momin Posted April 28, 2005 Share Posted April 28, 2005 Hi, I started mt car and it stalled. so i pulled the starter again and when i pulled it it just stayed out. it never went back in. any suggestions? Thanks momin Quote Link to comment Share on other sites More sharing options...
Tony Posted April 28, 2005 Share Posted April 28, 2005 Wiggle it. If it doesn't go back in, the spring is broken. You might need to take it apart to fix it. Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted April 28, 2005 Share Posted April 28, 2005 this has happend to me loads of times with my pure 10, if you never heard a loudisg noise then its just jammed probably, I just keep pullin at it (not too hard) and eventually it'll spring back in it could take some time though, once i spent 30 mins messin with it before it went back in Quote Link to comment Share on other sites More sharing options...
momin Posted April 28, 2005 Author Share Posted April 28, 2005 Hi, Ok, I got it sorted by loosing the screws that hold the pull starter (Dazzi you should try this). Has anyone got any good tips on starting the engine as i cant seem to start (i did yesterday)! Thanks momin Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted April 28, 2005 Share Posted April 28, 2005 whats happenin to it? wen u try to start Quote Link to comment Share on other sites More sharing options...
LEE69 Posted April 28, 2005 Share Posted April 28, 2005 pour a little fuel in the carb glow plug ok and charged up? Quote Link to comment Share on other sites More sharing options...
momin Posted April 28, 2005 Author Share Posted April 28, 2005 It just doesent start. Lee il try pooring Fuel into the carb. anyone got any ideas on pulling the starter? Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted April 28, 2005 Share Posted April 28, 2005 richening the lsn usually sorts it out for me (wen it stalls straight away) pullstart? just pull it,not too much though, if you have good compression it should start on the first bite, my cars do, I rarly have to pull more than 10cms Quote Link to comment Share on other sites More sharing options...
Nitr0Maj0r Posted April 28, 2005 Share Posted April 28, 2005 Any change in weather conditions? Quote Link to comment Share on other sites More sharing options...
momin Posted April 28, 2005 Author Share Posted April 28, 2005 Slightly windyer at the mo. Would it make a difference if i heat the cooling head up with a hair dryer? Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted April 28, 2005 Share Posted April 28, 2005 if the engine is cold yes,but that only needed in winter, yor lsn maybe to lean cos of the milder weather also richen the hsn thats what i do,then just lean em up a bit once its running don't know if thats the best advice but its what i do Quote Link to comment Share on other sites More sharing options...
momin Posted April 28, 2005 Author Share Posted April 28, 2005 Would my glow starter be usable from 1hour charge from flat? Quote Link to comment Share on other sites More sharing options...
rc007 Posted April 28, 2005 Share Posted April 28, 2005 if the engine is cold yes,but that only needed in winter, yor lsn maybe to lean cos of the milder weather also richen the hsn thats what i do,then just lean em up a bit once its running don't know if thats the best advice but its what i do ← Milder weather usually requires a leaner mixture than colder weather due to the air being less dense. Quote Link to comment Share on other sites More sharing options...
dazzi220 Posted April 28, 2005 Share Posted April 28, 2005 Milder weather usually requires a leaner mixture than colder weather due to the air being less dense. ← maybe I should have pointed out thats what I've been doing all winter, you just saved me alot of posting when my cars won't start lol Quote Link to comment Share on other sites More sharing options...
nitro_beginner Posted April 28, 2005 Share Posted April 28, 2005 (edited) maybe I should have pointed out thats what I've been doing all winter, you just saved me alot of posting when my cars won't start lol ← Erm.......Excuse me whats isn? Edited April 28, 2005 by nitro_beginner Quote Link to comment Share on other sites More sharing options...
doom56 Posted April 30, 2005 Share Posted April 30, 2005 isn no its LSN means Low Speed Neddle wich is located inline of the carb air hole rod Quote Link to comment Share on other sites More sharing options...
300ZXZ31 Posted May 6, 2005 Share Posted May 6, 2005 try spinning the fly wheel the other way to the way the engine would normally run and that sould bring the string back in aslong as the owb is working. Quote Link to comment Share on other sites More sharing options...
