jayjaymozza Posted November 14, 2015 Share Posted November 14, 2015 Hi, I took my yama buggy out for the first time today (bought it second hand) it seems to run okay when giving alot of throttle although a little to much smoke, but when I give it little throttle it seems to bog / go to die until more throttle is giving. I have tried the low speed screw but still no luck. Any ideas ? Thanks Quote Link to comment Share on other sites More sharing options...
Gaz! Posted November 15, 2015 Share Posted November 15, 2015 What ratio fuel/oil you using? Lots of smoke points to running too much oil or running rich I think.....you could try going back to factory settings and go from there.... Quote Link to comment Share on other sites More sharing options...
jayjaymozza Posted November 15, 2015 Author Share Posted November 15, 2015 Go back to factory settings on the card? Quote Link to comment Share on other sites More sharing options...
fletch101 Posted November 15, 2015 Share Posted November 15, 2015 Check oil fuel mix is right and id say try learning off high speed screw a bit Give it a good warm up and blast out before tuning though and small movements at a time Speaking from general carb setting. Not had much experience with mine yet. Hoping too give it good run tomorrow in anger lol Quote Link to comment Share on other sites More sharing options...
andyknight Posted November 15, 2015 Share Posted November 15, 2015 Bogging at initial pull off is normally too rich on the lsn, particularly if you're not on full throttle. Quote Link to comment Share on other sites More sharing options...
jayjaymozza Posted November 16, 2015 Author Share Posted November 16, 2015 Ended up changing fuel and putting some fresh 32:1 mixed in, also changed the low and high speed screws back to factory, seems to have done the trick. Just need to fix the tick over a little now Thanks Quote Link to comment Share on other sites More sharing options...
Jays-bond Posted November 19, 2015 Share Posted November 19, 2015 Did you get this sorted bud..? Quote Link to comment Share on other sites More sharing options...
flatout! Posted December 12, 2015 Share Posted December 12, 2015 Not if he was running 32.1 lol! Smoking a bit was it? Hope ya sorted it pal ? Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted December 12, 2015 Share Posted December 12, 2015 I thought 32:1 seemed odd. Quote Link to comment Share on other sites More sharing options...
flatout! Posted December 12, 2015 Share Posted December 12, 2015 Pmsl! Lol! Can only advice using the 25.1, ? hows Dan? Quote Link to comment Share on other sites More sharing options...
mark35 Posted December 12, 2015 Share Posted December 12, 2015 32/1 is less oil to petrol incase you didn't know??? Quote Link to comment Share on other sites More sharing options...
flatout! Posted December 17, 2015 Share Posted December 17, 2015 Mmm these things burn oil so less than what it's supposed to have it would get a bit warm wouldn't it, bit of friction going on I bet lol! I'll stick to the 25.1 Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted December 17, 2015 Share Posted December 17, 2015 32:1 would not cause any long term harm and should run fine. The oil is to lubricate the bearings and friction surfaces. It's burnt because it ends up in the combustion chamber. Quote Link to comment Share on other sites More sharing options...
Jays-bond Posted December 18, 2015 Share Posted December 18, 2015 Oil/ fuel mixture isn't really the cause for the bogging down... I'd say it was over fueling.. id also stick to the manufacturer recommended ratio of 1/25.. Quote Link to comment Share on other sites More sharing options...
ROBSTER 1992 Posted December 18, 2015 Share Posted December 18, 2015 Oil/ fuel mixture isn't really the cause for the bogging down... I'd say it was over fueling.. id also stick to the manufacturer recommended ratio of 1/25.. You mean 25:1 Quote Link to comment Share on other sites More sharing options...
Jays-bond Posted December 18, 2015 Share Posted December 18, 2015 Spot on..! Think it would be rather smoky that other way round.. ? Quote Link to comment Share on other sites More sharing options...
