THE E-Firestorm Thread
I'm likely to add a dynamite fuze motor to my firestorm in the very near future, before swapping out to a kit.
Does anybody run this motor 5800kv in their firestorm?
If so I'd be interested in gearing/pinions used as well as overall handling and what tips can be offered to calm wheelies down a little :)
Cheers
been messing with the firestorm today while i have been bored, still waiting on the ezerun combo:Photo0132.jpg Had to mod the motor guard to get it on.:closedeyes:
Also swiped the rear spoiler of my old citroen xsara body shell and the roof scoop ;) not decieded whether i like the spoiler yet.Photo0131.jpgPhoto0126.jpgPhoto0129.jpg
After a clear body shell for mine, my firestorm is going to adopt a 2nd look. Doesnt have to be a like for like shell, but ideally a clear one as I'm aiming to paint one up myself.
Any suggestions or links?
<br />After a clear body shell for mine, my firestorm is going to adopt a 2nd look. Doesnt have to be a like for like shell, but ideally a clear one as I'm aiming to paint one up myself.<br />
<br />
Any suggestions or links?<br />
<br /><br /><br />
http://images.rcuniverse.com/forum/upfiles/479007/Mk26042.jpg quite like this I believe it's the pro line short baja body for the savage
only seen it here : http://prolineracing...-tnx-flux-body/ you will probably need this too
http://prolineracing.com/performance-parts/extended-front-and-rear-body-mounts/
also found another pic. Second one down, looks sweet
http://www.hpiracing...llery/2011/1/1/
Edited by notfast
OK, as promised i've returned to give an update on spur compatibility.
I tried using the Blitz spur with Blitz pads. As the Blitz shaft is 13.5mm I had to fit a bearing inside of 5x13.5x4, but upon full assembly the slipper plates didn't compress with the pads for it to work properly due to the bearing being about 1mm too wide. I scrapped this ideac123842a-98aa-a891.jpg
Associated t4 spurs would fit, but I didn't have a reamer handy. You would also need the associated slipper pads to do this.
I then decided it might be a good idea to try the spur and slipper pads and plates out of my Mad Rat and they work superbly.
So there you go; Blitz spurs will work, but you'd need a bearing at least 1mm width less than mine.
Associated spurs fit with a slight reaming.
Mad Rat spur, slipper pads and plates fit wonderfully.
I'm now geared 26/80 and am very happy with this setup.
Although the Firestorm is a very good truck I feel that it was a major oversight that they limited the truck to a 87t. Just my opinion.
Sent from my E10i using Tapatalk
Edited by Damo666
Damo666 excellent info mate i've added a link to it in the first post of this topic, mad rat eh who would have though it.
dtokez Dirt hawgs, dirt paws, gladiators are all good choices
you could always go to 2.8 wheels too. you would have to gear accordingly for the extra weight and size. i am personally gonna be doin this in the next few weeks/months.
Edited by notfast
