mightymini-5 Posted May 30, 2015 Share Posted May 30, 2015 Hi all just got a scout for our daughter with no motor or pinion i have a 27t motor was just wondereing what pinion many thanks shaun Quote Link to comment Share on other sites More sharing options...
Tamiyacowboy Posted May 30, 2015 Share Posted May 30, 2015 (edited) 0.6 mod pinion around 14 teeth should be perfect freepawn racing site stocks them. : http://www.freeprawnracing.co.uk/rw-racing-06-module-steel-pinions-9t-30t-rw0600.html Edited May 30, 2015 by Tamiyacowboy Quote Link to comment Share on other sites More sharing options...
mightymini-5 Posted May 30, 2015 Author Share Posted May 30, 2015 i have just tried a 48dp 23t pinion that i had but could not get gearbox back in with motor attached as motor was too far over but 48dp teeth looked as if it meshed perfect when spun over ?? i had one before from new and i thought a little too slow if i was to go 17 instead of 14 would that make it go a little faster many thanks in advance shaun Quote Link to comment Share on other sites More sharing options...
Tamiyacowboy Posted May 30, 2015 Share Posted May 30, 2015 i was sure they came with a 13t or 14t pinion as stock. if your 23 does not fit its because your to high on teeth. so something like a 16 should do for a little xtra speed, but remember the scouts a bit top heavy and not really built for speed. more clambering around things. saying that it can be dropped lower so its more flatter running chasis and less prone to tip over at speed 1 Quote Link to comment Share on other sites More sharing options...
mightymini-5 Posted May 30, 2015 Author Share Posted May 30, 2015 many thanks mate Quote Link to comment Share on other sites More sharing options...
ghazghul Posted June 1, 2015 Share Posted June 1, 2015 48dp is correct. You are already going from a 70t (stock) motor to 27t so I wouldn't go for a bigger pinion then stock (14t I think... It's whatever the motor is listed as, typical Maverick) or it's going to be way fast and have no torque... Quote Link to comment Share on other sites More sharing options...
Tamiyacowboy Posted June 1, 2015 Share Posted June 1, 2015 (edited) if the esc is beefed up he could run a 27x2 or 27x3 , the dual or triple wind would produce some extra torque and also smooth out that rawness on the speed somewhat. we are so used to running single wind motors we forget the racer dual and triple turn winding cans. Edited June 1, 2015 by Tamiyacowboy Quote Link to comment Share on other sites More sharing options...
mightymini-5 Posted June 1, 2015 Author Share Posted June 1, 2015 many thanks all or the advice i already have a single 27t motor lying around so if i use a 13t pinion should be ok is this correct or should i go 12t shaun P.S do the Wheely King diff lockers internals do the same/ fit the same as Axial internal ones as a mod on these Quote Link to comment Share on other sites More sharing options...
ghazghul Posted June 2, 2015 Share Posted June 2, 2015 many thanks all or the advice i already have a single 27t motor lying around so if i use a 13t pinion should be ok is this correct or should i go 12t shaun P.S do the Wheely King diff lockers internals do the same/ fit the same as Axial internal ones as a mod on these Not sure if you'll get a 12T to mesh. I run a 13T on a 13.5T brushless setup ok. The axial lockers only fit in the scout housing if you (carefully) drill out the diff as it has a plastic lump in the middle acting as a locker. The axle ends also need grinding to fit into the locker as they are larger on the scout. I assume WK ones are same as Axials. It's a pain but worth doing and if you fit CVDs or rear lockouts then they fit without grinding. Quote Link to comment Share on other sites More sharing options...
