.AJ. Posted July 12, 2020 Author Share Posted July 12, 2020 There’s isn’t really much choice for the B, I may bite the bullet and just go for aluminium bulks Quote Link to comment Share on other sites More sharing options...
Tug Posted July 12, 2020 Share Posted July 12, 2020 Lot of damage for a smallish tumble? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 12, 2020 Author Share Posted July 12, 2020 Not really, it only pulled some threads, it was a pretty heavy hit though Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 13, 2020 Author Share Posted July 13, 2020 2 standard transmission cases order, along with a selection of m5 csk screws, it looks like on the front I can use longer screws than stock, I cant find any rear body mounts in the UK, so I’m going to make my own. I’ve order some L section aluminium and I’ve found a front mount I’m going to mod, I’ll separate the 2 posts and use the L to mount to my previous modified location and then mount the posts to the L 👍 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 14, 2020 Author Share Posted July 14, 2020 I’ve just ordered a pair of these for the rebuild, plus a set of shock boots, the ones on the buggy have started to perish https://www.rcmodelz.co.uk/atop-rc-alloy-one-piece-center-diff-housing-silver.html?___SID=S 1 Quote Link to comment Share on other sites More sharing options...
Mack1 Posted July 14, 2020 Share Posted July 14, 2020 Looks a nice bit of kit and price seems quite good compared to some other makes I have seen. I quite like the look of the red one myself. Maybe on the next diff rebuild I can invest. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 14, 2020 Author Share Posted July 14, 2020 They do look good, I can’t see it performing any different to the TLR one have in the centre or a £60 IRC or RCMAX one 👍 Quote Link to comment Share on other sites More sharing options...
Mack1 Posted July 14, 2020 Share Posted July 14, 2020 I reckon a lot of it is down to branding. The more people recognise a brand the more people want to be seen with that brand so the price will go up to reflect that if that makes sense. Quote Link to comment Share on other sites More sharing options...
mond Posted July 15, 2020 Share Posted July 15, 2020 8 hours ago, .AJ. said: They do look good, I can’t see it performing any different to the TLR one have in the centre or a £60 IRC or RCMAX one 👍 The rcmax one has a proper replaceable oil seal in it and is 7075. Could argue neither are needed but that's the difference. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 15, 2020 Author Share Posted July 15, 2020 True, either way you are still stuck with the stock O-ring on the ring gear side, so kinda pointless having a wiper seal just on one side Quote Link to comment Share on other sites More sharing options...
mond Posted July 15, 2020 Share Posted July 15, 2020 I've never had one leak but I did buy the rcmax one to go in the centre as I melted the centre on my 5ive shortly after putting a Scott Finlay 34cc in it. Destroyed itself in spectacular fashion. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 15, 2020 Author Share Posted July 15, 2020 The plastic centre ones will melt with a 26cc if run hard enough, the funny angle of the front driveshaft generates a fair bit of heat as well Quote Link to comment Share on other sites More sharing options...
Tug Posted July 15, 2020 Share Posted July 15, 2020 A fair bit of heat? They're too hot to touch! Pretty sure I've recorded temps above 90C on the front out-drive cup! However, I've yet to melt the stock cup. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 15, 2020 Author Share Posted July 15, 2020 When a petrol powered one can run for 40mins on a tank they melt pretty easy, low oil weight doesn’t help either Quote Link to comment Share on other sites More sharing options...
mond Posted July 15, 2020 Share Posted July 15, 2020 The only ones i've seen melt were 30DNT ones up until I melted my own. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 15, 2020 Author Share Posted July 15, 2020 My mate melted one in his 5ive T V1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 16, 2020 Author Share Posted July 16, 2020 Fitting the new alloy diff cup to the rear diff...... The outdrives are showing a very small amount of wear, so i’ve swapped them left to right, there is zero wear on the ring gear or pinion and the pinion coupling has zero play.... You can also see the MOD diff inserts. The diff was refilled with 50k. Yeah yeah, I know I should really replace the gasket, but my plumbing mind says it will be absolutely fine 👍 So far I’m very impressed with Atop diff cup 👍 3 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 16, 2020 Author Share Posted July 16, 2020 I bought a set of shock boots at the same time They are junk, they are miles too long for even the rear shocks and fit really poor... Quote Link to comment Share on other sites More sharing options...
mond Posted July 17, 2020 Share Posted July 17, 2020 For the price of the genuine boots you can pick up some shockwears which is silly really. Not bothered with boots since. The mod inserts are nice. I might have to get some next time I rebuild. There's slight sideways play in the rear at the moment although the ring and pinion seem absolutely fine. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 17, 2020 Author Share Posted July 17, 2020 I’ve never been a fan of shockwears, but think I’ll pick a set up next week 👍 Quote Link to comment Share on other sites More sharing options...
mond Posted July 17, 2020 Share Posted July 17, 2020 I'm not a fan of the look either but they make maintenance super easy and keep everything clean and very well protected. Easy to remove unlike other shock sock type things. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 18, 2020 Author Share Posted July 18, 2020 Front diff is now done, there was pretty much zero wear on the outputs and like the rear the pinion and ring gear are still perfect, it’s has been filled with 100k as before👌 3 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 20, 2020 Author Share Posted July 20, 2020 All back together and bench tested, all seems good, also added a bit more rear toe, I’ve gone from 3 to 3.5 degree Still need to to fab up some kind of rear body mount 👍 3 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 20, 2020 Author Share Posted July 20, 2020 And that’s a rear body mount bodged together Needs a bit of refining, but it will work just fine 👍 2 Quote Link to comment Share on other sites More sharing options...
