iDesign_5 Posted November 1, 2014 Share Posted November 1, 2014 I just happened to run across something for those with Vandals/Vantages who may be interested. I'm not much on running the stock RTR bodies that come with the cars so if you are looking for a replacement too, the Pro-Line Bulldog Cab Forward bodies made to fit the Schumacher Cat SX3 (item # 3387-00) are pretty much a direct fit, with minimal trimming to the nose. The rest of the body fits the chassis almost perfect. Just my two cents...lol 3 Quote Link to comment Share on other sites More sharing options...
Bigyeti007 Posted November 3, 2014 Share Posted November 3, 2014 (edited) I've had a completely standard brushless carnage for a year, I've used it a handful of times due to time and other things etc, I'm wanting to get a better lipo, I know the standard setup is best suited to 2's so that's what I'll get the question is which one? Having a look it seems hobbyking is the place to get them from but unsure which one, what are you guys using with a standard set up. I'm looking to get 2 and budget is around 30ish Edited November 3, 2014 by Bigyeti007 Quote Link to comment Share on other sites More sharing options...
charlieinsurance Posted November 3, 2014 Share Posted November 3, 2014 Quick question - the ad or these lights says up to 11v. Have you run them on 3S as at full charge they are closer to 12.6V? Does that voltage blow them? Thanks! Quote Link to comment Share on other sites More sharing options...
charlieinsurance Posted November 3, 2014 Share Posted November 3, 2014 For 2S I use nVision Sport 45C. Currently on offer at MS for Quote Link to comment Share on other sites More sharing options...
Relativenewbyseb Posted November 3, 2014 Share Posted November 3, 2014 Probably look for as higher capacity as will fit your budget, 25c 3000mah minimum to provide the amps, but more around 5000 Turnigy/zippy Quote Link to comment Share on other sites More sharing options...
Relativenewbyseb Posted November 3, 2014 Share Posted November 3, 2014 For the lights do they plug into the receiver? If so it will be the same voltage whether on 3s or 2s Quote Link to comment Share on other sites More sharing options...
cgmonkey Posted November 4, 2014 Share Posted November 4, 2014 Finally had a play with the Carnage, good fun but over to quick, I have a 3800 overlander battery and the stock one so need to get some more batteries. Can someone advice on the best battery for a brushed model, I do plan to upgrade to brushless at some point. Also is it normal to hear an slight electric squeal after using for a while? And sometimes it wont go into reverse for a couple of attempts? Quote Link to comment Share on other sites More sharing options...
iDesign_5 Posted November 5, 2014 Share Posted November 5, 2014 Hey y'all. I don't know who may be interested, but since I am racing my Vandal, I looked and looked for a set-up sheet to keep track of everything. Unfortunately, there are none or anything even close really. So I made one by hand on Inkscape. It may even be valuable for those of you who don't race your Vantage/Carnage/Vandal, but want to keep track of things or need to document stuff when you have to tear into it. It's formatted for a standard sheet of paper, so feel free to use it if you have a need. Also, I think I got most everything on it that I could think of sitting here looking at the car, but if there is something else you think needs added, by all means me know! I think I uploaded the file correctly lol guess we will see! http://www.msuk-forum.co.uk/gallery/image/30793-vandal-set-up-sheet/ 1 Quote Link to comment Share on other sites More sharing options...
charlieinsurance Posted November 5, 2014 Share Posted November 5, 2014 There is a reserve lock to prevent damage, ie, forward, brake, reverse, so a slight pause after braking before reverse will engage is normal. May need to reprogramme Failsafe though? Re batteries, trust me on this, once you have gone Brushless (which is exactly what I did, went from brushed on NiMh to Brushless on same) you will want to go for LiPo almost immediately, the speed will become intoxicating! So just get NiMh batteries appropriate for your brushed and then go whole hog and go brushless and LiPo, pref 3S - it gets everything very hot in an otherwise standard Carnage but it will shift! See my posts with my now 4S HPI Trophy which I am looking at potentially upping to 6S and I started with a brushed Vantage and a commitment to spend NO MORE money than that...... Quote Link to comment Share on other sites More sharing options...
charlieinsurance Posted November 5, 2014 Share Posted November 5, 2014 Didn't realise that - so there is a voltage regulator in the ESC that equalises the voltage output to the receiver (and therefore to the steering servo?) regardless of voltage input? I asked on another thread about whether a standard servo could take 6S but from what you are saying the answer to that is also yes since it would not actually be 6S voltage that outputs the ESC to the receiver? Anyone know what voltage does output the ESC? Quote Link to comment Share on other sites More sharing options...
Relativenewbyseb Posted November 5, 2014 Share Posted November 5, 2014 Yep it's a bec, usually 4.8 or 6v, correct me anyone if I'm wrong... [emoji12] Quote Link to comment Share on other sites More sharing options...
capri-boy Posted January 5, 2015 Share Posted January 5, 2015 Going to be getting my FTX Pro 'race' ready over the next couple of weeks or so. Budget city so have gone for a Cheetah 8.5t combo, but stuck with stock pinion atm as I can't find a suitable pack of option sizes. Quote Link to comment Share on other sites More sharing options...
Steven.T Posted January 5, 2015 Share Posted January 5, 2015 Anybody else found the steering is a bit naff? I had mine running on a buggy track for the first time last week and didn't realise I could barely turn the corners at any real speed, don't know if theres any adjustments I can make? Quote Link to comment Share on other sites More sharing options...
Mattyboy Posted January 5, 2015 Share Posted January 5, 2015 Anybody else found the steering is a bit naff? I had mine running on a buggy track for the first time last week and didn't realise I could barely turn the corners at any real speed, don't know if theres any adjustments I can make? If using the stock transmitter then you can turn the steering rate up (it's the dial on the far right if looking down at the Tx). If you're using the stock servo I'd also recommend upgrading it a high torque servo. Good ones can be had for sub 1 Quote Link to comment Share on other sites More sharing options...
cmarti Posted January 5, 2015 Share Posted January 5, 2015 I am about to give this car to my nephew as a gift, tired of replacing the spur gear every time I run the car at the track. And yes I am making sure the mesh is correct. Quote Link to comment Share on other sites More sharing options...
Bigyeti007 Posted January 6, 2015 Share Posted January 6, 2015 A Quote Link to comment Share on other sites More sharing options...
capri-boy Posted January 7, 2015 Share Posted January 7, 2015 I am about to give this car to my nephew as a gift, tired of replacing the spur gear every time I run the car at the track. And yes I am making sure the mesh is correct. Something's not right then. Quote Link to comment Share on other sites More sharing options...
cmarti Posted January 7, 2015 Share Posted January 7, 2015 Something's not right then. I am open to suggestions Quote Link to comment Share on other sites More sharing options...
diago999 Posted January 9, 2015 Share Posted January 9, 2015 (edited) I am open to suggestions Could just be that you are setting the mesh too loose or too tight, are you running brushless or brushed? Failing that, I have a metal spurgear made by someone on this forum that I'd happy to part with (for a cost) as I dont use my vantage anymore. but it is 48p not the standard 0.6mod Edited; 0.6mod not 1.3 its been a while since I spoke Vantage ahah Edited January 9, 2015 by diago999 Quote Link to comment Share on other sites More sharing options...
diago999 Posted January 9, 2015 Share Posted January 9, 2015 Anybody else found the steering is a bit naff? I had mine running on a buggy track for the first time last week and didn't realise I could barely turn the corners at any real speed, don't know if theres any adjustments I can make? Look through the entirety of this forum, theres an image somewhere that shows how to get the best steering out of the buggy, also it might be due to the fact that the End points of the steering throw arent adjustable on the kit transmitter, Or the servo horn might not be in the right place on the spline, ie getting more steering one direction and less the other, Also I trimed abit of the steering arm away to give more throw, as it didnt look like it did anything Hope this helps. Tristan Quote Link to comment Share on other sites More sharing options...
capri-boy Posted January 9, 2015 Share Posted January 9, 2015 Could just be that you are setting the mesh too loose or too tight, are you running brushless or brushed? Failing that, I have a metal spurgear made by someone on this forum that I'd happy to part with (for a cost) as I dont use my vantage anymore. but it is 48p not the standard 1.3mod Could be interested - afaik the std ftx gears are 0.6mod - 1.3 would be more like a 5th scale. Quote Link to comment Share on other sites More sharing options...
diago999 Posted January 9, 2015 Share Posted January 9, 2015 (edited) Could be interested - afaik the std ftx gears are 0.6mod - 1.3 would be more like a 5th scale. Edited thanks And if you search metal gears its the ones someone called daveyboi73 who supplied me mine, He may have some left, but again I have my slightly used one for sale if anyone wants it pm me and we can arrange a price Also Capri-boy, I have a few 0.6mod pinions I think 24,25 and 27 if you were interested in them? all unused but out of packet Edited January 9, 2015 by diago999 Quote Link to comment Share on other sites More sharing options...
capri-boy Posted January 9, 2015 Share Posted January 9, 2015 Edited thanks And if you search metal gears its the ones someone called daveyboi73 who supplied me mine, He may have some left, but again I have my slightly used one for sale if anyone wants it pm me and we can arrange a price Also Capri-boy, I have a few 0.6mod pinions I think 24,25 and 27 if you were interested in them? all unused but out of packet Hi, poss yh - although I think i'll need to gear the other way tbh - i've got a 4000kv 8.5t combo for it, it's only 60a though and pushing the specs running it in a 4wd buggy. I was thinking with the Pro being so light I'd get away with it. Quote Link to comment Share on other sites More sharing options...
diago999 Posted January 9, 2015 Share Posted January 9, 2015 Hi, poss yh - although I think i'll need to gear the other way tbh - i've got a 4000kv 8.5t combo for it, it's only 60a though and pushing the specs running it in a 4wd buggy. I was thinking with the Pro being so light I'd get away with it. Fair enough, for a moment I thought that you were running the unsensored 9t version I had, and its an absolute weapon of a motor. I think you might be right, but the pro version will still be pretty heavy, if you get chance could you weigh it without electrics for me? I've got the alu quanum vandal chassis on mine because I broke the standard one but I'll weigh mine when I can and see what the difference is, have you put the electrics in it yet? Quote Link to comment Share on other sites More sharing options...
cmarti Posted January 9, 2015 Share Posted January 9, 2015 Could just be that you are setting the mesh too loose or too tight, are you running brushless or brushed? Failing that, I have a metal spurgear made by someone on this forum that I'd happy to part with (for a cost) as I dont use my vantage anymore. but it is 48p not the standard 0.6mod Edited; 0.6mod not 1.3 its been a while since I spoke Vantage ahah I ran a traxxas velineon motor in the car, I would love to buy the spur gear from you. I will send you a PM. Quote Link to comment Share on other sites More sharing options...
