Nimh charging??
NOFX
Hi. I just programmed the hkc6 charger to charge my 1800mah nimh at 1.8amps.  It took it up to 9.2 volts . The battery is a 6 cell. :boredlook:. I can't programme the voltage , just the charge rate in amps. The provided charger pushes out a massive 500 mah .... So it takes millennia to charge the batteries.Any ideas? Without me having to shell out loads of cash. Tia :ack:
Nimh cells are 1.2v nominal.
Nimh can go up to around 1.5v when charged and ideally no less than 1.0v when flat.
6cells charged = 1.5 x 6 = 9v
