Nitroholic Posted December 8, 2014 Share Posted December 8, 2014 Looking nice and neat That turret had a handy ledge ideal for the purpose! Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 8, 2014 Author Share Posted December 8, 2014 Yea worked out well, thinking about trying a 360 servo for turret rotation next Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted December 8, 2014 Share Posted December 8, 2014 Would love to have that on mine....but the board doesn't allow for it. Would need a lot to make it happen. The HL traverse motor is so damn noisy. Presumably you would either need a course gear on the servo or a much finer toothed turret ring. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 8, 2014 Author Share Posted December 8, 2014 (edited) The IBU2 Pro has all the settings for turret rotation with a 360 servo, you can change both the speed and direction or rotation, this is one of the differences between the IBU2 Base and the Pro, the big problem like you say is the gear ring and pinion to drive it, would it really be worth doing if I still have to use the stock course gears??? But I'll get a servo ordered up ( Edited December 8, 2014 by .AJ. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 8, 2014 Author Share Posted December 8, 2014 (edited) Been having a think, if I can get the servo to run at a low enough speed I could rotate the turret directly off the output shaft of the servo, I would mount the servo on a brace across the underneath of the upper hull, then make a plate to go in the centre of rotation ring and mount a cross shaped servo horn to the dead centre of it, I've just ordered a servo and it has 15kg of torque with metal gears, so it should be well up to the job Edit... Another brainwave If I need to gear down I could fit a spur gear to the centre of the plate in the turret ring and offset the servo and then drill out a pinion gear to fit the servo shaft Edited December 8, 2014 by .AJ. Quote Link to comment Share on other sites More sharing options...
The Dark Knight Posted December 8, 2014 Share Posted December 8, 2014 Looking awesome AJ, all your installs always look neat and tidy, great work 1 Quote Link to comment Share on other sites More sharing options...
johninderby Posted December 8, 2014 Share Posted December 8, 2014 One of these? http://www.hobbyking.com/hobbyking/store/__8863__Turnigy_3_Channel_Servo_Speed_Direction_Regulator.html John Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 8, 2014 Author Share Posted December 8, 2014 Not needed, I've got everything I need to control the servo built into the board Quote Link to comment Share on other sites More sharing options...
RCbutcher Posted December 9, 2014 Share Posted December 9, 2014 (edited) 1x traxxas summit , 1x apocalypse body, then some guns missiles and a tank box for sounds. Or scx10 with .50 on the roof like humvee. I cant see a tank in my house tbh but a gun truck mayb. half track wpuld be cool too. Edited December 9, 2014 by RCbutcher Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 9, 2014 Author Share Posted December 9, 2014 Got round to cutting in the speaker, the sound is a lot better and has a good punch to it now, I made a little vid.... Also I've set the limiters/scale speed on the tracks and spin, she behaves more like a scale tank now Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted December 9, 2014 Share Posted December 9, 2014 Sounding nice Does it play the inspiring Soviet song every time you start the engine, or is that an option! Speed and slower turning is definitely looking nice. I hated the super spin turning my HL came with as stock. Turn that fast and you would rip the tracks off a real tank ( and a 1/16 one too sometimes ) and it makes them a pain to drive. Slower turning just feels right. What you got planned for it now? Quote Link to comment Share on other sites More sharing options...
johninderby Posted December 9, 2014 Share Posted December 9, 2014 Yes a decent speaker makes all the difference. Bluetooth speaker adaptors aren't too expensive so streaming the tank sound to a subwoofer would be interesting. Hmmmmm? John Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 9, 2014 Author Share Posted December 9, 2014 Next step is the 360 servo mod for the turret rotation, then to move back to weather the hull, the plan for the future is to find another upper hull and do a SU152 conversion, I'll share one lower hull with 2 uppers Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 9, 2014 Author Share Posted December 9, 2014 Sounding nice Does it play the inspiring Soviet song every time you start the engine, or is that an option? It's an option, I've got 3 sound clips I can play through channel 6 on my radio, at the moment I've got 2 speech clips and that song, There are other sounds I can replace them with if I want Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted December 9, 2014 Share Posted December 9, 2014 Saw there was an Su152 conversion out there .... very nice indeed. Quote Link to comment Share on other sites More sharing options...
Noj Posted December 9, 2014 Share Posted December 9, 2014 Big improvement over the stock motion and sound Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 11, 2014 Author Share Posted December 11, 2014 (edited) Got the detailed mantlet painted and fitted Edited December 11, 2014 by .AJ. Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 13, 2014 Author Share Posted December 13, 2014 Done the servo turret rotation today, I'm happy with the way it came out, but its a bit quick for my liking, so I've ordered a servo speed controller like Johninderby posted earlier in this thread Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 13, 2014 Author Share Posted December 13, 2014 Crappy vid http://youtu.be/7Ar9WXmuiDU You get the idea and it's nice and quiet which is the real reason for the mod Quote Link to comment Share on other sites More sharing options...
Nitroholic Posted December 13, 2014 Share Posted December 13, 2014 Lack of noisy whirring motors is well worth the effort in my book. Definitely needs toning down in terms of speed, but still better than stock. One thing I did wonder, though. Is the stock motor the noisy part, or is it the plastic gearbox and chunky final drive teeth ? Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 13, 2014 Author Share Posted December 13, 2014 (edited) It's the gears in side the box and the motor which make the noise, I've seen a vid where they have used the geared turret ring and the final drive gear and it's pretty quiet, I did think about going that route, but with spaced becoming very limited in side the hull I needed to get the servo in a specific place in the hull and driving the turret direct off the servo made more sense/room. Once the servo speed controller is fitted it should slow things up nicely Edited December 13, 2014 by .AJ. Quote Link to comment Share on other sites More sharing options...
johninderby Posted December 13, 2014 Share Posted December 13, 2014 I can see why you want to slow it down. Still it is quiet. I'm intending to use servos for the turret rotation, gun elevation and recoil on the Torro Tiger 1 build so I'm interested in seeing how you get on on the KV1. Just scared myself a bit reading through the 9 page manual on the Elmod Fusion Pro and I still haven't downloaded all the documentation yet. Sooooooo many options. Do I really need to use the hatch opening option? Still would be cool to have the drivers hatches slowly open and close remotely. John Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 13, 2014 Author Share Posted December 13, 2014 Just get on with it and work it out when you get to it, that's all I ever do xD Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 13, 2014 Author Share Posted December 13, 2014 Quote Link to comment Share on other sites More sharing options...
.AJ. Posted December 16, 2014 Author Share Posted December 16, 2014 Been messing around with the smoker and found a good mixture Quote Link to comment Share on other sites More sharing options...
