mydoddy69 Posted April 2, 2020 Share Posted April 2, 2020 So ever since I saw the release of the builders kit this has firmly been in my mind to get one, now with the current lockdown situation I thought why not 👍 I ordered up the kit and nothing else as I have a few bits knocking around I can use to get started with and don’t want to buy anything aboard right now. Never had an Axial kit before so this will be interesting for me and I’ve never had a true solid axle monster truck before either so a learning curve is coming for sure. All help tips and tricks most welcome 👍👍 Hopefully it won’t take too long to come and I can get started, I’ll add some pics then Quote Link to comment Share on other sites More sharing options...
tamiyafanboy Posted April 2, 2020 Share Posted April 2, 2020 44 minutes ago, mydoddy69 said: So ever since I saw the release of the builders kit this has firmly been in my mind to get one, now with the current lockdown situation I thought why not 👍 I ordered up the kit and nothing else as I have a few bits knocking around I can use to get started with and don’t want to buy anything aboard right now. Never had an Axial kit before so this will be interesting for me and I’ve never had a true solid axle monster truck before either so a learning curve is coming for sure. All help tips and tricks most welcome 👍👍 Hopefully it won’t take too long to come and I can get started, I’ll add some pics then Sounds awesome, really intrigued by this kit! Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted April 2, 2020 Share Posted April 2, 2020 Does the kit come with lockers? I know the RTR are live diffs. Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 2, 2020 Author Share Posted April 2, 2020 1 hour ago, Oh How Original said: Does the kit come with lockers? I know the RTR are live diffs. Not sure Dan there’s no mention of it in any of the info I’ve read to say if there is or isn’t but I’d guess it’s the same as the rtr and your need to purchase them separately. 🤷🏻♂️ Quote Link to comment Share on other sites More sharing options...
Oh How Original Posted April 2, 2020 Share Posted April 2, 2020 3 minutes ago, mydoddy69 said: Not sure Dan there’s no mention of it in any of the info I’ve read to say if there is or isn’t but I’d guess it’s the same as the rtr and your need to purchase them separately. 🤷🏻♂️ I just asked because you mentioned not having a solid axle truck before. 1 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 2, 2020 Author Share Posted April 2, 2020 1 hour ago, Oh How Original said: I just asked because you mentioned not having a solid axle truck before. Got ya 👍👍. 1 Quote Link to comment Share on other sites More sharing options...
Jumper Posted April 2, 2020 Share Posted April 2, 2020 The builders kit comes with open diffs as well. no lockers. Normally a full size monster truck would only have the front axle locked. 1 Quote Link to comment Share on other sites More sharing options...
mond Posted April 2, 2020 Share Posted April 2, 2020 I run AR60s open on my MT. I personally wouldn't run the locked front or rear. 2 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 3, 2020 Author Share Posted April 3, 2020 Thanks for the advice chaps 👍👍 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 3, 2020 Author Share Posted April 3, 2020 10 hours ago, mond said: I run AR60s open on my MT. I personally wouldn't run the locked front or rear. What motor set up you running in yours fella ? Quote Link to comment Share on other sites More sharing options...
mond Posted April 3, 2020 Share Posted April 3, 2020 31 minutes ago, mydoddy69 said: What motor set up you running in yours fella ? Castle 1410 3800kv and run geared down on 3S. Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 3, 2020 Author Share Posted April 3, 2020 9 minutes ago, mond said: Castle 1410 3800kv and run geared down on 3S. Cheers fella I have a hobbywing 3660 3200kv kicking about I’m going to use for now what pinion would you suggest to start with running the j concepts Renegades and like you probably a 3s Quote Link to comment Share on other sites More sharing options...
Jumper Posted April 3, 2020 Share Posted April 3, 2020 I have got a hobbywing system linked below in mine. I run a 16t pinion, 56t spur and overdrive gears in the diffs. I can run both 2s and 3s. mainly run 3s though as 2s can be a bit slow. On a 3200kv 3660 i would have though you can run the 17t pinion easy. I think 17t is the biggest you can run. https://www.modelsport.co.uk/hobbywing-ezrun-combo-max10-3652sl-3300kv-brushless-motor/rc-car-products/420922 if you are going to jump i would recommend open diffs as it will be a lot less stress on the axles. The locked front diff i ran for 2 packs driving up loose dirt hills and it was quite fun, but ive gone back to the open diffs now. 2 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 3, 2020 Author Share Posted April 3, 2020 15 minutes ago, Jumper said: I have got a hobbywing system linked below in mine. I run a 16t pinion, 56t spur and overdrive gears in the diffs. I can run both 2s and 3s. mainly run 3s though as 2s can be a bit slow. On a 3200kv 3660 i would have though you can run the 17t pinion easy. I think 17t is the biggest you can run. https://www.modelsport.co.uk/hobbywing-ezrun-combo-max10-3652sl-3300kv-brushless-motor/rc-car-products/420922 if you are going to jump i would recommend open diffs as it will be a lot less stress on the axles. The locked front diff i ran for 2 packs driving up loose dirt hills and it was quite fun, but ive gone back to the open diffs now. Thanks for the advice fella 👍👍 Ill see how this motor performs I may at a later date go with one of those cheapo 3800 3660 motors on eBay ive seen them with 80a esc which should be plenty for this . Plan is to have it jump back flip and go nuts as cheap as possible 😂 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 3, 2020 Author Share Posted April 3, 2020 Haha it’s here 👍👍was going to take pics but it’s a box full of plastic bits not very exciting at the minute 😂😂 1 Quote Link to comment Share on other sites More sharing options...
mond Posted April 4, 2020 Share Posted April 4, 2020 I think it's got a 16t pinion at the moment. Tbh it's a bit too fast for a scale MT sometimes and it strips rod ends like it's going of of fashion because of it. Good fun though. Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 4, 2020 Author Share Posted April 4, 2020 1 hour ago, mond said: I think it's got a 16t pinion at the moment. Tbh it's a bit too fast for a scale MT sometimes and it strips rod ends like it's going of of fashion because of it. Good fun though. Thanks fella You have any heat issues with running it ? Reason I ask is I’m looking at the Hobbywing 4000kv combo but would like a few gearing options to play around with if this old 3200 isn't up to the job that is 😂👍 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 5, 2020 Author Share Posted April 5, 2020 Pics sadly this is as far as I’ve gotten 😂 I’m not going with a body shell I might get one at a later date though 2 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 9, 2020 Author Share Posted April 9, 2020 Axles done now onto the links 👍. One thing I will say is don’t use power tools these plastic strip real easy I’ve pulled out the old Tamiya tool kit so I can’t crank down to hard on the screws Decided if I like the way it drives I’ll probably invest in some cnc axles and run 4 wheel steer plus believe it or not you can get a cnc axle cheaper than a stock plastic complete set ! Now that’s mental 😂😂 Next up links but I want to modify them before fitting more for looks than anything else 😂 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 12, 2020 Author Share Posted April 12, 2020 Got a little carried away and forgot to take any pics 🤦🏻♂️ Anyway can’t go any further as bits in the kit are incorrect 🤬 There should have been AX31114 x2 for the centre driveshafts but they put in AX31586 x2 which I believe are for a scx 10 and shorter Dare say in the current situation this means the build will be on hold for a few weeks while I get it sorted out 😡 I have ordered up some cheap steel ones from Planedeals U.K. they looks similar to the MIP version but a fraction of the price I went for 110mm x 150mm which should be fine 👍. 1 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 13, 2020 Author Share Posted April 13, 2020 Getting there but still no centre driveshafts 🤦🏻♂️ Raided my stash of body shells and found this little beauty Its a extremely rare Proline Maxx Streamliner only thing is I’d have to trim the wheel arches and I’m in 2 minds to keep it for something else as it’s so rare 😂😂 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 15, 2020 Author Share Posted April 15, 2020 Wired and ready to go almost 2 Quote Link to comment Share on other sites More sharing options...
mydoddy69 Posted April 16, 2020 Author Share Posted April 16, 2020 Axle tube time ! Cant pay UK prices and didn’t want to order from China so made my own down the shed 😂😂 1 Quote Link to comment Share on other sites More sharing options...
Paul Busby Posted April 17, 2020 Share Posted April 17, 2020 This is one of those kits that makes me go... Hmmmmmmmmm every time I'm on the hobby sites. Really tempted buy it but got a lot of modding, building/rebuilding to do as it stands Have you any ideas what kind of shell you're going for yet?That's proline one would look the business. Quote Link to comment Share on other sites More sharing options...
mond Posted April 17, 2020 Share Posted April 17, 2020 14 hours ago, mydoddy69 said: Axle tube time ! Cant pay UK prices and didn’t want to order from China so made my own down the shed 😂😂 Nice, what did you make them from? Quote Link to comment Share on other sites More sharing options...
