evssv Posted March 11, 2015 Author Share Posted March 11, 2015 (edited) Well me reckoning was spot on...snapped pin..yet again!!!Here's wos left of it.. 2 idy bits..lol!!Let's hope a axle pin fits!! Edited March 11, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 11, 2015 Author Share Posted March 11, 2015 ...found the other bit of the pin..topped up with 60k oil...let's see how long this lasts!! Quote Link to comment Share on other sites More sharing options...
Wrighty8766 Posted March 11, 2015 Share Posted March 11, 2015 Where have you filled the oil upto there bud? Should be just above the cross pins otherwise it will cause extra strain on the diff and can cause...ermm...pins to snap etc Quote Link to comment Share on other sites More sharing options...
evssv Posted March 11, 2015 Author Share Posted March 11, 2015 (edited) Where have you filled the oil upto there bud? Should be just above the cross pins otherwise it will cause extra strain on the diff and can cause...ermm...pins to snap etc ok...filled jus so tops of the 4 gears r covered...the oil sorta dips in the middle..concaved is the word....and I never knew that either!!!...if it goes again I'll refill with less oil nx time...is there any hd pins available or they all the same.. Edited March 11, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
Wrighty8766 Posted March 11, 2015 Share Posted March 11, 2015 ok...filled jus so tops of the 4 gears r covered...the oil sorta dips in the middle..concaved is the word....and I never knew that either!!!...if it goes again I'll refill with less oil nx time...is there any hd pins available or they all the same.. I'm not sure sorry bud, I would imagine the hot bodies lightning ones would fit, and probably be tougher....in 12 months I haven't broken a stock one yet so I haven't looked into it!...I musnt be driving it right Quote Link to comment Share on other sites More sharing options...
evssv Posted March 11, 2015 Author Share Posted March 11, 2015 (edited) I've never broke any on any of our other rc's....strange!!..and I filled all our other brushless diffs to the same level... Edited March 11, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 11, 2015 Author Share Posted March 11, 2015 (edited) Can sum one confirm the pin size pls??....looking for sum but need the size.... Edited March 11, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
Tug Posted March 12, 2015 Share Posted March 12, 2015 Make one from a drill bit shaft? Quote Link to comment Share on other sites More sharing options...
fornowagain Posted March 12, 2015 Share Posted March 12, 2015 Has this same diff snapped more than one pin? Quote Link to comment Share on other sites More sharing options...
evssv Posted March 12, 2015 Author Share Posted March 12, 2015 Has this same diff snapped more than one pin?can't remember which it was last time...i'll go bak n chk through this thread...y U ask?? Quote Link to comment Share on other sites More sharing options...
fornowagain Posted March 12, 2015 Share Posted March 12, 2015 (edited) can't remember which it was last time...i'll go bak n chk through this thread...y U ask?? It's just that when something fails unexpectedly in the same place more than once, then there maybe an underlying cause. Look for things like a raised edge on the outdrive cup pin hole, worn bearing or wear on the gear side diff housing. Anything really. Make sure it's the right pin though, wrong one wouldn't last long. I'd take it as an opportunity to really bullet proof the diff with a vorza cup, hardened gears etc, get rid of the thin 10mm bearing. I'll leave the part numbers in case you need them. HPI101029 Differential Shaft (2), gear pins (2) HPI101142 Hard Differential Gear Set (6 gears, 4 shims) HPI101026 Vorza Differential Case Set HPI102692 Bulletproof Diff Set 29T/9T (if you don't have a donor diff) HPI86599 or 86099 gaskets HPIZ877 8mm shim HPIB085 8mm Bearings ( 2) HPI Z721 Grub Screw M4 x 4mm HPI 86248 Super Heavy Duty Diff Cups HPI 6811 O-rings 6x9.5x2mm (2) 4 off M3 x 15 CSK countersunk socket cap screws. Edited March 12, 2015 by fornowagain Quote Link to comment Share on other sites More sharing options...
evssv Posted March 12, 2015 Author Share Posted March 12, 2015 (edited) It's just that when something fails unexpectedly in the same place more than once, then there maybe an underlying cause. Look for things like a raised edge on the outdrive cup pin hole, worn bearing or wear on the gear side diff housing. Anything really. Make sure it's the right pin though, wrong one wouldn't last long. I'd take it as an opportunity to really bullet proof the diff with a vorza cup, hardened gears etc, get rid of the thin 10mm bearing. I'll leave the part numbers in case you need them.nice one...I'll look In to it..its back togather now so if it goes again then I'll look into what u've suggested above...well the pin is a stock hpi hub hex pin...only thing I had what a fit...i meassured the broken pin and it is 2.75mm diameter but not sure how long as I binned the 2 other bits of it Edited March 12, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 12, 2015 Author Share Posted March 12, 2015 (edited) so I got me gpm bell crank but I'm confused as to how the spring will go on it??..all the integy ones come with spring ect looking like a stock setup but obviously in ally...i don't wanna open it if it ain't gonna b what I wants... or is there bits from the stock set I have to use?? Edited March 12, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
Tug Posted March 12, 2015 Share Posted March 12, 2015 Yeah, you replace the plastic parts with the new ally parts. Quote Link to comment Share on other sites More sharing options...
evssv Posted March 12, 2015 Author Share Posted March 12, 2015 Yeah, you replace the plastic parts with the new ally parts.cool. ...i got a hd spring to fit aswell jus waiting on me alza motor plate and bulkhead kit to turn up and me fr hub carriers the I'm good to go and can get on with it...for now I'm fitting a fr/rear sway kit. . Quote Link to comment Share on other sites More sharing options...
fornowagain Posted March 12, 2015 Share Posted March 12, 2015 (edited) so I got me gpm bell crank but I'm confused as to how the spring will go on it??..all the integy ones come with spring ect looking like a stock setup but obviously in ally...i don't wanna open it if it ain't gonna b what I wants... or is there bits from the stock set I have to use?? You'll just use the original steering post, it the bit with a hex head on one end and the thread with spring & collar on the other, 4mm thread showing with compressed spring. The other post looks different, it's just shorter is all, bearing is further up. Edited March 12, 2015 by fornowagain Quote Link to comment Share on other sites More sharing options...
evssv Posted March 12, 2015 Author Share Posted March 12, 2015 (edited) Nice one...i see now looking at pics of the set up...jus finished fitting me sway bars ..got sum nifty little caps what go over the rod ends in the kit aswell..I still done the cable tie mod to keep the bumper arms togather Edited March 12, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 13, 2015 Author Share Posted March 13, 2015 (edited) so I now have everything all bar the fr hub carriers so I can get on with the alza xl swap....motor plate and bulkhead kit so I'll get me sum ciders in later and make a start on it!! Edited March 13, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
DannyP Posted March 13, 2015 Share Posted March 13, 2015 Couple of beers and rebuilding, bliss Quote Link to comment Share on other sites More sharing options...
evssv Posted March 13, 2015 Author Share Posted March 13, 2015 Couple of beers and rebuilding, bliss jus thinking of going up the offy now actually..... Quote Link to comment Share on other sites More sharing options...
evssv Posted March 13, 2015 Author Share Posted March 13, 2015 (edited) Let the build commence.... Edited March 13, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 13, 2015 Author Share Posted March 13, 2015 (edited) ....first off gonna fit this bit of braid sent by froggy..nice one matey! .. Edited March 13, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 13, 2015 Author Share Posted March 13, 2015 rx box off fr end off rear off Quote Link to comment Share on other sites More sharing options...
evssv Posted March 13, 2015 Author Share Posted March 13, 2015 (edited) took me a while to work out which way the chassis plates went...I had to take off all the battery posts as I had them on the wrong sides...couldn't work out y the motor plate wasn't lining up..d'oh! Edited March 13, 2015 by evssv Quote Link to comment Share on other sites More sharing options...
evssv Posted March 13, 2015 Author Share Posted March 13, 2015 Bloody posts!! Quote Link to comment Share on other sites More sharing options...
