evssv Posted February 27, 2015 Author Share Posted February 27, 2015 (edited) Mine is exactly the same Mike, a bit sloppy. In fact there is loose play all over (wheels, steering). I think I'll have to invest in a full set of bearings as well!fair nuff...I'll keep eye on it .Although when I do the alza swap I will do the rubber o rings in the cups to take up any play there....u got urs going again yet?? Edited February 27, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
tingtong333 Posted February 27, 2015 Share Posted February 27, 2015 http://www.modelsport.co.uk/hobbywing-quicrun-wp8bl150-bl-esc/rc-car-products/382834 I'm gonna give this a try, it arrived today. Quote Link to comment Share on other sites More sharing options...
fornowagain Posted February 27, 2015 Share Posted February 27, 2015 (edited) http://www.modelsport.co.uk/hobbywing-quicrun-wp8bl150-bl-esc/rc-car-products/382834 I'm gonna give this a try, it arrived today. That's the one on mine, be aware you can only program it with the led box. The LCD/PC box doesn't work, yet. I'm guessing there will be an firmware update eventually. Paid Edited February 27, 2015 by fornowagain Quote Link to comment Share on other sites More sharing options...
tingtong333 Posted February 27, 2015 Share Posted February 27, 2015 That's the one on mine, be aware you can only program it with the led box. The LCD/PC box doesn't work, yet. I'm guessing there will be an firmware update eventually. Paid Quote Link to comment Share on other sites More sharing options...
evssv Posted February 28, 2015 Author Share Posted February 28, 2015 (edited) Yep got one, going to run on 4s for now until I've fitted new bearings all round as my Savage Flux doesn't like new ESC's for some reason!!!.lol..Hopefully this new one lasts for u.... .longer then a pack.... . Edited February 28, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
jordan_bench10 Posted March 1, 2015 Share Posted March 1, 2015 (edited) The play in the wheels can be shinmed out by adding washers on the drive cup behind the rear bearing of each hub Play in the staleering is normally down to wear on tie rod ball joints and slight slop from servos This slight slop on the servo grows through the steering components and makes it look like a huge wobble when its only a tiny bit on the servo lol Edited March 1, 2015 by jordan_bench10 Quote Link to comment Share on other sites More sharing options...
evssv Posted March 1, 2015 Author Share Posted March 1, 2015 I got new steering set up on the way....I'll see what I can do with the axles when it's a apart. .....spouse nothing I can do with the rods ends apart from new ones I'm guessing... Quote Link to comment Share on other sites More sharing options...
evssv Posted March 3, 2015 Author Share Posted March 3, 2015 (edited) I got me hd servo spring and now this lot just waiting on the rest now..rear tie delets..fr hubs an carriers..and steering bell crank...an me hd gear.. Edited March 3, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 4, 2015 Author Share Posted March 4, 2015 (edited) Where do I start.... Edited March 4, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
scotty1986 Posted March 4, 2015 Share Posted March 4, 2015 with the stella Quote Link to comment Share on other sites More sharing options...
evssv Posted March 4, 2015 Author Share Posted March 4, 2015 (edited) The centre box is now done..fresh bearings all round. hd gear fitted..cut ends off of the battery boxes to keep cables tidy and slipper locker fitted ...and gonna wait till i got the rest of me parts before i do the alza swap I thk...at least I can run it now...With no issues hopefully! ! It's sounds so much better now that gears been replaced when u push it long... Edited March 4, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
jordan_bench10 Posted March 4, 2015 Share Posted March 4, 2015 Flip your battery boxes around will be so much easier to get em in / out Quote Link to comment Share on other sites More sharing options...
evssv Posted March 4, 2015 Author Share Posted March 4, 2015 I'll see how it goes....seems ok this way but I've only put em in n out a few times up to now.... Quote Link to comment Share on other sites More sharing options...
evssv Posted March 5, 2015 Author Share Posted March 5, 2015 (edited) jus had these turn up... really need the ally bell crank so I can get on with the swap.... but I'll get these fitted tonight probably Edited March 5, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 5, 2015 Author Share Posted March 5, 2015 (edited) so I got these fitted. ...found jus enuff shims to take up the play in the axials...amazing what difference that thin bit of metal makes...New bearings all round....job done!! Edited March 5, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
Tug Posted March 5, 2015 Share Posted March 5, 2015 I think you need the middle hole, not the top hole. Quote Link to comment Share on other sites More sharing options...
evssv Posted March 5, 2015 Author Share Posted March 5, 2015 (edited) I think you need the middle hole, not the top hole.yeah I moved em after this shot once the wheels were on...did try the bottom one but to much camber then... Edited March 5, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
fornowagain Posted March 5, 2015 Share Posted March 5, 2015 so I got these fitted. ...found jus enuff shims to take up the play in the axials...amazing what difference that thin bit of metal makes...New bearings all round....job done!! Make sure those purple spacers there can still turn a wee bit with the hexes done up tight, otherwise your new bearings won't last long. Quote Link to comment Share on other sites More sharing options...
evssv Posted March 5, 2015 Author Share Posted March 5, 2015 Make sure those purple spacers there can still turn a wee bit with the hexes done up tight, otherwise your new bearings won't last long.good point....I'll chk later. .. Quote Link to comment Share on other sites More sharing options...
evssv Posted March 7, 2015 Author Share Posted March 7, 2015 Make sure those purple spacers there can still turn a wee bit with the hexes done up tight, otherwise your new bearings won't last long.jus checked em and they both turn but r not loose. ... Make sure those purple spacers there can still turn a wee bit with the hexes done up tight, otherwise your new bearings won't last long.jus checked em and they both turn but r not loose. ... Quote Link to comment Share on other sites More sharing options...
evssv Posted March 8, 2015 Author Share Posted March 8, 2015 jus won this for when i do me xl chassis swap http://pages.ebay.com/link/?nav=item.view&id=261796686209&alt=web Quote Link to comment Share on other sites More sharing options...
evssv Posted March 8, 2015 Author Share Posted March 8, 2015 (edited) so jus been out for the first run and all was sweet until the motor moved forward unmeshing itself ...so reset it...and it went again. ..an again...so Im home now to sort the problem. ....which I assume I need to take a mm if that of the 2 bits the mount clamps down on....the hollow bits the long bolts go through... Edited March 8, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
Wrighty8766 Posted March 8, 2015 Share Posted March 8, 2015 so jus been out for the first run and all was sweet until the motor moved forward unmeshing itself ...so reset it...and it went again. ..an again...so Im home now to sort the problem. ....which I assume I need to take a mm if that of the 2 bits the mount clamps down on....the hollow bits the long bolts go through... Is it a leopard motor? They are 39.8mm in diameter compared to the torks 40mm Quote Link to comment Share on other sites More sharing options...
evssv Posted March 8, 2015 Author Share Posted March 8, 2015 (edited) Is it a leopard motor? They are 39.8mm in diameter compared to the torks 40mmyep...4274 2000kv ..so if I take a bit off these it should sort my problem out?? Edited March 8, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
Wrighty8766 Posted March 8, 2015 Share Posted March 8, 2015 yep...4074 2000kv ..so if I take a bit off these it should sort my problem out?? Either that or just wrap a little electricians tape around the motor! I think if you shave some off the posts then it will egg the mount a bit and it won't sit tight all the way around the motor Quote Link to comment Share on other sites More sharing options...
