.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 And shouldn't cost too much to get running Ezrun 35a - Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 Roller finished 2 Quote Link to comment Share on other sites More sharing options...
Badkad Posted June 28, 2013 Share Posted June 28, 2013 Looking forward to the electrics install Quote Link to comment Share on other sites More sharing options...
silone74 Posted June 28, 2013 Share Posted June 28, 2013 I think the 4 pole motor that comes in the rtr looks to be a good one from the off Si Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 That's my thinking too, I've yet to here a bad word about the motor and also Schumacher have stock, so easy enough to get hold of Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted June 28, 2013 Share Posted June 28, 2013 Quote Link to comment Share on other sites More sharing options...
silone74 Posted June 28, 2013 Share Posted June 28, 2013 I think if it where me the 4 pole would be the one over the black mantis but it would be good to have both to compare lol. I like the way lc racing have made it a standard 28mm can size for this. Si Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 It certainly leaves the option open for motor sizes, I'm now sold on the LC motor, I'll be ordering one Monday And now for the final pic The shell is cool, but I'm going to change the wing for something bigger, I've got a pair of LMR Electra wings on the way for the XB4 so I'll probably try one of them 2 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 Does the kit come with the servo and 3 pinions? Or did you order them at the same time from APEX? They came in the kit Quote Link to comment Share on other sites More sharing options...
silone74 Posted June 28, 2013 Share Posted June 28, 2013 It will be good to see what space there is with a bigger esc on the top deck,i run the 35a in the m8 and its a tight fit but then there looks to be more space when the 4 pole is fitted to house the esc down at the end of the motor if the body shape allows it? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 It hard to tell until I try to fit stuff, I had a similar problem in my Shark LWB, so I ended up running smaller 1300mah packs and mounting the esc in the extra space in the battery tray, I'll go find a pic Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 Quote Link to comment Share on other sites More sharing options...
silone74 Posted June 28, 2013 Share Posted June 28, 2013 I use smaller batts in mine but still mount the esc on the top deck with no fan on and i use the small orange rx that fits perfectly at the end of the motor its just too tight fit to have the esc where i have the rx or i would mount it there on the m8, the emb looks to have more room but like you say hard to tell unless you have it all there to fit. Si Quote Link to comment Share on other sites More sharing options...
goldblades7 Posted June 28, 2013 Share Posted June 28, 2013 Mini 8 killer! Looks quality. 1 Quote Link to comment Share on other sites More sharing options...
Joshyjol Posted June 28, 2013 Share Posted June 28, 2013 Are the wheel hexes 12mm? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 28, 2013 Author Share Posted June 28, 2013 Yep 12mm, so TC rims and Rally Blocks are the way to go Quote Link to comment Share on other sites More sharing options...
jari Posted June 29, 2013 Share Posted June 29, 2013 I've always regretted sell on my LRP Shark LWB, so it was time to get another Micro, this time I went for the Schumacher imported and supported LC Racing EMB-1 On with the build All metal diffs Fitted in the bulks The castings and the metal used for the diff crown and pinion look bombproof, the slipper looks well up to the job as well More to come soon Those diffs look unusual - not the regular style in every other car I've got. i.e. not 4 gears with two shafts crossing in the middle. What is that design of diff called? How do they work? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 29, 2013 Author Share Posted June 29, 2013 Yea it's a different way of doing it, but it seem good way around it with no bevel gears and just straight cut gears. It works in exactly the same was as a normal geared diff from what I can see 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 29, 2013 Author Share Posted June 29, 2013 (edited) Looks like they ripped off Corally http://www.radiocontrolzone.com/showthread.php?t=267899 And also some Traxxarse cars have the same style diffs Edited June 29, 2013 by .AJ. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 30, 2013 Author Share Posted June 30, 2013 I've tried one of wing off the XB4 on her and think it looks so much better And from what I've been reading they jump a lot better with a 1/10th wing 2 Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted June 30, 2013 Share Posted June 30, 2013 Simply looking awesome dude Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 30, 2013 Author Share Posted June 30, 2013 (edited) Cheers, I'll be sticking on one of my LMR wings when they turn up Edited June 30, 2013 by .AJ. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 30, 2013 Author Share Posted June 30, 2013 A couple more pics of the big wing fitted 1 Quote Link to comment Share on other sites More sharing options...
pieman5 Posted June 30, 2013 Share Posted June 30, 2013 (edited) Looks awesome AJ Also looks very similar to the yokomo land jumper (which ive wanted for a while) Reckon its the same platform? Edited June 30, 2013 by pieman5 Quote Link to comment Share on other sites More sharing options...
Colicab Posted July 1, 2013 Share Posted July 1, 2013 Really nice wee buggy, very interested in one myself now, after seeing his thread lol. Congrats tho tis a really nice wee ride. Quote Link to comment Share on other sites More sharing options...
