Posted (edited)
Build thread for my e Revo V1 to V2
After owning a very unreliable Revo 2.5r as a child I always fancied another Revo but never got round to getting one, I finally have and will have the fun of building it!
V2 components & new bits
Front & rear arms
Front & rear drive shafts
Transmission drive shafts
Steering links
Front & rear skid plates
Front & rear diffs - the main reason for the build!
Chassis
Hobbywing max Max 8
Hobbywing 2200kv motor
Proline 3.8 trenchers
Traxxas 15t pinion
Traxxas 65t spur
V1 components
Rear wing
Front and rear bumper
Transmission
Shocks
Servos
Shell
Body mounts
Rockers etc
Think I have all the bits, will update if any others are needed.
Edited by helsinki98
Posted
Is the chassis different? That has to be changed too? I was hoping it was just the bulkheads needed in order to change to the newer diffs.
Posted (edited)
Unfortunately so, the diffs are within the bulkheads of the 2.0 where as the 1.0 the difs have a houseing inside the of bulkheads. The 2.0 diffs are also much larger thankfully but mean there is a slight bulge in the chassis to accommodate the larger diffs
You also have to change the drive shafts due to the huge drive cups on the new diffs, which also means new knuckles & bearings, the arms can be re used and the center drive shafts can be re used although a put the new ones on with the V1 transmission I had to cut the front center drive shaft down as the V1 transmission connector bits are longer than the v2
  • 4 years later...
