Losi Mini 8ight-T arrived today
ninjagaiden
Ok first full 2s lipo and motor is hot but not as hot as I thought it would be :)
You can obv see the motor is the odd ball as it even looks too small for the Trugggy but it wasn't smoking hot just hot.
Now onto the lightweight outdrives and servo upgrade :)
No lipo came from Giantshark :)
I did however get a free Nimh lol
They will be on the FS section soon along with the Nimh charger :)
What're your thoughts on the overall feel of the plastics, turnbuckles etc? Does it feel like a tough basher? Is it worth the money?
Personally the turnbuckles pop off too easy but I would rather pop a turnbuckle than snap an arm ;) or an easy fix by upgrading the end cups :)
As for the feel of plastic I can say it feels stronger than the mini 8 and almost 100% easier to work on ;)
Bash wise will be hard to say really as I only run a 2s pack upto now and all that happened was a turnbuckle popped off when clipped a curb :)
That servo has been giving some one else trouble on rc tech forum, if I remember its to do with the digital compatibility of it
Well put 4x 2s packs through it and 3x 3s packs all within 5 mins of each other and apart from loosing a grub screw from a centre diff cup it's still going strong :)
Grub screw was my own fault so can't complain :) and as for temps I wouldn't have said it was any different running a 3s than a 2s other than the speed :) WOW! It flies hahaha
Edited by hebby
 You still running stock gearing ??
You must be the only guy that i have read about that has managed to run a 3s without  the thermal cut off kicking in, or did you turn it off??
What sort of surface's are you running on ??
