mishking Posted August 6, 2010 Share Posted August 6, 2010 Hi, New to Nitro Cars but have been around racing 2 stoke engines for years, mini moto's etc.... I have brought a CEN TR4 from ebay as a non runner with the intention of getting it back up and running if the engine has any decent form of compression, comes with loads of spares to. http://cgi.ebay.co.u...:EOIBSA:GB:1123 Are these cars any good? If the engine is worn out does any one know of a suitable replacement that will fit? Regards, Greg Quote Link to comment Share on other sites More sharing options...
Sandy Ravage Posted August 6, 2010 Share Posted August 6, 2010 (edited) I have one of these, it's got a .16 in it and its still brand new, mine has a 2 speed box, is yours the same? As I've been told Thunder Tiger and Tamiya spares are a close match to this. Hope that helps you. Its a very quick car Edited August 6, 2010 by Sandy Ravage Quote Link to comment Share on other sites More sharing options...
R46 Posted August 6, 2010 Share Posted August 6, 2010 Hi an Welcome to forum You've got the eye the a bargain Tr4 wasn't a bad car just retail tag new was laughable, As car been stored away best thing to do is strip an clean then lube bearings, rotate engine by hand via flywheel to see if has resistance or smooth (feeling if engine bearings are gummed up from old fuel) Only thing against could be getting spares? from pics it looks like the thottle linkage is missing, replace the K&N airfilter for a foam one( better for engine) as for engine most 12/15/18 pullstart with slide carb will fit (Thunder tiger,Rb,sts,picco,Os,Novarossi,Sirio) you need to get yourself a fail safe device which applys brakes if low battery or signal lose great investment!! off topic: which minmotos got/had? have 2 myself b1rep an z1/zpf rep Quote Link to comment Share on other sites More sharing options...
mishking Posted August 6, 2010 Author Share Posted August 6, 2010 Ive had loads of mini motos over the years but at the moment i have got a b1r with a 50cc big bore kit, 19mm carby and a 3 shoe clutch and performance exhaust. Put's out nearly 11bhp at the wheel!!!. And ive also got a standard Blata elite replica. Thanks for the advice R46. Regards, Greg Quote Link to comment Share on other sites More sharing options...
R46 Posted August 6, 2010 Share Posted August 6, 2010 no worries sweet! my b1 running black widow triple stage reeds,14mm dellorto carb,banshee/alloy rad,ngk race plug,zocchi rep pipe,polini 1/4 turn thottle,powder coated frame,bzm 2 shoe clutch,pmt junior r tyres as raced in proddy class had to remain 39cc the z1 i ditch its 50cc bzm rep motor for genuine polini s2 proddy lump 14/14 carb bzm pipe,polini 1/4 turn thottle,pmt tyres (just need to finish water pump set up) Quote Link to comment Share on other sites More sharing options...
mishking Posted August 6, 2010 Author Share Posted August 6, 2010 My blata elite rep is a savage bike, it so light and very difficult not to lift the front end coming out the corner at full throttle. All good fun. It's a shame about the typical cag quality. Im on the lookout for polini 6.1 lc engine to start my new project but i keep missing them when they go up for sale. Back on topic. Not knowing much about nitro would it be better to run a 16% nitro mix or should i go higher? Im going to start with the base carb settings that CEN recommend for the NT-16 engine and then start to tweak from there. Once ive got it all up and running il post up some pics and vids. Cheers, Greg Quote Link to comment Share on other sites More sharing options...
R46 Posted August 6, 2010 Share Posted August 6, 2010 have you visited your local hobby shop to see what brand fuels they stock? i go for byron gen2 20% and get 2 medium rated glow plugs Quote Link to comment Share on other sites More sharing options...
mishking Posted August 6, 2010 Author Share Posted August 6, 2010 Looks like there is a shop near me so i might pop down on the weekend and have a butchers. Quote Link to comment Share on other sites More sharing options...
mishking Posted August 21, 2010 Author Share Posted August 21, 2010 Update: Have been playing with car today after buying a starter kit and some 20% fuel. I can start car easy with the roto start but the car just revs all the way up and the wheels spin flat out. Anyone have any suggestions to what might be wrong? Regards, Greg Quote Link to comment Share on other sites More sharing options...
Stormbringer Posted August 21, 2010 Share Posted August 21, 2010 the servo reverse switch got moved ? servo not centred properly ? idle screw not adjusted properly ? check those out see if it helps any Quote Link to comment Share on other sites More sharing options...
mishking Posted August 21, 2010 Author Share Posted August 21, 2010 Right i have re-adjusted hsn,lsn and idle back to factory default and it seems to be a hell of a lot better. Wheels move only a little bit at idle now. Quote Link to comment Share on other sites More sharing options...
Stan4th racing Posted September 29, 2021 Share Posted September 29, 2021 Hello and thank you for having me. I have a tr4 awd I have came across I was just wondering what the shell size is it came with a subaru shell many thanks Quote Link to comment Share on other sites More sharing options...
