mixmasterjay Posted January 3, 2010 Share Posted January 3, 2010 (edited) Hi guys and gals i thought we could show everyone our rush,rush evo's , i have upgraded mine quite alot this past week (thanks to martin34) so i will show both the old one and the new and improved one , anyway get your p[ics ,vids out and give us your hints and tips on these and good upgrades to do well here is the upgrade parts ive had front alloy suspension arms purple rear alloy suspension arms purple front alloy hub carriers purple rear alloy hub carriers purple rear alloy brace purple alloy engine mounts purple alloy slipper clutch black steel 49t savage spur gear carbon fibre top deck high torque steering servo LRP.Z 18 S PRO engine tuned mmieke efra exhaust T-15 exhaust header minifold (wider opening at the engine end than the stock LRP header) no 6 glo plug i think thats it lol before pice basically a standard resh evo with a T15 engine Edited July 27, 2010 by mixmasterjay Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 3, 2010 Author Share Posted January 3, 2010 And here is the hopped up rush evo Quote Link to comment Share on other sites More sharing options...
Dirty Electro Posted January 3, 2010 Share Posted January 3, 2010 Nice one jay loving the carbon chassis (top plate) heres the specs of mine, i'll get Wol or Yanto to take some piccies and post them up but anyway the spec so far: FRONT Edit racing front castor blocks Edit racing front Knuckles Abec front wheel bearings Jato front turnbuckles Alloy front suspension arm mounts Alloy front shock absorber towers Re-drilled front suspension arms for better lower shock mounting Hyper 7 front shocks with 20wt associated oil and white stiff springs Thunder Tiger STI shock mounts and pillow balls, with alloy nuts HPI F5 yellow wheels with proline Dirt hawg tires REAR Alloy engine/gearbox brace alloy Rear suspension Tower Alloy suspension arm mounts +1 degree Alloy Rear Knuckle joints Jato Turnbuckles Hyper 7 rear shocks with 25wt associated oil and white springs Redrilled lower suspension arms for better lower shock mount positioning HPI F5 yellow wheels with Proline Dirt hawg tires. Hyper pillowbal rear shock mounts with alloy nuts GEARBOX AND ENGINE HPI ball diff kit with tungsten carbide balls and Dr Liquid diff grease HPI Diff spring kit (hard) HPI Carbon idler gear Abec bearings throughout gearbox HPI heavy duty diff outdrive cups HPI heavy duty output drive shaft HPI Alloy slipper clutch holder HPI Fiber brake disk (Soon to be steel) Nitrostar T15 engine with polished and ported crankshaft Ported and gasket matched dynamite exhaust manifold Vantage racing carbon fiber Revo resonator R pipe RB No.4 glowplug 20% Byrons race fuel HPI/motorsaver hi flow air-filter Fastrax alloy fuel filter 52T savage spur gear with 15T vented clutch bell or 49T Savage spur gear with 19T vented clutchbell 1200 Mah RX stick pack. rear battery box removed and battery hung on to side of roll cage, much better handling lots of other stuff but my fingers are now bleeding typing all of this and I've not mastered typing with elbows just yet As i said at the top, pictures to follow once I've finished the HPI Silverado shell and when Wol or Yanto photo it. Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 3, 2010 Author Share Posted January 3, 2010 that sound awesome mate i never knew hyper 7 shocks and springs fitted thats good to know there is alot to do to mine still then lol i know about the shock towers but i can only find the rear alloy one ,i also want the alloy12mm hex's too now that ive but the little bigger engine in ,i will be going up to 205 fuel soon too as im running the rest of my 16% out it wont take long with this engine lol ,i cant wait for the pics mate Quote Link to comment Share on other sites More sharing options...
Dirty Electro Posted January 3, 2010 Share Posted January 3, 2010 Hyper 7 shocks dont just fit on fella There was a lot of modding involved to get them to fit. The shock towers all had to be drilled etc to allow the pillowball mounts needed for the shocks to fit on, and to get the Jato turnbuckles on, In fact none of the holes in the front or rear suspension towers are the standard size I've got to change my rear hexes to alloy as well I'm also waiting on some Lunsford titanium steering turnbuckles to show up. Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 3, 2010 Author Share Posted January 3, 2010 oh ok so alot of work but thats all good lol , im not sure if ive still got the standard turn buckles on but ive been thinking of upgrading them too Quote Link to comment Share on other sites More sharing options...
Dirty Electro Posted January 3, 2010 Share Posted January 3, 2010 Yep, all your turnuckles are standard mate, you can see them clipped on in the pictures It's easier to go custom with these as well as there is a massive choice cos of the ones used on other models. The turnbuckles are what started my build off, because I wanted adjustable ones, quite literally everything else has been built around the fact that I wanted different, stronger and adjustable turnbuckles. I started this project last year in February, spent nearly all year hunting and gathering parts and now it's almost finished. Lots of the parts fitted to mine are discontinued so it took a fair old hunt about, anything I couldnt find uses parts off other models that have been modified to be honest I wish this bloody snow would do one so i can give her a proper run. Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 4, 2010 Author Share Posted January 4, 2010 your not wrong with the snow mate i wanna propper try this engine out lol well the hunt is on for parts then lol for sure Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 4, 2010 Author Share Posted January 4, 2010 ok so ive ended up keeping the rush evo i was building for turb() (due to personal reasons my end) and all it basically needs is springs and radio gear , it is basically stock apart from a 15t vented steel clutchbell, racing clutch shoes and a mmeike tuned exhaust and a purple anodised chassis it started 3rd pull and it sounds great nice bit of smoke and ive not touched any settings on it Quote Link to comment Share on other sites More sharing options...
Mr Terminator Posted January 4, 2010 Share Posted January 4, 2010 Heres mine,bog standard apart from the TTR rear shocks from the 1/10 TTR truck,small 6v RX pack,TowerPro MG995 steering and a JP Supertec TB servo and finally a Q-World failsafe,it isnt technically mine but the daughter seems to have lost interest which is understandable at 18,courting and at college but its still here for when she does.Just got a brand new stock HPI shell in the bag for it from Manny.No plans for it really as it doesn't interest me enough,it'll get fixed when it breaks and thats it,was gonna stick alloy arms,shock towers and adjustable top arms on it but not till the Revo has seen its upgrades through.... Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 4, 2010 Author Share Posted January 4, 2010 mate like i said before its tooo cllleeeaan lol but it does look great mate thankyou for sharing with us erm 2 lol i took the 18s rush out again today as it was abit drier i got a few good wheelies out of it lol but even on dry tarmac it spins out propably due to the slightly oily rear tyres lol Quote Link to comment Share on other sites More sharing options...
Neil-M Posted January 4, 2010 Share Posted January 4, 2010 looks good jay mate just need to get de-anodizing lol nah its got great pick up Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 4, 2010 Author Share Posted January 4, 2010 yeah im going to get them polished up by my mate Quote Link to comment Share on other sites More sharing options...
Neil-M Posted January 4, 2010 Share Posted January 4, 2010 theres a good tutorial on here mate for de-anodizing mate in guides and tutorials Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 4, 2010 Author Share Posted January 4, 2010 i will have a look cheers for that neil , my mate does all that metal polishing thing with cloth wheels and allsorts lol Quote Link to comment Share on other sites More sharing options...
Neil-M Posted January 5, 2010 Share Posted January 5, 2010 no probs have you thought about putting 1/8 shocks on it? Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 5, 2010 Author Share Posted January 5, 2010 yeah ive thought about it lol, jerre has hyper 7 on his but it took alot of modding i'll find some nice shocks and springs from somewhere for it it can be another project for me lol Quote Link to comment Share on other sites More sharing options...
Neil-M Posted January 5, 2010 Share Posted January 5, 2010 indeed what about a wing??? might look good Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 5, 2010 Author Share Posted January 5, 2010 yeay ive thought of that too its just finding a decent one and with the 18s in it i need a wheelie bar lol Quote Link to comment Share on other sites More sharing options...
Neil-M Posted January 5, 2010 Share Posted January 5, 2010 I've got a spare mate if you want it just need a clean up and to be trimmed down a bit just give me the width between rear tyres mate and il do it for ya and post it out Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 5, 2010 Author Share Posted January 5, 2010 cheers mate that would be great ,from inner tyre to inner tyre its 8 inch mate Quote Link to comment Share on other sites More sharing options...
CarlHarris3.0 Posted January 5, 2010 Share Posted January 5, 2010 LOVIN Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 5, 2010 Author Share Posted January 5, 2010 thanks mate its what your firestorm took over from Quote Link to comment Share on other sites More sharing options...
CarlHarris3.0 Posted January 5, 2010 Share Posted January 5, 2010 thanks mate its what your firestorm took over from Lovin the blue cooling head........can i get one for my firestorm... (Where from ...How much ) looks trick Quote Link to comment Share on other sites More sharing options...
mixmasterjay Posted January 5, 2010 Author Share Posted January 5, 2010 you can get a silver nova cooling head off ebay for about 35 quid , that blue cooling haed is a complete LRP.z 18 s pro engine mate ive took the standard T15 out and replaced it with that Quote Link to comment Share on other sites More sharing options...
