Tug Posted July 6, 2020 Author Share Posted July 6, 2020 Ah, sounds like a possible result. Have you done that yet? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 6, 2020 Share Posted July 6, 2020 Na, I looked at doing a firmware update a while ago, but the instructions were all a bit vague, so I didnt bother, the last thing I want to do is brick a £350 esc Quote Link to comment Share on other sites More sharing options...
Tug Posted July 6, 2020 Author Share Posted July 6, 2020 I'll see what rccaronline says, then decide. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 8, 2020 Share Posted July 8, 2020 Did they get back to you? Quote Link to comment Share on other sites More sharing options...
Tug Posted July 8, 2020 Author Share Posted July 8, 2020 No, nothing. I used the contact form, do you know of a better method? Got a proper email addy? May just search online for the firmware, must be on the ZTW site? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 8, 2020 Share Posted July 8, 2020 The ZTW site is terrible, I used the contact us on RcCarOnline shop, but I have the same email chat going from over a year ago though, the guy I’ve been speaking to is called Steffen Quote Link to comment Share on other sites More sharing options...
Tug Posted July 8, 2020 Author Share Posted July 8, 2020 Cheers, might have to try again. Quote Link to comment Share on other sites More sharing options...
Tug Posted July 12, 2020 Author Share Posted July 12, 2020 Tried to fit KM rims c/w Pioneer rubber (Trencher copies) to the X2, turns out the inner rim is smaller than stock and they rub on the steering rod-end. Total fail. Just about fit the rear, but only just. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 12, 2020 Share Posted July 12, 2020 They are probably Baja rims, so the offset is wrong Quote Link to comment Share on other sites More sharing options...
Tug Posted July 12, 2020 Author Share Posted July 12, 2020 Plausible, but they shouldn't be listed as truck rims suitable for the 5ive and X2. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 12, 2020 Share Posted July 12, 2020 Got a link to the wheels? Quote Link to comment Share on other sites More sharing options...
Tug Posted July 12, 2020 Author Share Posted July 12, 2020 PTWPR is the part number, they're listed for the Baja truck, but it states they will work with the KM X2. I'll not lose sleep over it, life is way too short. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 26, 2020 Share Posted July 26, 2020 Did you ever get an answer about the 10s issue? Quote Link to comment Share on other sites More sharing options...
Tug Posted July 26, 2020 Author Share Posted July 26, 2020 Nope, didn't even reply. That's the main reason why this kind of thing is better purchased domestically, customer support. Modelsport just didn't have them in at the time. Coincidentally, tried a test run yesterday on 10S, it does still do it, but you can almost drive through it by blipping the throttle before each actual application of throttle. Not ideal, but it's better than nothing. That and the fact I can't afford an MGM, which are known for their own issues. Quote Link to comment Share on other sites More sharing options...
Tug Posted July 26, 2020 Author Share Posted July 26, 2020 Can't believe Castle are still not interested in a 12S ESC, there's a market, serve it! Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 26, 2020 Share Posted July 26, 2020 Just stick to 12s it is then! 😂 Quote Link to comment Share on other sites More sharing options...
Popular Post Tug Posted February 28, 2021 Author Popular Post Share Posted February 28, 2021 Some old footage I'd forgotten about. It ain't much, but better than nothing. 5 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 28, 2021 Share Posted February 28, 2021 that goes well mate do you still have it and did you up the pinion on it as mentioned in vid ? Quote Link to comment Share on other sites More sharing options...
Tug Posted February 28, 2021 Author Share Posted February 28, 2021 3 minutes ago, Stormbringer said: that goes well mate do you still have it and did you up the pinion on it as mentioned in vid ? Cheers! I'll be buried with this one, absolutely love it! So yes, still got it. No, same 18 tooth. Maybe try a twenty this year. 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 28, 2021 Share Posted February 28, 2021 cool mate mind you it does go quite well as is Quote Link to comment Share on other sites More sharing options...
locky Posted February 28, 2021 Share Posted February 28, 2021 Looking good, what are you using to measure motor temps? Quote Link to comment Share on other sites More sharing options...
Tug Posted February 28, 2021 Author Share Posted February 28, 2021 23 minutes ago, Stormbringer said: cool mate mind you it does go quite well as is Yeah, I'm happy with it for now, but for how long? 14 minutes ago, locky said: Looking good, what are you using to measure motor temps? Hobbyking purchase I think. Bought it years ago on a whim and never used it until now. Quite a nice bit of kit. 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 28, 2021 Share Posted February 28, 2021 is that the lcd display inside the car ? Quote Link to comment Share on other sites More sharing options...
Tug Posted February 28, 2021 Author Share Posted February 28, 2021 Just now, Stormbringer said: is that the lcd display inside the car ? Yeah, does voltage (which I don't use) and temp. Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted February 28, 2021 Share Posted February 28, 2021 cool Quote Link to comment Share on other sites More sharing options...
