Post your Plane/Heli pictures!
I think I'm too slow for the Voodoo even if I wanted one! The Viper is much bigger but even then I wouldn't be able to fly it at pylon racing speeds.
If you like building then why not have a crack at a 125% Slipso from the free RCGroups plans. They cost next to nothing to build and can be pretty quick if powered right. My first glassed wing went wrong so I did another with just Solarfilm covering and that was fine. The wing takes an hour to carve/sand and is pretty strong with a carbon tube embedded in it. The fuselage can just be covered in solarfilm. Not exactly like a Voodoo but lots of fun and won't make your wallet cry if it all goes wrong :)
Thanks for that i thought i had got the hang of posting photos but still got some learning to do.It depends on how much time i have the larger ones take longer to set up and i need a bigger field the smaller ones i can fly in the local park so its quick and easy.
Edited by FEN
:o Thats a Squadron.....
I've only 2 gliders flying...
Moded SkyHawk and a Parkzone Radian
But I've a another new Radian PnP still in a box as spare just incase..:whistling:
Ordered another SkyHawk RTF Glider (only
Thanks now i look at them i have five more not in that photo ill try get a photo up later.
nice collection there is the big purple one a chriss foss extra wot
Hi the yellow and white one is a wot 4 mk3 with an os 75 in it, the purple one is a Eurobat 90inch wingspan and is powered by a crrc 45.
Edited by FEN
Heres my SkyHawk ...or as I call it my Not-Liner
Up-Graded with ....
1750kv Brushless motor
20a ESC
1500 mAh Li-Po's
8x4 Prop
Alloy Spinner
HTX900 Servo's
"Gold-n-Rod" Pushrods
Spektrum DX5e...Rx AR500
Just ordered another one to Up-Grade,this one I want it to fly Faster
Anybody recommend a Motor / ESC / Prop combo ???
Sean
ok hw do i delete a post thats failed then? All i wana do is upload fotos frrom my folder not working so youre now reading this!!!
Sorry im no good with comflippinputers!!!
Why can i not simply upload a photo from my msuk gallery? There is icons for url in post editor but no option to get one from my gallery????
Edited by j1273
Load from photobucket....:good:
But please not thumb nails ( them small photo's):(
Edited by seanmcgrath48
Do you still have the link to these planes......
Here you go. The standard 100% Slipso is well covered but if you want to go bigger with the 125% Slipso (1 metre wingspan) then remember to keep the CG at 28mm from the leading edge to start. They're a simple build and the wing seems more difficult to shape than it really is. I shaped my last wing in an hour!
The 100% performs well on a 3000Kv motor with a 4.75x4.75 prop and 3s battery but the 125% version is a rocket on a decent 4s setup.
Have fun :)
