Emil Posted December 21, 2013 Share Posted December 21, 2013 Hi guys! My 2 years old MIni z ma-010 AWD wont reverse! i tried to re solder all those exposed wires and it wont work!! i need help!! Pls advice! Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted December 21, 2013 Share Posted December 21, 2013 you may need to replace the fets as one of them could have went pop take iot apart again and look Quote Link to comment Share on other sites More sharing options...
atom3624 Posted December 21, 2013 Share Posted December 21, 2013 Is there a 'race mode' that electronically blocks reverse? How did it happen? Did you lose reverse when playing with it? Al. Quote Link to comment Share on other sites More sharing options...
Emil Posted December 21, 2013 Author Share Posted December 21, 2013 @mini z awd : im new here. where to find the FETS?? @ atom : what do u mean by " race mode '? when i lift the throttle trigger to reverse , my car just wont respond. Only sometimes though. Quote Link to comment Share on other sites More sharing options...
atom3624 Posted December 21, 2013 Share Posted December 21, 2013 OK. Many RC vehicles have options on their transmitters. If people go racing at circuits, reverse is NOT permitted generally, so there are ways of selecting forwards only in the transmitter options. It sounds like this has happened whilst you've been using it, so its not the case. Have the transmitter batteries been there a long time / has it been used a lot / has it been left on? Are the batteries discharged? Al. Quote Link to comment Share on other sites More sharing options...
PurcyP Posted December 21, 2013 Share Posted December 21, 2013 Hi guys! My 2 years old MIni z ma-010 AWD wont reverse! i tried to re solder all those exposed wires and it wont work!! i need help!! Pls advice! O_o id take it to your local hobby shop and have them take a look at it 1 Quote Link to comment Share on other sites More sharing options...
atom3624 Posted December 21, 2013 Share Posted December 21, 2013 O_o id take it to your local hobby shop and have them take a look at it Good point. Al. Quote Link to comment Share on other sites More sharing options...
Emil Posted December 21, 2013 Author Share Posted December 21, 2013 Thanks atom but i think mini z ma 010 doesnt have that function. Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted December 21, 2013 Share Posted December 21, 2013 @mini z awd : im new here. where to find the FETS?? @ atom : what do u mean by " race mode '? when i lift the throttle trigger to reverse , my car just wont respond. Only sometimes though. here is a pic i`ve marked the fets in blue if you take your board out check them to see if one or even both have any damage also while you have the board out look for any broken wires Quote Link to comment Share on other sites More sharing options...
R46 Posted December 21, 2013 Share Posted December 21, 2013 (edited) which board running Am or 2.4 asf? Edited December 21, 2013 by R46 Quote Link to comment Share on other sites More sharing options...
rc guyyy Posted May 8, 2019 Share Posted May 8, 2019 emil i have the same problem i also have a ma 010 Quote Link to comment Share on other sites More sharing options...
R46 Posted May 20, 2019 Share Posted May 20, 2019 (edited) On 08/05/2019 at 01:33, rc guyyy said: emil i have the same problem i also have a ma 010 Hold brake/ reverse for 2sec like then reverse activates Edited May 20, 2019 by R46 Quote Link to comment Share on other sites More sharing options...
jasonmc2 Posted August 4, 2022 Share Posted August 4, 2022 (edited) I have the same problem with my mini-z MA-030EVO I cant go in reverse at all at the start it worked, then I was about to take the back of the car of to put the DWS on but I Chickened out it felt a bit hard for me I'm just new to RC so I put the screws to the back end back on top and bottom, then after that no reverse? Can any one help me I'm such a noob I should have just left it alone!.. wish I did. ok guys I just worked out what the problem was it was my NB4 I must of pressed a button and it made it so the reverse wouldn't engage sorry to bother any one? and maybe any one ells has a reverse problem it might not hert to check out your transmitter lol Edited August 4, 2022 by jasonmc2 1 Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted August 4, 2022 Share Posted August 4, 2022 Good that you found what was wrong 1 Quote Link to comment Share on other sites More sharing options...
Yrkoon Posted August 5, 2022 Share Posted August 5, 2022 (edited) . Edited August 5, 2022 by Yrkoon Quote Link to comment Share on other sites More sharing options...
