Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 30-40 maybe...never believe what they print on the box's. ..lol!!but if u play around with the gearing then it will go faster..use 3s lipos ect...but will shorten it's life if all u do is speed runs everywere.... i will be on dirt thats dry too, when charging a lipo you put the balance connector in and the two newgative/positive into the deans connector right? Also is this a good sort of helping guide? http://www.msuk-forum.co.uk/topic/21028-lipo-the-big-guide-thread-updated-march-10/ Link to comment Share on other sites More sharing options...
evssv Posted June 14, 2015 Share Posted June 14, 2015 i will be on dirt thats dry too, when charging a lipo you put the balance connector in and the two newgative/positive into the deans connector right? Also is this a good sort of helping guide? http://www.msuk-forum.co.uk/topic/21028-lipo-the-big-guide-thread-updated-march-10/yes...I always connect both up....and yes that's a good read ffor sure Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 yes...I always connect both up....and yes that's a good read ffor sure ok, got the bag aswell, dont want to burn my house down, does the firestorm have a low voltage cutoff? Link to comment Share on other sites More sharing options...
evssv Posted June 14, 2015 Share Posted June 14, 2015 ok, got the bag aswell, dont want to burn my house down, does the firestorm have a low voltage cutoff?I'm guessing the new one has a lvc 2 Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 I'm guessing the new one has a lvc ok any tips for maintaining and using an high grade rc for the first time? Link to comment Share on other sites More sharing options...
Deafty Posted June 14, 2015 Share Posted June 14, 2015 Clean after use 2 Link to comment Share on other sites More sharing options...
Noj Posted June 14, 2015 Share Posted June 14, 2015 Not with bleach. 2 Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 Not with bleach. Clean after use anything else? Link to comment Share on other sites More sharing options...
Deafty Posted June 14, 2015 Share Posted June 14, 2015 lol Noj. Check bearings Shocks Diffs Drivetrain If in doubt strip her out. 2 Link to comment Share on other sites More sharing options...
evssv Posted June 14, 2015 Share Posted June 14, 2015 (edited) and when u take it out the box...chk every nut bolt Allen head as sum will b not quite tight enuff before u run it....once u've done this. ..go bash it....buy ur self a few tins of gt85 spray.....and use regularly in ur cleaning routine....never put it away wet...rusty nuts don't look good when sell time comes. ... Edited June 14, 2015 by evssv 1 Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 and when u take it out the box...chk every nut bolt Allen head as sum will b not quite tight enuff before u run it....once u've done this. ..go bash it....buy ur self a few tins of gt85 spray.....and use regularly in ur cleaning routine....never put it away wet...rusty nuts don't look good when sell time comes. ... whats gt85 spray? Link to comment Share on other sites More sharing options...
evssv Posted June 14, 2015 Share Posted June 14, 2015 whats gt85 spray? http://pages.ebay.com/link/?nav=item.view&id=311270107812&alt=web better then WD40 and smells better imo Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 http://pages.ebay.com/link/?nav=item.view&id=311270107812&alt=web better then WD40 and smells better imo use this on the nuts and bolts and screws etc..? Link to comment Share on other sites More sharing options...
supersavage Posted June 14, 2015 Share Posted June 14, 2015 ok, got the bag aswell, dont want to burn my house down, does the firestorm have a low voltage cutoff? Yes it has an auto cut off but the esc can be programmed and there is a guide in the manual if you need to change any of the settings on the esc.ok, got the bag aswell, dont want to burn my house down, does the firestorm have a low voltage cutoff? Yes it has an auto cut off but the esc can be programmed and there is a guide in the manual if you need to change any of the settings on the esc. 1 Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 Yes it has an auto cut off but the esc can be programmed and there is a guide in the manual if you need to change any of the settings on the esc. Yes it has an auto cut off but the esc can be programmed and there is a guide in the manual if you need to change any of the settings on the esc. you have the hpi i see, anything you personally think i should know and what speeds on a 2s? Link to comment Share on other sites More sharing options...
supersavage Posted June 14, 2015 Share Posted June 14, 2015 you have the hpi i see, anything you personally think i should know and what speeds on a 2s? I only got mine Tuesday so still getting used to it but there's a very good thread in the electric section for all thing E Firestorm. I can't tell you how fast it is as I don't have a way of measuring the speed. But I quickly found out that its worth fitting the included wheelie bar as it likes pointing its nose at the sky or sliding down the road on its back lol. 1 Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 I only got mine Tuesday so still getting used to it but there's a very good thread in the electric section for all thing E Firestorm. I can't tell you how fast it is as I don't have a way of measuring the speed. But I quickly found out that its worth fitting the included wheelie bar as it likes pointing its nose at the sky or sliding down the road on its back lol. i will look for the thread Link to comment Share on other sites More sharing options...
supersavage Posted June 14, 2015 Share Posted June 14, 2015 Here's the thread http://www.msuk-forum.co.uk/topic/109667-the-e-firestorm-thread/ Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 Here's the threadhttp://www.msuk-forum.co.uk/topic/109667-the-e-firestorm-thread/ thanks, is this battery ok in the c rating for the flux http://www.modelsport.co.uk/nvision-7.4v-sport-lipo-3700-45c-deans-/rc-car-products/380174 Link to comment Share on other sites More sharing options...
Relativenewbyseb Posted June 14, 2015 Share Posted June 14, 2015 (edited) I'd still go turnigy batteries as you get much more for your money and they're tried and tested on here Anything 30c and 4000mah plus is fine for the firestorm but get as high capacity and c rating that'll fit (dimensions of battery tray in firestorm thread) with the view to being able to use them in larger 1/8 scale if/when you upgrade You can get them around 12 quid from hobbyking. ... Edited June 14, 2015 by Relativenewbyseb Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 I'd still go turnigy batteries as you get much more for your money and they're tried and tested on here Anything 30c and 4000mah plus is fine for the firestorm but get as high capacity and c rating that'll fit (dimensions of battery tray in firestorm thread) with the view to being able to use them in larger 1/8 scale if/when you upgrade You can get them around 12 quid from hobbyking. ... i cant find any with a deans connector built in? Link to comment Share on other sites More sharing options...
Prokart2000 Posted June 14, 2015 Author Share Posted June 14, 2015 the nvision one looks ok 45c 3700mah Link to comment Share on other sites More sharing options...
Relativenewbyseb Posted June 14, 2015 Share Posted June 14, 2015 Soldering is an essential skill really, yeah it looks ok but you can get just as good, if not better specs for less than half the price so then you have 2 to prolong runtime Link to comment Share on other sites More sharing options...
Noj Posted June 14, 2015 Share Posted June 14, 2015 Surprised no one has yet mentioned the adaptor...from deans to 'x' on whichever hobbyking packs you decide upon. Solves the soldering issue, will carry the current, problem solved. Link to comment Share on other sites More sharing options...
evssv Posted June 14, 2015 Share Posted June 14, 2015 use this on the nuts and bolts and screws etc..?yep.. . spray it ever where apart from the tyres and slipper but that's covered anyway. .. Link to comment Share on other sites More sharing options...
