours ago, tanveer said: Do these super baja reys run 8s lipo? been watching some vids and people seem to mention that its 8s capable. Hobby quater even uploaded a video of it drifting on 8s im just unsure. Yes they support 8S but recommendation is short runs due to 1200KV and heat. 8S has also wrecked tyres on a few, so you’ll be needing more or aftermarket 1 Quote Link to comment Share on other sites More sharing options...
mond Posted March 26, 2018 Share Posted March 26, 2018 Not sure 8S would be worth the strain on the truck. Would be good for run times on a lower KV motor. Can't see any point though. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted March 26, 2018 Author Share Posted March 26, 2018 The SBR does 50-55mph completely stock on 6s, I don’t think 8s is really needed and I won’t be trying it anytime soon Quote Link to comment Share on other sites More sharing options...
tanveer Posted March 26, 2018 Share Posted March 26, 2018 I'm in two minds, do I wait for my e Revo or call wheelspin and tell them iv changed my mind and want an SBR...decisions decisions. Quote Link to comment Share on other sites More sharing options...
