Arif Posted May 30, 2016 Share Posted May 30, 2016 (edited) Carpmart - the turbine's now Wren's flagship engine - the DC100 iKero. It puts out 10.2kg of thrust, idles at 45,000rpm, & maxes out at 160,000rpm. It's starter motor is brushless (in that little aluminium cap you can see), as is its fuel pump. The electronic gubbins is called FADEC - Full Authority Digital Engine Control - & manages everything from start-up to shut-down. All running gear has been removed, & has no brakes. It runs on normal paraffin, dosed with helicopter turbine oil (5%). Edited May 30, 2016 by Arif Further details 2 Quote Link to comment Share on other sites More sharing options...
Arif Posted May 30, 2016 Share Posted May 30, 2016 I've just bumped my original 2014 thread on this forum, for anyone interested in the jet car project. Apologies - it does ramble, does divert to the fuller write-up on Pistonheads - & any decent video will come when I meet up with Norco next! Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 2, 2016 Author Share Posted June 2, 2016 Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 4, 2016 Author Share Posted June 4, 2016 (edited) Well I have finally speced the engine i will be building for the 5ive and I thought this would be a good time to list the upgrades into sections Electrics Spektrum DX4S Spektrum SR410 rx Spektrum S9010 throttle servo Spektrum S9010 steering servo Etronix cap pack Killer rc lights X4 Engine Gzr billet Crankcase ESP 30.5 championship ported head Zenoah coated piston +2mm stuffed stroker crank Walbro 668 carb Team fast eddy carb filter Dogpile Alloy coil pack spacer Zenoah pullstart Team go nads alloy handle RBI clutch cooling plate CY lightened clutch 8k spring lightened flywheel DDM velocity stack DT1 airfilter Pullstart outerware Air filter outerware Crankcase outerware Bartolone billet clutch holder Bartolone billet clutch carrier Bartalone billet mesh plate Vertigo hex clutch bell Vertigo 20t pinion Vertigo 20t engine spacers Billet fan cover DDM pro linkage Killer rc fuel lines Full force Rc brass fittings Bartalone xp exhaust Killer rc superbee Hostile choke lever Mip exhaust gasket Stage 8 locking exhaust bolts Heavy duty gaskets Tygon fuel line Chassis Team chase bumper Craftwerks billet light covers Bartolone front and rear skid plates Rc decals chassis skin Alloy front gearbox mount DDM alloy top plate Turtle racing alloy chassis braces Alloy fuel cap Team fast eddy jam nuts Team chase ackerman plate Fonzie steering linkage Hot racing throttle and brake horn Modified Rc centre diff Team fast eddy Hardened centre diff cups Rcr full brake kit Alloy rear cage mount Bartolone cage panels Outerwares for cage Fullforce read mudguards Outerwares shock socks Fonzie rc alloy shock ends Alloy rear shafts guards Snappy rc cage tethers Alloy body mounts 30°N basher shell Custom painted grafil extreme g shell (show only) Alloy rear mudflap emblems Alloy rear mudflaps holders Triple a racing rear wing DDM body trim Hot racing sway bars and alloy holders Craftwerks extenders Spiked wheel nuts Ice racing wheel nuts Vertigo qr tank posts Hot racing rear alloy plates. DDM extra hard springs all round Rok armour brake brace Losi rc lightened stub axles all round Losi alloy servo saver Dirty danglers Magic spoon Wheels and tyres Hostile slicks Proline trenchers Km mx copies Silverback beringi wheels Silverback 5imian wheels Proline split six wheels Silver back beadlocks Ice racing alloy beadlocks Edited June 9, 2016 by norcoforever Quote Link to comment Share on other sites More sharing options...
Tug Posted June 4, 2016 Share Posted June 4, 2016 It'll be less of a 5ive than mine! Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 4, 2016 Author Share Posted June 4, 2016 2 minutes ago, Tug said: It'll be less of a 5ive than mine! It's only now I've listed it all I've realised how far from standard I've drifted lmfao Quote Link to comment Share on other sites More sharing options...
Carpmart Posted June 4, 2016 Share Posted June 4, 2016 2 hours ago, norcoforever said: It's only now I've listed it all I've realised how far from standard I've drifted lmfao That hop up list is not 'drifting' away from stock, that's rocketing away faster than AJ Loverings rocket car! 1 Quote Link to comment Share on other sites More sharing options...
andyknight Posted June 4, 2016 Share Posted June 4, 2016 (edited) Why buy a long block and esp head, you can buy a complete esp motor for less then it would be to build it from parts? Thatis pretty much the spec I am going for when I get round to doing it. I keep holding off as my km runs so good at the moment. Edited June 4, 2016 by andyknight Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 4, 2016 Author Share Posted June 4, 2016 2 minutes ago, andyknight said: Why buy a long block and esp head, you can buy a complete esp motor for less then it would be to build it from parts? Thatis pretty much the spec I am going for when I get round to doing it. I keep holding off as my km runs so good at the moment. I'm only using the coil from a normal engine everything else is an upgrade so it's cost me about £80 less to build an esp longblock compared to buying an esp engine Quote Link to comment Share on other sites More sharing options...
andyknight Posted June 4, 2016 Share Posted June 4, 2016 1 minute ago, norcoforever said: I'm only using the coil from a normal engine everything else is an upgrade so it's cost me about £80 less to build an esp longblock compared to buying an esp engine Good stuff, I won't be going quite as far as you although I'm still in 2 minds over the type of esp head, torque or rev? 1 Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 4, 2016 Author Share Posted June 4, 2016 1 minute ago, andyknight said: Good stuff, I won't be going quite as far as you although I'm still in 2 minds over the type of esp head, torque or rev? I had the same dilemma but went for torque as absolute top speed isn't that important for me but acceleration is so torque is more important. I'm still toying with the idea of a 9.5k clutch spring as well but I'm thinking that may be ott Quote Link to comment Share on other sites More sharing options...
Carpmart Posted June 4, 2016 Share Posted June 4, 2016 10 minutes ago, andyknight said: Why buy a long block and esp head, you can buy a complete esp motor for less then it would be to build it from parts? Thatis pretty much the spec I am going for when I get round to doing it. I keep holding off as my km runs so good at the moment. Andy, Andy, Andy.... You've jinxed youself now! 1 Quote Link to comment Share on other sites More sharing options...
andyknight Posted June 4, 2016 Share Posted June 4, 2016 (edited) 5 minutes ago, Carpmart said: Andy, Andy, Andy.... You've jinxed youself now! Yeah, I have a spare head , piston, gaskets and plugs so I can do a trackside rebuild if I have to! Edited June 4, 2016 by andyknight 1 Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 5, 2016 Author Share Posted June 5, 2016 Had a great bash with saviown today. Have discovered my exhaust needs the end re riveting and my engine is cracked :/ good job I was changing lol 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 5, 2016 Share Posted June 5, 2016 What part of the engine did you crack? Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 5, 2016 Author Share Posted June 5, 2016 2 minutes ago, .AJ. said: What part of the engine did you crack? The part directly behind the flywheel. It's cracked down an entire side. Suspect it either happened or caused my flywheel falling off issue the other week. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 5, 2016 Share Posted June 5, 2016 May be worth looking at a billet crankcase for your new engine 1 Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 5, 2016 Author Share Posted June 5, 2016 4 minutes ago, .AJ. said: May be worth looking at a billet crankcase for your new engine I suspect it's the exhaust that caused the issues as it's mounted to the fancover and crank case. Considering a Bartalone pipe at this point Quote Link to comment Share on other sites More sharing options...
saviown Posted June 5, 2016 Share Posted June 5, 2016 14 minutes ago, norcoforever said: Had a great bash with saviown today. Have discovered my exhaust needs the end re riveting and my engine is cracked :/ good job I was changing lol was great according to my gps I did 2.24 miles on the 1st run, you must of done easily 3-4 times that much, maybe even more, great looking truck, 1st time iv'e seen a losi 5 close up, performed very well 1 Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted June 5, 2016 Share Posted June 5, 2016 Quick question chap, that brace that sits on your throttle servo, not sure what brand it is, also, can that be used with a stock centre diff mounts? Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 5, 2016 Author Share Posted June 5, 2016 9 minutes ago, Oh How Original said: Quick question chap, that brace that sits on your throttle servo, not sure what brand it is, also, can that be used with a stock centre diff mounts? It's a rok armour brace and absolutely it was designed around the stock kit 1 Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted June 5, 2016 Share Posted June 5, 2016 8 minutes ago, norcoforever said: It's a rok armour brace and absolutely it was designed around the stock kit Any chance you've got a link handy at all chap? Can't seem to locate rok armour products Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 5, 2016 Author Share Posted June 5, 2016 5 minutes ago, Oh How Original said: Any chance you've got a link handy at all chap? Can't seem to locate rok armour products http://www.freeprawnracing.co.uk/rc-rock-armor-losi-5ive-t-brake-brace-rra015tb.html There you are buddy 1 Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted June 5, 2016 Share Posted June 5, 2016 10 minutes ago, norcoforever said: http://www.freeprawnracing.co.uk/rc-rock-armor-losi-5ive-t-brake-brace-rra015tb.html There you are buddy Ta muchly! 1 Quote Link to comment Share on other sites More sharing options...
norcoforever Posted June 14, 2016 Author Share Posted June 14, 2016 Time for an update after a small incident with a stock longblock I have built myself a 30.5 torque tuned esp championship ported engine.still in the process of running in however did achieve a good bash with a group of guys from on here car ran almost faultlessly aside from an issue with the linkage jamming seemingly due to the alloy throttle parts so I've reverted back to plastic and all seems good I have also fitted an electronic on off switch. Just waiting for payday to order my new exhaust 1 Quote Link to comment Share on other sites More sharing options...
