leontheprof Posted July 24, 2016 Share Posted July 24, 2016 Greetings, i have a max8 esc for a month now and in the last 2 runs my car stopped due to esc overheating (green flashing led on the esc). When the car stopped the esc's cooling fan was spinning but with very low RPM. I remember that the first time i calibrated the esc with the transmitter the fan was spinning like crazy...like 100% of its power. Since then i didn't really notice its performance until my esc stopped from overheating. Now my question is, is the fan supposed to run all the time? or its temperature triggered? Now when i cold start my car the fan spins for the first 1-2 secs and then stops. And if i run my car the fan still doesnt work 100% even if the esc is very hot. (60-70 C) I double checked that there isnt anything that blocks the fan, any dust or rock. Quote Link to comment Share on other sites More sharing options...
NuttyProfessor Posted July 24, 2016 Share Posted July 24, 2016 could try running the fan off the receiver to see if it keeps spinning, could be the BEC playing up. Quote Link to comment Share on other sites More sharing options...
sunny Posted July 24, 2016 Share Posted July 24, 2016 Fan should always be on you can always replace the fan individually just measure it up it will be something like 40mmx40mm or similar then you can get tornado fan just google tornado fan on ebay Quote Link to comment Share on other sites More sharing options...
losi8igh Posted July 24, 2016 Share Posted July 24, 2016 (edited) I found the ESC fans on both the Hobbywing ESCs I had to be mini tornadoes right from the first moment you switched them on,there was certainly no change in fan speed depending on temperature,it was full on all the time even when the ESC was cold. Edited July 24, 2016 by losi8igh Quote Link to comment Share on other sites More sharing options...
leontheprof Posted July 31, 2016 Author Share Posted July 31, 2016 i changed the fan and now works ok. Dimensions are 30x30x10mm 5v if the same happens to anyone else. Quote Link to comment Share on other sites More sharing options...
