SnoopMaxx Posted February 6, 2010 Share Posted February 6, 2010 Where can I find a HD diff pinion gear for the TT-01 I found the diff gear but the diff pinion is plastic Quote Link to comment Share on other sites More sharing options...
Garry Posted February 7, 2010 Share Posted February 7, 2010 I haven't seen one around the net, if someone made one, I'd have expected it to be Yeah Racing (but there isn't one on their site). Its not really needed to have metal gears inside each TT01 gearbox anyway, the stock plastic ones are really tough and I've not seen anyone strip them, even with really quick brushless systems. Quote Link to comment Share on other sites More sharing options...
adeace Posted February 7, 2010 Share Posted February 7, 2010 (edited) Quick one looking for an update:- got stock teu101bk esc and stock silver can in TT01. Just bought turnigy 5000 2S hard case - would anyone recomend a new esc possibly with lipo cut out protection or just buy a gv lipo cut off ? If getting new esc would you recommend one which can take a lower turn motor for more speed in future (still want forward & reverse) ? Budget wise im a tight arse so as little as possible. Again any thoughts appreciated. Ade Edited February 7, 2010 by adeace Quote Link to comment Share on other sites More sharing options...
midi-mania Posted April 4, 2010 Share Posted April 4, 2010 just thought id mention, some of the links in the first post are no longer going to the correct items Quote Link to comment Share on other sites More sharing options...
geordie121 Posted January 26, 2011 Share Posted January 26, 2011 Hello there! I'm fairly new to the RC world and completely new to the forum. I see its been a fair while since anyone posted on here. was just wanting some help. I have TT01 E which has an alloy prop shaft and metal bearings. I'm wanting to put something like a 12T motor and suitable ESC in it but don't know where to start to be honest. Does anyone have any suggestions? I'm not into drifting or anything, just beating my mates on a huge car park we have at work! What about this My link Cheers! Quote Link to comment Share on other sites More sharing options...
Garry Posted January 26, 2011 Share Posted January 26, 2011 Welcome to the forum Yep, that'll be great, you could also go for the Fusion 10.5 without putting much more stress on the car. Quote Link to comment Share on other sites More sharing options...
geordie121 Posted January 26, 2011 Share Posted January 26, 2011 Hey thanks for the reply. I think I'll go for the 13 turn. Can anyone explain what pinnion I'll need? Tried looking at the diagram on the first page on this thread but don't quite understand it. Cheers Quote Link to comment Share on other sites More sharing options...
geordie121 Posted January 26, 2011 Share Posted January 26, 2011 Just read it more thoroughly and i understand it a bit more. I didn't know what turn my spur gear was. Had a look and its a 61T. Cheers Quote Link to comment Share on other sites More sharing options...
Garry Posted January 27, 2011 Share Posted January 27, 2011 Normally when fitting as faster motor, you'd go higher on the gearing, so, fitting a smaller pinion or bigger spur gear. But, the TT01 usually comes with a 19 tooth pinion and 61 tooth spur which is as high as you can go, so leave it be. Quote Link to comment Share on other sites More sharing options...
RClewis Posted April 14, 2011 Share Posted April 14, 2011 Iv bought a baja champ it has the ballrace kit on it , but is there any other upgrades for it ???? I think im going to get the suspention upgrade aswell Quote Link to comment Share on other sites More sharing options...
Garry Posted April 14, 2011 Share Posted April 14, 2011 Ansmann do oil filled shocks in various lengths, so I'd be looking at a couple of pairs of those Nothing much else really, its a tough car so won't need alloy, and the bearings cover the efficiency area. Maybe tyres to suit your surface, and then brushless/LiPo if you want more speed? A metal geared servo would be a good idea for more holding power in the corners. Quote Link to comment Share on other sites More sharing options...
Quantra Posted April 14, 2011 Share Posted April 14, 2011 Do LiPo's fit in the TT-01 with no hassle? Quote Link to comment Share on other sites More sharing options...
Garry Posted April 14, 2011 Share Posted April 14, 2011 Most do, a 5000mah pack can be a squeeze though and it helps to get rid of those triangle locators from one side of the battery area. Just Dremel them away to make space. Quote Link to comment Share on other sites More sharing options...
leongordon234 Posted April 18, 2011 Share Posted April 18, 2011 Welcome to the forum Yep, that'll be great, you could also go for the Fusion 10.5 without putting much more stress on the car. I recently built my tt01e and i put a fusion 10.5turn in and it runs sweet with loads of speed and acceleration, so the fusion10.5 is highly recommended without to much stress Quote Link to comment Share on other sites More sharing options...
fatboyneil Posted July 24, 2011 Share Posted July 24, 2011 (edited) can anyone tell me what battery will fit my tl-01 without hacking anything off the chassis also where can i get a carbon propshaft from its the only hop up part i didnt get when they where first out Edited July 24, 2011 by fatboyneil Quote Link to comment Share on other sites More sharing options...
Garry Posted July 24, 2011 Share Posted July 24, 2011 Rounded LiPo backs will fit, they are packs with a rounded profile. HPI, Ansmann, Yeah Racing and Core all do packs to suit, as do others, but you'll need to trim the L-shaped battery straps for a bit of clearance. If you want to stick with NiMH cells, then Vapextech packs fit too but might need the straps trimming as well. Quote Link to comment Share on other sites More sharing options...
fatboyneil Posted July 25, 2011 Share Posted July 25, 2011 Rounded LiPo backs will fit, they are packs with a rounded profile. HPI, Ansmann, Yeah Racing and Core all do packs to suit, as do others, but you'll need to trim the L-shaped battery straps for a bit of clearance. If you want to stick with NiMH cells, then Vapextech packs fit too but might need the straps trimming as well. thanks garry but i've got the quick release adapters to go on yet dont know if that should help i am after lipo but most rounded ones on ms say 45mmx24mm for width and depth wich is too big for the hole in the chassis i still have a origanal 1400mah nicd tamiya pack that holds a half decent charge but i'm gonna need something for longer run times than 5 minutes Quote Link to comment Share on other sites More sharing options...
xfirus Posted July 31, 2011 Share Posted July 31, 2011 Seems like the best place to put this (most likely) silly question. Since I'm going to start using an old TL01 I have for rally I thought why not get a rally shell to go with it and quite like the look of the 306 Maxi shell that came with the FF02 models, will this shell fit onto a standard TL01? or will I have to perhaps change the rear mounts since from pictures it looks like the mounts are pretty similar in position. Quote Link to comment Share on other sites More sharing options...
Garry Posted August 1, 2011 Share Posted August 1, 2011 Yep, its 190mm wide and has a 257mm wheelbase so its just a case of using FF02 rear body mounts on the TL01. Quote Link to comment Share on other sites More sharing options...
xfirus Posted August 1, 2011 Share Posted August 1, 2011 Yep, its 190mm wide and has a 257mm wheelbase so its just a case of using FF02 rear body mounts on the TL01. Cheers, They have the same C parts according to the manuals but if I had kept them which I thought I would have then I have no idea where they would be now, looks like I've got another part to get . Quote Link to comment Share on other sites More sharing options...
cossieboy2007 Posted August 9, 2011 Share Posted August 9, 2011 i bought a escort wrc xbs, and i wanted to make it a bit faster, i've just bought a bearing kit and a alloy prop shaft, and i wanted to know how to fit them, i am a novice so please help? Quote Link to comment Share on other sites More sharing options...
Garry Posted August 10, 2011 Share Posted August 10, 2011 Welcome to the forum! Have you got a manual? If not, download one here: http://www.tamiya.com/english/rc/rcmanual/tt01.pdf The centre driveshaft is a case of taking the spur gear cover off, then maneuvering the spur gear and mounts out to get the driveshaft out. The bearings simply replace all the plastic and bronze bushings inside each gearbox casing and wheel hub. Quote Link to comment Share on other sites More sharing options...
cossieboy2007 Posted August 11, 2011 Share Posted August 11, 2011 @Garry thanks, i also wanted to know if i needed tamiya grease for the bearings? Quote Link to comment Share on other sites More sharing options...
Garry Posted August 11, 2011 Share Posted August 11, 2011 Nope, if you can get hold of some sewing machine oil then thats ideal, but I've just fitted the bearings and ran them with the oil already in them fine. Quote Link to comment Share on other sites More sharing options...
cossieboy2007 Posted August 12, 2011 Share Posted August 12, 2011 @Garry thanks, i have some sewing machine oil in the shed, also is this kit suitable for a tt01d drift car, because it only says tt01/tt01e? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=380360787638&ssPageName=STRK:MEWAX:IT Quote Link to comment Share on other sites More sharing options...
