200sx Posted March 21, 2017 Share Posted March 21, 2017 Is it normal for the driveshafts to bind when level? Quote Link to comment Share on other sites More sharing options...
evssv Posted March 21, 2017 Share Posted March 21, 2017 level.......jus sat there u mean??? Quote Link to comment Share on other sites More sharing options...
200sx Posted March 21, 2017 Author Share Posted March 21, 2017 No bind at full droop or full compression only at the centre part of movement. Quote Link to comment Share on other sites More sharing options...
evssv Posted March 23, 2017 Share Posted March 23, 2017 On 21/03/2017 at 19:08, 200sx said: No bind at full droop or full compression only at the centre part of movement. sumin not right there then.... Quote Link to comment Share on other sites More sharing options...
Gaz! Posted March 23, 2017 Share Posted March 23, 2017 Have a look at the out puts on the gearbox and the stub axles, have they been spaced out at all? there were a few different types of driveshaft arrangement on this chassis. I'll have a nosey at a online build manual and see what I can advise. EDIT* Just looked, yeah same as brat, best thing I would do is remove each rear corner and clean/rebuild back together using the manual, if you have stuff left over, that's your problem. seems like the driveshafts are too long going from your above posts Quote Link to comment Share on other sites More sharing options...
