mini-z-awd Posted September 3, 2015 Share Posted September 3, 2015 Have you switched to the recommended pinion that comes with the car? The 3s pinion? if i had it it would`nt work with the 32p spur gear from the halix Quote Link to comment Share on other sites More sharing options...
Rossyra Posted September 3, 2015 Share Posted September 3, 2015 Your guess is as good as anybody's. There will be a limit because of the space you have to work with, I would have though 16t at most? You would be better off running 3s tbh and sticking with the 13t. Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 3, 2015 Share Posted September 3, 2015 Your guess is as good as anybody's. There will be a limit because of the space you have to work with, I would have though 16t at most? You would be better off running 3s tbh and sticking with the 13t. i have a 14t iam going to try and if that works all leave it at that if it does`nt then all think about a new motor when this one does die Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 3, 2015 Share Posted September 3, 2015 just gave it a try with the14t pinion and it works really good now plenty of speed for me now so no need to go any higher but if i do want more speed new motoro and 3s lipo`s will eb the way to go Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 4, 2015 Share Posted September 4, 2015 (edited) it finally arrived alloy rear camber mount now i have it for wehn i break my plastic one little edit. does anyone no were to get a 20x20x10 esc fan as i seem to have lost 2 of the blades of mine Edited September 4, 2015 by mini-z-awd Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 7, 2015 Share Posted September 7, 2015 (edited) got a new motor well new to me a 4000kv hobbywing jobby now i just need to test it out oh and i kinda dented the old motor somehow (skatepark bash) but the good thing is it still works dented motor Edited September 7, 2015 by mini-z-awd Quote Link to comment Share on other sites More sharing options...
Brandon Posted September 8, 2015 Share Posted September 8, 2015 The stock motor seemed to get quite hot on a short run for me. How are the temps for that motor? Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 8, 2015 Share Posted September 8, 2015 The stock motor seemed to get quite hot on a short run for me. How are the temps for that motor? ran it today doing some jumps and some full pelt runs and it was cool tot eh touch with the halix 58 spur and 13t pinion iam running and i never had any problems withthe stock motro getting hot it got warm but not ernough that i couldnt put my finger on it and leave it there and does anyone know were to get a fan for the stock esc as i need one as mine has given up the ghost Quote Link to comment Share on other sites More sharing options...
Brandon Posted September 8, 2015 Share Posted September 8, 2015 Ok awesome! Thanks! Yeah the stock motor for me just seems like it wants to burn out. I may have binding issues maybe but no idea. I am not sure if you can get the stock fan without the esc but you should be able to get one to fit. Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 8, 2015 Share Posted September 8, 2015 Ok awesome! Thanks! Yeah the stock motor for me just seems like it wants to burn out. I may have binding issues maybe but no idea. I am not sure if you can get the stock fan without the esc but you should be able to get one to fit. one of the front wheels on mine was binding abit when i got it worth looking at them and the esc fan is a weird size 20x20x10 and most of the oens ive seen are 30x30x10 and iam not sure if they`ll fit or not Quote Link to comment Share on other sites More sharing options...
Rossyra Posted September 10, 2015 Share Posted September 10, 2015 Running mine without the fan, have been all along. Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 11, 2015 Share Posted September 11, 2015 Running mine without the fan, have been all along. all end up just taking it off as its no use right now Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted September 17, 2015 Share Posted September 17, 2015 if people are thinking of changing there rod ends to rpm don`t bother they don`t work the ball-ends are to wide to work with the rpm rod ends you could change the ball ends but you would have to find the right size screw thread to fit the glamis plastic Quote Link to comment Share on other sites More sharing options...
MoFoHo Posted October 29, 2015 Share Posted October 29, 2015 Hi all. I need to recalibrate my ESC. I've recently moved back from a Futaba to a Spektrum radio system. When all trims and sub-trims on the throttle channel are set to neutral, the wheels spin backwards gently- I need to apply slight throttle to stop the wheels spinning.I've looked and looked and cannot, for the life of me, find a 'set' button anywhere on the Fuse ESC. I've also tried powering up the ESC with full throttle engaged (as I've seen some ESCs put into 'setup mode' this way) but no luck.Please, anyone: how do I put the ESC into set-up mode? Quote Link to comment Share on other sites More sharing options...
Brandon Posted October 29, 2015 Share Posted October 29, 2015 Just done a quick google search. If you type in Google this:"how to put the 60a fuse esc into setup mode"it should be the first vid. I can't add a link for some reason but it's the first vid. Hope that helps. Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted October 29, 2015 Share Posted October 29, 2015 Hi all. I need to recalibrate my ESC. I've recently moved back from a Futaba to a Spektrum radio system. When all trims and sub-trims on the throttle channel are set to neutral, the wheels spin backwards gently- I need to apply slight throttle to stop the wheels spinning.I've looked and looked and cannot, for the life of me, find a 'set' button anywhere on the Fuse ESC. I've also tried powering up the ESC with full throttle engaged (as I've seen some ESCs put into 'setup mode' this way) but no luck.Please, anyone: how do I put the ESC into set-up mode?the setup button is on the on/off switch Quote Link to comment Share on other sites More sharing options...
MoFoHo Posted October 30, 2015 Share Posted October 30, 2015 Just done a quick google search. If you type in Google this:"how to put the 60a fuse esc into setup mode"it should be the first vid. I can't add a link for some reason but it's the first vid. Hope that helps.In that video, it says turn on the ESC whilst applying full throttle. All that happens (for me), is that after a short delay the wheels just blast forward at full speed. Quote Link to comment Share on other sites More sharing options...
MoFoHo Posted October 30, 2015 Share Posted October 30, 2015 the setup button is on the on/off switch The same switch that is on a short wire? How do I activate that switch, if its the same switch to power on the ESC?(sorry if that comes across as a silly question!) Quote Link to comment Share on other sites More sharing options...
mini-z-awd Posted October 30, 2015 Share Posted October 30, 2015 The same switch that is on a short wire? How do I activate that switch, if its the same switch to power on the ESC?(sorry if that comes across as a silly question!)if you look at the on off switch there is alittle button to the side were the wire comes out you hold that before switching the esc on and then the esc or motor will start making some beep noises if it does then your in setup mode.this should help you out http://www.horizonhobby.co.uk/autoonline/j1-vaterra/j1-product/j1-manual/j1-vtr04000-glamis-uno-manual.pdf Quote Link to comment Share on other sites More sharing options...
mrorange26 Posted April 2, 2016 Share Posted April 2, 2016 Could someone post a link to the steel gear that is being used thanks Quote Link to comment Share on other sites More sharing options...
JungleS2K Posted January 2, 2019 Share Posted January 2, 2019 Hi, Sorry for dragging up an old thread but has anyone got a rear camber mount they don't need or know where I can get one, plastic or alloy? My plastic one broke the other day after reviving the old girl. Not much use without it. I guess I could try to make my own but not ideal. Thanks Quote Link to comment Share on other sites More sharing options...
monkeyboy_uk Posted January 2, 2019 Share Posted January 2, 2019 26 minutes ago, JungleS2K said: Hi, Sorry for dragging up an old thread but has anyone got a rear camber mount they don't need or know where I can get one, plastic or alloy? My plastic one broke the other day after reviving the old girl. Not much use without it. I guess I could try to make my own but not ideal. Thanks You'll have more luck if you post this in the wanted section. Quote Link to comment Share on other sites More sharing options...
