Zyphruk Posted January 30, 2024 Share Posted January 30, 2024 HI all, Im after some help, i have an element enduro SE 325mm wheel base and i have bought a 275mm wheelbase body, Ideally i only want to shorten the rear links is there a way of figuring out what size links i need? TIA Quote Link to comment Share on other sites More sharing options...
wombat Posted January 30, 2024 Share Posted January 30, 2024 Would it work, in effect you want to move the rear axle forwards by 50mm, which will mean shortening the prop shaft by the same amount and repositioning the shock absorbers Quote Link to comment Share on other sites More sharing options...
Zyphruk Posted January 30, 2024 Author Share Posted January 30, 2024 turns out cant be done as it puts the propshaft at too steep of an angle, just ordered a new body instead 😛 Quote Link to comment Share on other sites More sharing options...
Lone-wolf Posted January 31, 2024 Share Posted January 31, 2024 7 hours ago, Zyphruk said: turns out cant be done as it puts the propshaft at too steep of an angle, just ordered a new body instead 😛 what body is the 275mm one, might fit my coyote Quote Link to comment Share on other sites More sharing options...
Zyphruk Posted February 1, 2024 Author Share Posted February 1, 2024 On 31/01/2024 at 05:25, Lone-wolf said: what body is the 275mm one, might fit my coyote its the rockee mate Quote Link to comment Share on other sites More sharing options...
