Tug Posted May 23, 2020 Author Share Posted May 23, 2020 11 minutes ago, .AJ. said: The IRP servo link? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 23, 2020 Share Posted May 23, 2020 If you run a single sided servo saver it’s a nice part to have 👍 Quote Link to comment Share on other sites More sharing options...
Tug Posted May 23, 2020 Author Share Posted May 23, 2020 Do you mean servo horn? On the brake servo? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 23, 2020 Share Posted May 23, 2020 The IRP link is for the steering, from the servo horn to the servo saver Quote Link to comment Share on other sites More sharing options...
Tug Posted May 23, 2020 Author Share Posted May 23, 2020 Ah, not what I'm after. I want to brace the brake servo as you've done on the B. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 23, 2020 Share Posted May 23, 2020 The Rock Armour brace is for a t/b servo, I’ve got a carbon version and if you mean the one with rod ends , then I made that 👍 Quote Link to comment Share on other sites More sharing options...
Tug Posted May 23, 2020 Author Share Posted May 23, 2020 Yeah, it's the one you made I'm after, cheap and effective. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 23, 2020 Share Posted May 23, 2020 Revo rod ends, a bit of 4mm stud, I did add alloy tube over the stud, but it’s not really needed 👍 Quote Link to comment Share on other sites More sharing options...
Tug Posted May 23, 2020 Author Share Posted May 23, 2020 As in Traxxas Revo? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted May 23, 2020 Share Posted May 23, 2020 Yea Quote Link to comment Share on other sites More sharing options...
Tug Posted June 9, 2020 Author Share Posted June 9, 2020 Tonight I finally got the chance to have another test run, this time 12S. The cells are Floureon 10,000mah packs, and were at 51% at the start of the test. I wanted to see what runtimes were like, but also see that the LVC would work as it should. The efficiency is quite something, I was actually starting to think I'd have to abandon the run as it was getting late, but the cells wouldn't let up. I was driving for close to thirty minutes! Didn't time it to the second, but was out there far longer than I expected! The 380kv motor was superb! Temps rose, but much slower than the 520kv used to. Top temp was 60C, and it took a while to get there. Speed is reasonable, enough to bash keep up with the crowd. No speed records, but meh. Now, that LVC. Not impressed here, the overall parameters available on the ZTW Beast are sparse at best, the LVC is one of the worst. You can't manually select your cell count, and the highest Voltage available is 3.6. At the end of tonight's run, I'd given up and was heading in because the cells were touching 3.0, time to call it. And then finally the LVC cuts in, just as I'm getting back to the house! OK, it worked, but barely! ZTW really need to address this, they're not new to the industry, so why cheap out on their flagship? Can't wait for a full on bash, will try to take accurate timings to see how long she runs. Latazz. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 9, 2020 Share Posted June 9, 2020 My LVC only goes to 3.4, but does seem to work fine, anyway just go bash it, I haven’t got the spare time to test anything, so I just go to my bash spot and hit a few jumps and wing it 😂 Quote Link to comment Share on other sites More sharing options...
Tug Posted June 9, 2020 Author Share Posted June 9, 2020 I only have time for test runs over the road from the house. Seriously, the 5ive platform really needs sub 500kv for efficiency. I was amazed at how long it kept going! Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 9, 2020 Share Posted June 9, 2020 What’s your gearing? I don’t think I could easily gear a 380kv high enough to keep me happy with it in a B tho Quote Link to comment Share on other sites More sharing options...
Tug Posted June 9, 2020 Author Share Posted June 9, 2020 Don't think they're available anymore, shame. 18/58, plenty of room to go up. Could try 20 or 21, but I'm too pleased to be changing anything now. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted June 9, 2020 Share Posted June 9, 2020 Tbh you are probably undergeared with that ratio, go up a tooth and bet you run even cooler Quote Link to comment Share on other sites More sharing options...
Tug Posted July 5, 2020 Author Share Posted July 5, 2020 Was having a quick rip in the park, then it cut out at LVC. No problem, I thought, turn it off and back on again, that'll allow me to limp it home, that's better than dragging it. However, when i turned it back on, it started doing the full throttle from zero thing that others have described. It'll stop if i blip the throttle a few times, but does come back after a few throttle inputs. Annoying as I've only just got it running just how I want it! I'll email RC car online, see what they say. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 5, 2020 Share Posted July 5, 2020 Was that on 10s? Quote Link to comment Share on other sites More sharing options...
Tug Posted July 5, 2020 Author Share Posted July 5, 2020 12S, but only after switching off and back on. Will test tomorrow with fresh cells and see if it does it again. I know I haven't cooked it, not with this set-up, so it's definitely their fault, not mine. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 5, 2020 Share Posted July 5, 2020 If the packs were low I bet the esc thought it was 10s, stick fresh 12s back in it and I bet it’s ok, it’s the same software glitch mine has Quote Link to comment Share on other sites More sharing options...
Tug Posted July 5, 2020 Author Share Posted July 5, 2020 Yeah, I'm starting to think the same. Will test tomorrow. It'd be nice to keep the option of 10S, but not really a deal breaker. 1 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 5, 2020 Share Posted July 5, 2020 It’s not a common fault, but yeah just stick to 12s 👍 Quote Link to comment Share on other sites More sharing options...
Tug Posted July 5, 2020 Author Share Posted July 5, 2020 You still got your original? Still runs fine on 12 cells? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 5, 2020 Share Posted July 5, 2020 Yeah, runs fine on 8s and 12s Quote Link to comment Share on other sites More sharing options...
.AJ. Posted July 6, 2020 Share Posted July 6, 2020 There’s a new firmware that gets rid of the 10s issue, rccaronline will send it to you 👍 Quote Link to comment Share on other sites More sharing options...
