stupar Posted September 13, 2005 Share Posted September 13, 2005 I have fitted a Reedy modified Mini Max motor into my RC18T. Can anyone tell me what ESC will fit directly onto the pre soldered wires of this motor. If none fit directly, what soldering/wiring will be required e.g plugs etc! Quote Link to comment Share on other sites More sharing options...
4_cell_racer Posted September 13, 2005 Share Posted September 13, 2005 I have fitted a Reedy modified Mini Max motor into my RC18T. Can anyone tell me what ESC will fit directly onto the pre soldered wires of this motor. If none fit directly, what soldering/wiring will be required e.g plugs etc! ← What do the wire look like? are they a block or spade type of connector? If your any good with the solder iron....I would do away with the connectors off the motor, and solder the motor wires (from the speedo) direct to the motor Quote Link to comment Share on other sites More sharing options...
stupar Posted September 13, 2005 Author Share Posted September 13, 2005 They are spade connectors Quote Link to comment Share on other sites More sharing options...
4_cell_racer Posted September 13, 2005 Share Posted September 13, 2005 They are spade connectors ← I think the 18T has spade conns fitted to the kit speedo...so you should be alright Quote Link to comment Share on other sites More sharing options...
stupar Posted September 14, 2005 Author Share Posted September 14, 2005 I bought the factory team kit so i Dont have the kit speedo Quote Link to comment Share on other sites More sharing options...
Tamiyacowboy Posted September 14, 2005 Share Posted September 14, 2005 I bought the factory team kit so i Dont have the kit speedo ← deans use these to fit motor also makes for easy removal ESC: most if not any 1/10th scale esc will fit in a micro, it is just making space for it. suitable ones will be the futaba mrc330cr this little esc will handle any motor you care to put in your micro except a brushless motor. others include the SPY esc, novak, what the hell even a no limit Xtra ripmax esc now thats . the best thing with a micro is the things you can stick in them, i would sugest a metal geared servo something like the hi tec hs55 or the 8* range in micro servos TC Quote Link to comment Share on other sites More sharing options...
