foxy Posted January 16 Share Posted January 16 Hi all I’ve recently brought a second hand hobao hyper st with the mac star 28 engine.I’m trying to put the Carb to standard i know the settings for the high speed needle and the low speed needle but this has a 3 needle carb and I’m not sure on the settings for the middle needle it’s been messed with so I need the factory settings to move forward. I know as a rule you shouldn’t touch the middle needle but some one has and I’m lost finding the factory settings. Any help would be appreciated cheers. Quote Link to comment Share on other sites More sharing options...
locky Posted January 16 Share Posted January 16 Middle needle is usually flush with carb body, https://www.cmldistribution.co.uk/diagrams/HoBao/Engines/HB_Engine_settings_MacStar_28.pdf 1 Quote Link to comment Share on other sites More sharing options...
foxy Posted January 16 Author Share Posted January 16 1 hour ago, locky said: Middle needle is usually flush with carb body, https://www.cmldistribution.co.uk/diagrams/HoBao/Engines/HB_Engine_settings_MacStar_28.pdf This is what’s confusing me mate or am I just been thick? Quote Link to comment Share on other sites More sharing options...
locky Posted January 16 Share Posted January 16 The above shows the low speed needle. Your original question was referring to mid speed needle. High speed needle is where fuel first enters carb and is main flow control as you accelerate and the carb fully opens, labelled MNV. Low speed needle is the needle in the sliding carb throttle, which controls flow at idle and inital acceleration, labelled STNV. Mid range needle is opp side to LSN, labelled SFN. Idle needle is for setting idle rpm, ie. the air gap, labelled TAS. 1 Quote Link to comment Share on other sites More sharing options...
foxy Posted January 16 Author Share Posted January 16 (edited) Thanks mate for showing me what needle is what I got confused with the instructions for the factory settings I’ve now sorted it and finally got it running. Massive help 👍. Edited January 16 by foxy 1 Quote Link to comment Share on other sites More sharing options...
