arogon1235 Posted January 16, 2014 Share Posted January 16, 2014 my xl2 is thinking that foward is reverse and reverse is foward. the red light lights up on the esc when i pull foward and the green light lights up when i pull reverse can anyone help me. Quote Link to comment Share on other sites More sharing options...
R46 Posted January 16, 2014 Share Posted January 16, 2014 you got ch2 reversed on radio? recalibrated esc? 1 Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 16, 2014 Author Share Posted January 16, 2014 (edited) i dont know how to reverse channel 2 on the flysky gt3b if they even have that feature. Edited January 16, 2014 by arogon1235 Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 16, 2014 Author Share Posted January 16, 2014 derp found out it does have that feature reversed channel 2 and it works how it should now foward green light light up and reverse the red light lights up. cant believe i didn't think of that must have been because i was annoyed. thanks r46 cant thank you enough mate. top man Quote Link to comment Share on other sites More sharing options...
R46 Posted January 16, 2014 Share Posted January 16, 2014 yours is as follows: 1.) Turn on the radio2.) Press the large, round ENTER button. The MODEL text will highlight.3.) Turn the large, round ENTER button until REV highlights4.) Press the large, round ENTER button. The channel number will begin flashing.5.) Turn the large, round ENTER button to select the channel number you want.6.) Press the END button. The NOR (or REV) indication will start flashing.7.) Turn the large, round ENTER button to select REV (reverse) or NOR (normal).8.) Press the large, round ENTER button to save the setting for this channel. The transmitter will make a slight BEEP sound.9.) This channel has now been changed and saved. If you want to change another channel, go back to step 4.10.) When you have changed the direction of all the channels you wanted to change, press the BACK button to return to the opening screen.Done 2 Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 31, 2014 Author Share Posted January 31, 2014 just looked at the esc again and looks like i have a problem again when i am applying no break or throttle and the esc flashes yellow i can use the throttle and break no problem and seems fine but when i looked up the led codes for flashing yellow with no throttle input it says possible problem with esc i have re calibrated it but it still does the same thing should i send it of to castle to get it looked at or am i worrying about nothing. Quote Link to comment Share on other sites More sharing options...
atom3624 Posted January 31, 2014 Share Posted January 31, 2014 (edited) Do you have the Castle link? Hook up the ESC to the computer and reverse the motor there. I had the same problem with my E-Maxx - I'm assuming XL2 is Castle Creations Mamba XL2. If not, sorry for confusing the issue. Al. Edited January 31, 2014 by atom3624 Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 31, 2014 Author Share Posted January 31, 2014 already tried that but still flashes yellow Quote Link to comment Share on other sites More sharing options...
jony nitro Posted January 31, 2014 Share Posted January 31, 2014 Mine flashed when in Neutral? Not much input, and all was well Quote Link to comment Share on other sites More sharing options...
atom3624 Posted January 31, 2014 Share Posted January 31, 2014 I'd try again ... if no joy, contact CC. They're very helpful once you've got a direct contact. Al. Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 31, 2014 Author Share Posted January 31, 2014 (edited) tried it again no luck still flashes yellow, already emailed castle creations yesterday just waiting on their reply now. the only thing i can think of is the yellow led flashing means its logging data. Edited January 31, 2014 by arogon1235 Quote Link to comment Share on other sites More sharing options...
Tug Posted January 31, 2014 Share Posted January 31, 2014 My first one flashed yellow, then vented. Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 31, 2014 Author Share Posted January 31, 2014 hmm doesn't look good then, i got it from amainhobbies would castle still replace the esc. Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 31, 2014 Author Share Posted January 31, 2014 would it be better to send it to castle or send it to logic rc Quote Link to comment Share on other sites More sharing options...
arogon1235 Posted January 31, 2014 Author Share Posted January 31, 2014 just got a reply from castle and tuns out the led flashing yellow means its....... logging data could have atleast told me this in the user manual Quote Link to comment Share on other sites More sharing options...
atom3624 Posted February 1, 2014 Share Posted February 1, 2014 International purchases, I got in touch with Castle direct. Not too polite, but the service was spot on and replaced without charge .... then said I was overloading it by overgearing ....and won't replace again!! Al. Quote Link to comment Share on other sites More sharing options...
