locky Posted April 9, 2017 Share Posted April 9, 2017 Is it possible to make a similar strength bumper to Tbones from a sheet of nylon? Cut and the bend with heat. Quote Link to comment Share on other sites More sharing options...
Carpmart Posted April 9, 2017 Share Posted April 9, 2017 1 hour ago, locky said: Is it possible to make a similar strength bumper to Tbones from a sheet of nylon? Cut and the bend with heat. Yes. You want to buy HDPE sheet. I buy from direct plastics, but smaller quantities are probably best off eBay! Heat gun gives you the heat to bend.... good luck! Quote Link to comment Share on other sites More sharing options...
locky Posted April 9, 2017 Author Share Posted April 9, 2017 1 minute ago, Carpmart said: HDPE sheet Do you think HDPE is as robust as nylon? Quote Link to comment Share on other sites More sharing options...
evssv Posted April 9, 2017 Share Posted April 9, 2017 (edited) 1 hour ago, locky said: Is it possible to make a similar strength bumper to Tbones from a sheet of nylon? Cut and the bend with heat. Yes it is i did a load a while bak I used my old snapped t bones as templates Edited April 9, 2017 by evssv 1 Quote Link to comment Share on other sites More sharing options...
evssv Posted April 9, 2017 Share Posted April 9, 2017 2 Quote Link to comment Share on other sites More sharing options...
dazp1976 Posted April 9, 2017 Share Posted April 9, 2017 10 minutes ago, evssv said: Yes it is i did a load a while bak I used my old snapped t bones as templates Is that copyright infringement? Better watch out the way companies are suing each other these days 1 Quote Link to comment Share on other sites More sharing options...
evssv Posted April 9, 2017 Share Posted April 9, 2017 Bite me Quote Link to comment Share on other sites More sharing options...
locky Posted April 9, 2017 Author Share Posted April 9, 2017 13 minutes ago, evssv said: i did a load a while bak HDPE sheet? 3mm thick? Quote Link to comment Share on other sites More sharing options...
Carpmart Posted April 9, 2017 Share Posted April 9, 2017 26 minutes ago, locky said: Do you think HDPE is as robust as nylon? What do you think a t bone bumper is made from? Quote Link to comment Share on other sites More sharing options...
evssv Posted April 9, 2017 Share Posted April 9, 2017 Just now, locky said: HDPE sheet? 3mm thick? I thk it was. .3 or 4mm Quote Link to comment Share on other sites More sharing options...
locky Posted April 9, 2017 Author Share Posted April 9, 2017 10 minutes ago, Carpmart said: What do you think a t bone bumper is made from? Thought they were made from nylon, which is a polyamide, different to HDPE. Quote Link to comment Share on other sites More sharing options...
locky Posted April 15, 2017 Author Share Posted April 15, 2017 Made front bumper from 3mm HDPE for Hyper ST using Tbone as template, not bashed it yet to see how it compares in strength/robustness but feels flexible enough. 2 Quote Link to comment Share on other sites More sharing options...
Zannu Posted April 18, 2017 Share Posted April 18, 2017 Looking good, You will have to let us know how it holds up, and if HDPE is the right sort of plastic to be making bumpers out off. Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted April 18, 2017 Share Posted April 18, 2017 Very tidy that is. Let us all know how it goes ! Quote Link to comment Share on other sites More sharing options...
evssv Posted April 18, 2017 Share Posted April 18, 2017 All mine held up well no snapped ones. ...still got sum for sale.........hyper /st/st pro pair Quote Link to comment Share on other sites More sharing options...
